How to wire switch to dimmer (FS-05R)?
Hi, I received this wifi dimmer here but I’m not sure how to actually wire it to the wall switch.
From the manual, at least from the symbol, there’s power, brightness up and dimming.
Does it mean I need to use 3 gang switch like this?
Or could I still use with a 1 gang momentary switch (with 2 terminals)?
Hi Shaq,
So, a little advice. Do with it what you will…
  • We don’t know what country you are from or what your mains voltage is. Rules are different in every country and depending on different mains systems.
  • I would not feel comfortable asking a mains electrical question involving multiple switches like you are doing because random people will tell you random things.
  • I’m not going to tell you to not do that, but be very sure about what you end up doing, and use a meter / tester to make sure you do it right.
  • The best advice , however, might be this:
    :warning: DANGER OF ELECTROCUTION :warning:
If your device connects to mains electricity (AC power) there is danger of electrocution if not installed properly. If you don’t know how to install it, please call an electrician.
Beware: certain countries prohibit installation without a licensed electrician present
Remember: SAFETY FIRST. It is not worth the risk to yourself, your family and your home if you don’t know exactly what you are doing. Never tinker or try to flash a device using the serial programming interface while it is connected to MAINS ELECTRICITY (AC power).
I’m assuming that module is meant for a 3 gang retractive switch with up, down and power buttons.
This guy on reddit had the same problem - he found a switch but it was in a US size instead of EU size. https://www.reddit.com/r/homeautomation/comments/ymaezm/im_trying_to_find_a_3_button_dimmer_eu_standard/
Hopefully someone with more knowledge about switches will show up and be able to help you identify a compatible switch based on the link above. Good luck!
No you can’t.
An advise : Get Shelly Dimmer 2 and you can use whatever switch you already have.
Yeah, that looks like it’s designed for 3 buttons and similar to other tuya dimmer.
I could add tiny spring and make the switches retractable
Before that, do I get the wiring right for the switches? From the diagram it looks the neutral’s bridged with the switches
I’m no electrician, but the wiring diagram for the switch part on that module seems wrong.
I’d expect the diagram to connect the switches to Live, not Neutral, since switches are usually connected to live. The way you have drawn it is how they expect you to connect them, but that means you’d somehow have to rewire your switch feed in your consumer unit and hook it up to Neutral.
The whole thing seems a bit iffy - I’d either throw the damn thing away or at the very least, get a very good electrician. Like the others have said, don’t try this yourself.
EDIT: Confirmed in one of the reviews for an identical product.
Looks correct. Try it on the desk before you redo your house wiring.
Be aware that those dimmers don’t have any real certificates. If you burn your house, your insurance is not gonna cover it. Another reason to go with Shelly.
Well, i think I have a defect unit
I only wired the live and neutral and it’s not turning on, no led blinking or detected by tuya app
Will update again once i got the replacement
I’d have sent it back for refund & gotten a shelly dimmer personally.
Side note: in your first picture the instructions say that both input & output must be connected when testing. Maybe that’s why it’s not working.
I wonder what kind of circuit they have inside if they need output to work. I wouldn’t install that in my house even if they pay me…
Some person here discovered that the diagram requires momentary push switches. https://www.reddit.com/r/homeassistant/comments/17bnkvt/fs05r_zigbee_dimmer_anyone_used_it_with_zha/
The best solution I can think of right now is to replace their firmware with OpenBeken and then implement a low-voltage switch yourself using GPIO pins: https://www.elektroda.com/rtvforum/topic4027492-30.html
Yeah, this one uses gpio instead of tuya mcu for dimming. Swapped the beken chip with esp and added rotary encoder for dimming in tasmota.
Figured it would be easier with knob controls instead of button long press.
From that diagram, no. Completely wrong.
Here is my best guess:
(Excuse the wrong symbol for the light bulb. My library is not old enough to have incandescent light bulbs).
I got my FS-05R today, desoldered the CBS2 module, and managed to get esphome installed on it. I’ve now added two more low voltage wires to GPIO pins P23 and P6.
I’ve managed to get it to work! I’m sharing my ESPHome config here for others. I do not have a physical dimmer switch so I only wired up the dumb switch to P6 and P23. In order to adjust the brightness outside of the app, I set up the dumb switch to trigger a cycle between brightness settings if someone repeatedly toggles it within 5 seconds:
esphome:
  name_add_mac_suffix: false
  friendly_name: FS-05R Mini Dimmer Switch
  on_boot:
    priority: -10
    then:
      - globals.set:
            value: "true"
      - light.turn_off: out
bk72xx:
  board: cb2s
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret encryption_key
ota:
  - platform: esphome
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "FS-05R Fallback Hotspot"
    password: !secret fallback_hotspot
captive_portal:
globals:
  - id: brightness_index
    type: int
    restore_value: no
    initial_value: '0'
  - id: last_press_time
    type: unsigned long
    restore_value: no
    initial_value: '0'
  - id: boot_complete
    type: bool
    restore_value: no
    initial_value: "false"
# https://www.elektroda.com/rtvforum/topic4039890.html
status_led:
  pin:
    number: P8
    inverted: true
uart:
  rx_pin: RX1
  tx_pin: TX1
  baud_rate: 115200
  debug:
    direction: BOTH
time:
  - platform: sntp
    on_time_sync:
      then:
        - lambda: |-
            id(last_press_time) = id(sntp_time).now().timestamp;
output:
  - platform: gpio
    pin: P23
    type: float
    min_power: 0.0
    max_power: 1.0
    write_action:
      - uart.write:
          # https://www.elektroda.com/rtvforum/topic3880546.html
          data: !lambda |-
            uint8_t brightness_level = int(id(out).remote_values.get_brightness() * 255);
            uint8_t toggle_value = int(id(out).remote_values.is_on());
            // Calculate the value to send to the Tuya device
            uint16_t val = brightness_level * 3 * toggle_value;
            ESP_LOGD("fake_tuya", "Brightness: %d, Toggle: %d, val: %d", brightness_level, toggle_value, val);
            // Split the value into two bytes
            uint8_t high = (val >> 8) & 0xFF;
            uint8_t low = val & 0xFF;
            // Prepare TuyaMCU data packet
            // [0] 0x55       - Start byte
            // [1] 0xAA       - Second byte
            // [2] 0x00       - Protocol version or command type (can vary)
            // [4] 0x30       - Command type of package (content)
            // [5] 0x00       - The size of the packet`s data content in bytes (high)
            // [6] 0x03       - The size of the packet`s data content in bytes (low)
            // [7] 0x00       - Unknown
            // [8] high       - High byte of the calculated value (brightness * 3 * toggle_value)
            // [9] low        - Low byte of the calculated value
            // [10] checksum  - Checksum
            std::vector<uint8_t> data = {0x55, 0xAA, 0x00, 0x30, 0x00, 0x03, 0x00, high, low, 0x00};
            // Sum all bytes except the checksum itself (last byte)
            uint16_t sum = 0;
            for (size_t i = 0; i < data.size() - 1; ++i) {
              sum += data[i];
            // Take the result modulo 256 to get the checksum
            uint8_t checksum = static_cast<uint8_t>(sum % 256);
            data[data.size() - 1] = checksum;
            ESP_LOGD("fake_tuya", "High: %d, Low: %d, Checksum: %d", high, low, checksum);
            return data;
light:
  - platform: monochromatic
    restore_mode: ALWAYS_OFF
    default_transition_length: 0s
    output: fake_tuya
number:
    name: "Brightness Adjustment Interval"
    min_value: 0.0
    max_value: 10.0
    initial_value: 5.0
    step: 0.5
    unit_of_measurement: "s"
    restore_value: yes
    optimistic: true
    icon: "mdi:timer-sand"
    entity_category: config
binary_sensor:
  - platform: gpio
    pin: P7
    internal: true
    on_press:
      - script.execute: cycle
  - platform: gpio
    pin: P24
    internal: true
    on_press:
      then:
        - light.dim_relative:
            relative_brightness: -10%
  - platform: gpio
    pin: P26
    internal: true
    on_press:
      then:
            relative_brightness: 10%
  - platform: gpio
    pin:
      number: P6
      inverted: true
    internal: true
    filters:
      - delayed_on_off: 100ms
    on_state:
        - if:
            condition:
              - lambda: "return id(boot_complete);"
            then:
script:
  - id: cycle
    mode: restart
    then:
      if:
        condition:
          light.is_on: out
        then:
        else:
          - lambda: |-
              uint32_t current_time = id(sntp_time).now().timestamp;
              float cycle_interval = id(brightness_adjustment_interval).state;
              auto call = id(out).turn_on();
              // Check if the switch is pressed within the cycle interval
              uint32_t time_difference = current_time - id(last_press_time);
              if (time_difference < cycle_interval) {
                // Switch the brightness index
                id(brightness_index) = (id(brightness_index) + 1) % 4;  // Cycle through brightness levels
                // Set brightness based on the profile
                if (id(brightness_index) == 0) {
                  call.set_brightness(1.0);
                  ESP_LOGD("cycle", "Brightness set to 100%");
                } else if (id(brightness_index) == 1) {
                  call.set_brightness(0.66);
                  ESP_LOGD("cycle", "Brightness set to 66%");
                } else if (id(brightness_index) == 2) {
                  call.set_brightness(0.33);
                  ESP_LOGD("cycle", "Brightness set to 33%");
                } else {
                  call.set_brightness(0.15);
                  ESP_LOGD("cycle", "Brightness set to 15%");
              call.perform();
              ESP_LOGI("cycle", "Time difference: %lu seconds, Brightness index: %d", time_difference, id(brightness_index));
              // Update the last press time
              id(last_press_time) = current_time;
Note for others down the road, unshielded 3.3V wires near mains voltage can pick up interference, causing unstable readings or erratic behavior due to electromagnetic or capacitive coupling. To avoid this, keep 3.3V wires away from mains wiring—just a few centimeters of separation can make a big difference!
@nschimme:
Thanks for the configuration, it works like a charm! :smiley:
In my case I am controlling “Osram PAR16 Dimmable GU10 Spots”.
These go dark at about 25% brightness value.
Therefore I introduced an offset to your brightness formula, so that 0% will internally be output as 35% and added gamma correction:
//Shift brightness range to [<base> .. 100] % and adjust gamma
float   brightness_base = id(minimum_brightness).state;
float   brightness_mult = 255.0 / (1.0 + brightness_base);
float   gamma = id(dimming_gamma_value).state;
uint8_t brightness_level = int( (brightness_base + pow( id(out).remote_values.get_brightness(), gamma) ) * brightness_mult);
(Replaces the following line of your yaml: )
Added the following config entities to control minimum brightness and gamma:
number:
    name: "Minimum Brightness at Zero Percent"
    min_value: 0.0
    max_value: 1.0
    initial_value: 0.35
    step: 0.05
    unit_of_measurement: "%"
    restore_value: yes
    optimistic: true
    icon: "mdi:brightness-6"
    name: "Dimming Gamma Value"
    min_value: 0.0
    max_value: 4.0
    initial_value: 1.0
    step: 0.1
    unit_of_measurement: ""
    restore_value: yes
    optimistic: true
    icon: "mdi:gamma"
Nice! I ended up reworking my yaml some and added a more native way to set min/max brightness and gamma. I’ve posted the yaml on my blog at: Integrating the Tuya FS-05R WiFi Dimmer Switch with ESPHome | Nils Schimmelmann's Blog
