Running hassio on a PI which has ffmpeg streams from a external DVR/CCTV. Added Sighthound which adds timestamped images with face recon into config/www/sighthound_images/. Have nofity alerting when a new file is created, all of the above works well.
Q. How can I view the contents of the folder config/www/sighthound_images/ or the last 4 images which are time stamped as followed sighthound_front_cctv_2020-05-22_17:52:17.jpg
Youâd have to create a local_file camera. Unfortunately, youâll need to initially use a âblankâ image file on startup. But each time a new file is created, calll the local_file_update_file_path service to update the path to the newest image on the camera.
Error loading /config/configuration.yaml: while scanning for the next token
found character â\tâ that cannot start any token
in â/config/configuration.yamlâ, line 311, column 28
