How to turn Display (SSD1306) on, when needed
Dear community,
I would like to build an Air Quality sensor for my kids. It should show some Air Quality Data on a Display. The Display should only be on, when the kid is nearby.
Firmware:
  • ESPhome
Hardware available:
  • D1mini board (ESP8266)
  • VL53L0X (laser distance sensor)
  • SSD1306 Display
  • BME680 (temp, humidity, preassure, VOC/CO2)
Issue:
I have put everything together and everythings works fine - for a minute or so. Then, the distance sensor trips over something and starts sending nan-values.
[23:45:06][D][sensor:093]: 'VL53L0x Distanz': Sending state nan m with 2 decimals of accuracy
[23:45:06][W][vl53l0x:265]: VL53L0x Distanz - update called before prior reading complete - initiated:0 waiting_for_interrupt:1
I have found these two, old and unresolved issues:
Questions:
  • Is there anybody out there, who has successfully implemented a VL53L0X-sensor with a D1mini?
  • If not, what are other options to turn on/off a SSD1306 display, when somebody is nearby?
any help is very much appreciated.
current ESPhome code
# Variablen
substitutions:
  device_name: "esphome-test"
  friendly_name: "Test"
  node_name: "esphome_test"
  device_description: "Test Konfiguration"
# ESPHome Core Configuration
esphome:
  friendly_name: '${friendly_name}'
  comment: '${device_description}'
  platformio_options:
    build_flags:
      - -DPIO_FRAMEWORK_ARDUINO_MMU_CACHE16_IRAM48_SECHEAP_SHARED
  # Loop, der nach erfolgreicher WLAN-Verbindung und Zeitabfrage ausgefĂŒhrt wird
  on_boot:
    priority: -100  # Setze die PrioritĂ€t niedriger als die WLAN-Verbindung (standardmĂ€ĂŸig -10)
    then:
      - while:
          condition:
            not:
              lambda: 'return id(homeassistant_time).now().is_valid();'
          then:
            - delay: 1s # Warte eine Sekunde, bevor erneut ĂŒberprĂŒft wird
      - lambda: |-
          // Sobald die Zeit verfĂŒgbar ist, berechne den Boot-Zeitpunkt
          id(${node_name}_last_boot_time).publish_state(
            id(homeassistant_time).now().timestamp - (int) id(${node_name}_uptime_seconds).state
esp8266:
  board: d1_mini
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: "xxx1"
ota:
  - platform: esphome
    password: "xxx2"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: 192.168.30.5
    # Set this to the IP address of the router. Often ends with .1
    gateway: 192.168.30.1
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: 255.255.255.0
  use_address: ${device_name}.internal
  domain: .internal
  ap:
    ssid: '${device_name}'
    password: "xxx3"
captive_portal:
# enable web interface on device
#web_server:
# port: 80
font:
  # gfonts://family[@weight]
  - file: "gfonts://Roboto"
# Zeit von HomeAssistant abfragen -> fĂŒr Last Boot nötig
time:
  - platform: homeassistant
switch:
  - platform: restart
    name: "ESPHome Wohnzimmer neu starten"
i2c:
  sda: D2
  scl: D1
  scan: true
# Display SSD1306 einbinden
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x32"
    reset_pin: D0
    address: 0x3C
    lambda: |-
      it.print(0, 0, id(roboto_10), "Hello World!");
# BME680 Sensor einbinden
bme68x_bsec2_i2c:
  address: 0x77
  model: bme680
  operating_age: 28d
  sample_rate: ULP
  supply_voltage: 3.3V
  temperature_offset: 0    # dieser Wert wird abgezogen
  state_save_interval: 6h
# Last Boot Sensor definieren (Berechnung findet einmalig beim Boot statt)
  - platform: uptime
    name: "Uptime Sekunden"
    internal: true
    device_class: timestamp
    entity_category: diagnostic
    accuracy_decimals: 0
    update_interval: never # Kein regelmĂ€ĂŸiges Update nötig
# VL53LOX Distanzsensor
  - platform: vl53l0x
    address: 0x29
    timeout: 200us
    update_interval: 500ms
    unit_of_measurement: "m"
    device_class: distance
    state_class: measurement
  # Konfiguration fĂŒr BME680 Sensor
  - platform: bme68x_bsec2
    temperature:
      name: "BME680 Temperature"
#      filters:
#        - offset: -0.9
    pressure:
      name: "BME680 Pressure"
    humidity:
      name: "BME680 Humidity"
      filters:
        - offset: -5
    iaq:
    co2_equivalent:
      name: "BME680 CO2 Equivalent"
    breath_voc_equivalent:
      name: "BME680 Breath VOC Equivalent original"
      internal: false
    name: "BME680 Breath VOC Equivalent"
    lambda: |-
      return ( (id(voc_source).state) * 1000) ;
    device_class: volatile_organic_compounds_parts
    unit_of_measurement: ppb
    update_interval: 5min
    icon: 'mdi:molecule'
# BME680 Wohnzimmer: Taupunkt berechnen
    name: "BME680 Taupunkt"
    lambda: |-
      return (243.5*(log(id(bme680_humidity).state/100)+((17.67*id(bme680_temp).state)/
      (243.5+id(bme680_temp).state)))/(17.67-log(id(bme680_humidity).state/100)-
      ((17.67*id(bme680_temp).state)/(243.5+id(bme680_temp).state))));
    device_class: temperature
    unit_of_measurement: °C
    icon: 'mdi:thermometer-water'
text_sensor:
    iaq_accuracy:
      name: "BME680 IAQ Accuracy"
  # Air Quality-Angaben
    name: "BME680 IAQ Classification"
    lambda: |-
      if ( int(id(iaq).state) <= 50) {
        return {"extrem gut"};
      else if (int(id(iaq).state) >= 51 && int(id(iaq).state) <= 100) {
        return {"sehr gut"};
      else if (int(id(iaq).state) >= 101 && int(id(iaq).state) <= 150) {
        return {"gut"};
      else if (int(id(iaq).state) >= 151 && int(id(iaq).state) <= 200) {
        return {"mittelmÀssig"};
      else if (int(id(iaq).state) >= 201 && int(id(iaq).state) <= 250) {
        return {"schlecht"};
      else if (int(id(iaq).state) >= 251 && int(id(iaq).state) <= 350) {
        return {"sehr schlecht"};
      else if (int(id(iaq).state) >= 351) {
        return {"extrem schlecht"};
      else {
        return {"Fehler"};
  # Send IP Address
  - platform: wifi_info
    ip_address:
Hi, you might be able to control the brightness, but I don’t see an option to enable or disable the display as a whole.
I did start working on a lambda to control the brightness dynamically, but I didn’t go ahead with it in my project.
You could use some “simple” sensor, like PIR. Oled display is off in practice if you write empty page to it.
hmm if the laser is causing you problems, swap it out for a MMwave or PIR sensor that you know works with ESPHome?
If you want to power off the SSD1306, you’d need to figure a way to control the GPIO providing power/VCC.
This is entirely untested, but AI suggests this:
[AI generated code removed due to forum rules]
Hi @PharkieB,
thank you for the effort. AI generated code for Powershell and all sorts of other syntax is usually very helpful. Not true for ESPHome and Nunjucks. Please don’t provide untested code, as it is more confusing, then helping. :slight_smile:
I will think about testing the whole thing with an ESP32 board or switching to PIR or MMwave sensor.
It sounds like you might be asking two different questions.
  1. How do I turn off/on a ssd1306 display?
  2. Why is my ToF sensor returning NaN sometimes?
Don’t know that much about the display, but there are some posts about it and contrast is the key, set it to 0 and there is no display from what I recall.
I do have experience with the ToF sensors. My experience is that you get NaN when they don’t sense something. I have one in my grey water sump tank, but have not been impressed with it. It might be okay as a presence sensor, but I would use either a PIR or mmwave presence sensor. There are quite a few posts of people using both of those types of sensors. If you want to stick with the ToF sensor, use NaN to indicate you need to turn the display off.
Thank you for your input. Unfortunately, the sensor doesn’t recover from that state. You have to reboot. If you follow the two links above, they ‘solved’ it by automatically rebooting, as soon as nan values appear. Not a good option, if it reboots every other minute
I made a contrast change on OLED display. After sunset it is set to 1%, and during the day (at 10 AM) it changes to 20%:
  # Konfiguracja czujnika wewnetrznego skojarzonego z encja HA, ktora dostarcza poziom kontrastu
    name: "OLED Kontrast z HA"
    accuracy_decimals: 2
    entity_id: input_number.oled_contrast
    internal: true
    # Gdy zmieni sie wartosc encji w HA zmien kontrast wyswietlacza
    on_value:
      then:
        - lambda: |-
            float contrast_value = id(oled_contrast_from_ha).state;
            if (contrast_value >= 0.0 && contrast_value <= 1.0) {
              id(wyswietlacz_OLED).set_contrast(contrast_value);
              ESP_LOGD("OLED_contrast", "Kontrast ustawiony na %.0f%%", contrast_value * 100);
            } else {
              ESP_LOGW("OLED_contrast", "Niewlasciwa wartosc kontrastu: %.2f. Musi byc miedzy 0.0 a 1.0.", contrast_value);
I achieved this using the SUN integration in Home Assistant and the appropriate automation. The automation looks like this:
alias: OLED zmiana kontrastu
description: Wyƛwietlacz na piętrze
triggers:
  - trigger: time
    at: "10:00:00"
  - trigger: state
    entity_id:
      - sun.sun
    to: below_horizon
conditions: []
actions:
  - if:
      - condition: trigger
        id:
          - czas
    then:
      - action: input_number.set_value
          value: 0.2
    else:
          value: 0.01
mode: single
Below is the input_number configuration that I added to configuration.yaml, although it can also be done using the Helper. I will change this in the future because it seems that a new “{REST}” integration was added in the integrations, which is probably related to this code.
# Na potrzeby sterowania kontrastem wyswietlacza
input_number:
  oled_contrast:
    min: 0
    max: 1
    step: 0.01
    unit_of_measurement: '%'
Unfortunately setting contrast to 0 will not turn off the display but you can try “component.turn_off “ . I didn’t need it, so I didn’t test it and have no experience with it.
I am using Tasmota with the ToF sensor and it never needs a reboot, so must some difference in the driver code.
I would use a motion or presence sensor for your use case.
I did some more testing yesterday night. I have to admit that the soldering on my ToF sensor was - well - not very professional. :thinking: I have redone my soldering and now, no NAN values anymore. :partying_face: (Received values are very inaccurate, but I only need to know, if it falls below a certain value. At the moment, I don’t care about the actual value provided by the sonsor, as long as it is not drifting.)
For this project, I will probably keep the ToF-sensor, but I will keep in mind the PIR sensor.
Thank you all for providing inputs on how to activate/deactivate the display. I will work myself into it in the next nights.
So, after some thinking and some sleepless nights, I have finished my code.
Here is my example on how to turn on/off the display.
  • There is a start up page (-> on_boot) with some details about the device. (e.g. showing device name, IP-address and time)
  • There is page 1 showing the details, if value of the VL53L0x falls under a defined value.
  • There is page 2, showing, when the BME680 is calibrating.
yaml
# sources:
  # https://esphome.io/components/sensor/bme68x_bsec2.html
  # https://esphome.io/components/sensor/vl53l0x.html
  # https://esphome.io/components/display/ssd1306.html
# Variablen
substitutions:
esphome:
  platformio_options:
    build_flags:
  # Loop, der nach erfolgreicher WLAN-Verbindung und Zeitabfrage ausgefĂŒhrt wird und die Anzeige des Startseite regelt
  on_boot:
    then:
      # Zeige beim Start die Boot-Seite
      - lambda: 'id(ssd1306).show_page(id(page_boot));'
      # Warte auf gĂŒltige Zeit (sntp_time)
      - while:
          condition:
            not:
              lambda: 'return id(sntp_time).now().is_valid();'
          then:
            - delay: 1s
      # Berechne Boot-Zeitpunkt, sobald Zeit verfĂŒgbar ist
      - lambda: |-
          id(${node_name}_last_boot_time).publish_state( id(sntp_time).now().timestamp - (int) id(${node_name}_uptime_seconds).state );
      # Warte nun auf eine gĂŒltige IP
      - while:
          condition:
            not:
              lambda: 'return id(ip).has_state();'
          then:
            - delay: 1s
      # 5 Sekunden warten, bevor das Display ausgeschaltet wird
      - delay: 5s
      - lambda: |-
          id(ssd1306).show_page(id(page_empty));
          id(ssd1306).turn_off();
esp8266:
  board: d1_mini
# Enable logging
logger:
  level: DEBUG
#  level: VERY_VERBOSE
api:
  encryption:
    key: "p1ysJBCziWu7L..."
ota:
  - platform: esphome
    password: "68b666..."
wifi:
  manual_ip:
    dns1: 192.168.1.5
    dns2: 192.168.30.1
  domain: .internal
  ap:
    password: "ZpMn..."
captive_portal:
#web_server:
# port: 80
globals:
  - id: display_active
    type: bool
    restore_value: no
    initial_value: 'false'
# Fonts for use with display
font:
  - file: "gfonts://Lato"
    glyphsets:
      - GF_Latin_Kernel
    glyphs:
      ['Ä', 'Ă€', 'Ö', 'ö', 'Ü', 'ĂŒ', 'ĂŻ']
    glyphsets:
      - GF_Latin_Kernel
    glyphs:
  - file: "gfonts://Material+Symbols+Outlined" # https://fonts.google.com/icons
    glyphs:
      [ "\U0000e1ff", # icon "device_thermostat"
        "\U0000f87e", # icon "humidity_percentage"
        "\U0000efd8"  # icon "air"
    glyphs:
      [ "\U0000e627", # icon "sync"
        "\U0000e629", # icon "sync_problem"
        "\U0000e815", # icon "sentiment_very_satisfied"
        "\U0000e813", # icon "sentiment_satisfied"
        "\U0000e812", # icon "sentiment_neutral"
        "\U0000e811", # icon "sentiment_dissatisfied"
        "\U0000e814"  # icon "sentiment_very_dissatisfied"
time:
  - platform: sntp  # simple network time protocol
    timezone: Europe/Zurich
    servers:
      - ntp.metas.ch
      - ch.pool.ntp.org
      - 192.168.30.1
switch:
  - platform: restart
    name: '${friendly_name} neu starten'
i2c:
  sda: D2
  scl: D1
  scan: false
display:
    model: "SSD1306 128x64"
    reset_pin: D0
    address: 0x3C
    # show_test_card: true
    pages:
      - id: page_empty
        lambda: |-
          // clear display
      - id: page_boot
        lambda: |-
          it.print(0, 0, id(lato_12), "Startseite");
          it.strftime(127, 0, id(lato_12), TextAlign::TOP_RIGHT, "%H:%M", id(sntp_time).now());
          it.print(0, 13, id(lato_12), "${device_name}");
          it.printf(0, 25, id(lato_12), "IP: %s", id(ip).state.c_str());
      - id: page1
        lambda: |-
          it.print(0, 0, id(lato_12), "LuftqualitÀt");
          it.print(0, 13, id(icons_16), "\U0000e1ff");
          it.printf(17, 13, id(lato_16), "%.1f°C", id(bme680_temp).state);
          it.print(0, 30, id(icons_16), "\U0000f87e");
          it.printf(17, 30, id(lato_16), "%.0f%%", id(bme680_humidity).state);
          it.print(0, 47, id(icons_16), "\U0000efd8");
          it.printf(17, 47, id(lato_16), "%s", id(iaq_name).state.c_str());
          if ( int(id(iaq).state) <= 100) {
            it.printf(127, 0, id(icons_24), TextAlign::TOP_RIGHT, "\U0000e815");
            it.printf(127, 0, id(icons_24), TextAlign::TOP_RIGHT, "\U0000e813");
            it.printf(127, 0, id(icons_24), TextAlign::TOP_RIGHT, "\U0000e812");
            it.printf(127, 0, id(icons_24), TextAlign::TOP_RIGHT, "\U0000e811");
          else if (int(id(iaq).state) >= 251) {
            it.printf(127, 0, id(icons_24), TextAlign::TOP_RIGHT, "\U0000e814");
          else {
            it.printf(127, 0, id(icons_24), TextAlign::TOP_RIGHT, "\U0000e629");
      - id: page2
        lambda: |-
          it.printf(0, 0, id(lato_12), "Sensor: %s", id(iaq_state).state.c_str());
          it.printf(64, 32, id(icons_24), TextAlign::CENTER, "\U0000e627");
bme68x_bsec2_i2c:
  address: 0x77
  model: bme680
  operating_age: 28d
  sample_rate: ULP
  - platform: uptime
    name: '${friendly_name} Uptime Sekunden'
    internal: true
    name: '${friendly_name} Last Boot'
  - platform: vl53l0x
    name: '${friendly_name} VL53L0x Distanz'
    address: 0x29
    update_interval: 3s
    on_value:
      then:
        - if:
            condition:
              lambda: 'return (id(distance).state < 0.15) && (!id(display_active));'
            then:
              - lambda: 'id(display_active) = true;'  # Sperrvariable setzen
              - lambda: |-
                  id(ssd1306).turn_on();
                  if (id(iaq_state).state == std::string("Calibrated")) {
                    id(ssd1306).show_page(id(page1));
                  else {
                    id(ssd1306).show_page(id(page2));
              - delay: 15s  # 15 Sekunden lang anzeigen
              - lambda: |-
                  id(display_active) = false;
    temperature:
      name: '${friendly_name} Temperature'
    pressure:
      name: '${friendly_name} Pressure'
    humidity:
      name: '${friendly_name} Humidity'
    iaq:
    co2_equivalent:
      name: '${friendly_name} CO2 Equivalent'
      name: '${friendly_name} Breath VOC Equivalent original'
      internal: false
    name: '${friendly_name} Breath VOC Equivalent'
    lambda: |-
    name: '${friendly_name} Taupunkt'
    lambda: |-
text_sensor:
    iaq_accuracy:
      name: '${friendly_name} IAQ Accuracy'
    name: '${friendly_name} IAQ Classification'
    lambda: |-
        return {"gut"};
      else {
        return {"Fehler"};
  # Send IP Address
    ip_address:
      name: '${friendly_name} IP Address'
And for everybody, who does not like the Google Roboto font on a SSD1306 display, try the following fonts. I like those better, as letters stick to the base line and do not “jump around”.
For my curiosity, what’s the difference in practice between just displaying empty page and “turning off” display?
Hi @Karosm,
good question, I am not sure.
When playing around with it, I was showing several pages after each other, and triggered by different sensors. I had the effect, when the display was turned on that the last shown pages was visible for just a split second, before the actual page was shown. To prevent that, I empty the page before turning off the display. Now, no artefacts are there any more. (And I did this in the hope that it has an effect on energy consumption and in the hope to get rid of some of the log entries “display took longer then 30ms
Chris
I’m just thinking
 as this is an OLED display and not a backlit display, is the display not ‘off’ if all of the pixels are unlit?
I’ll test it on my bench with a multimeter later this week hopefully.
That was my point. Empty page should be pretty much off.
But I don’t know how much it draws while all pixels are off.
I typically find for most questions, someone has already done the work to figure it out and taken the time to write about it.
There is some savings for turning off the display. How much it matters is going to depend on the power source and duty cycle.
The table on that link shows that in most cases there are not.
I think it mainly depends on the LDO used on the display board and how the charge pump regulator is controlled.
thanks for the links to the fonts. It looks like the ones you selected are proportionally spaced, they look better but don’t typically work well for things that need to be in columns.
Top line is the roboto font. I don’t like the letters not being in the baseline. The other fonts don’t look better, but at least they don’t jump around. :wink:
