Hi @fspatt ,
thank you for your advice but it has not worked for me.
One thing i noticed, i could update PowerShell to a newer Version.
OOB it used WindowsPowerShell in Version 5.1 and now i’m using PowerShell 7.2.
Other point is, i’m on Win11 x64.
With the newer Version of PowerShell i don’t have an error after the shell command with the &.
Iritating is, that while pasting the shell command, the " are removed. Is this correct?
But i have stil lthe error: No frontmost application on Android Emulator 5554
On another different is, i have a newer Version of Android Studio:
Android Studio Bumblebee | 2021.1.1 Patch 1
Build #AI-211.7628.21.2111.8139111, built on February 1, 2022
Runtime version: 11.0.11+9-b60-7590822 amd64
VM: OpenJDK 64-Bit Server VM by Oracle Corporation
Windows 10 10.0
GC: G1 Young Generation, G1 Old Generation
Memory: 1280M
Cores: 24
Registry: external.system.auto.import.disabled=true
Hi Frank,
as you see in my log i got the command back after the display of this “table”.
Frida server is the same version. I also tried to update the frida tools itself.
Hi @Keules,
Im pretty new to HA. Just got ledvance integraded and would like to have the consumption too.
Could you explain how you imported the ledvance.yaml into your config?
When I integrate it in /packages I get the error: expected a dictionary for dictionary value @ data['packages']['ledvance']
When I integrate it separately I dont know which component I have to use.
I must admit i don’t really understand the whole concept: is it enough with just the “Local Tuya integration” or do you also need the “frida-server” running somewhere? Thanks!
How does these configurations translate to the latest update of home assistant?
The -platform does not seem to be used any more, so how will this be rewriten to work?
And I see others have asked the same thing but they did not really get any answer so how did you import your ledvance.yaml file into the configuration.yaml file?
