How to use RODRET blueprint to dim lights and change color temp?
Not sure how to configure the On - Hold action to increase brightness and the Off - Hold action to decrease brightness
On - Double press event to switch color temp and same with Off - Double press event
If you are having a problem with a specific Blueprint, the first point of contact is in the Exchange (or Github) post that you found the Blueprint in originally.
There are people there using the equipment and the blueprint and will be able to give you more accurate information regarding your problem.
You need to define the action. To decrease, use -XX%. It looks like this:
