I’ve bought an Osram Smart+ Mini Switch, and I have successfully paired it with my home assistant (I am using the zha integration with the conbee Stick), however the only thing I get is a battery sensor and nothing else, and the battery state is even “unknown”.
How can I trigger actions from pressing one of the three buttons on the switch?
I have three of them. It was quite easy to pair them with my Conbee II stick (deconz docker).
Using the deconz_events is straight forward too, but after about half a day they all stop working. The green light at the switches stays off. I have to remove the batteries for about an hour then they are working again for the next few hours.
In the meantime I switched from deCONZ to mqtt + zigbee2mqtt. This seems to be more reliable and the Osram Smart+ Mini Switches keep their connection without draining the batteries.
Managed to get this working with zigbee2mqtt aswell, i didnt use the blueprints that are floating around the internet. Far easiser just using MQTT and you can get the battery % aswell:
Wonder if anyone can help me here… I have this exact switch, I have paired via my Sonoff UZB 3 and it seems to be functioning, but something very odd has happened
It seems to have automatically bound itself to a Zigbee bulb that I have (Innr), so that when I press up the bulb comes on and when I press down the bulb goes off - there is no automation for this device
Why would this happen? And more to the point, how can I stop it?!
