UPDATED AS PER 08/22 LEDVANCE integration - this is how to do it as per 08/22
I’ve had a few posts about LEDVANCE. You haven’t been able to integrate, except through a very weird setup with an Android emulator and all sorts of tricks.
LEDVANCE has now announced integration to SmartThings, and soon Homey integration will follow (currently there is no help from Home Assistant developers to integrate to LEDVANCE, if you want to make the direct integration, let me know, I’ll hook you up).
BUT as there is now SmartThings integration, we can circumvent the limitations somewhat: You don’t need the SmartThings Hub, ONLY the SmartThings app!
LEDVANCE → Integrate to SmartThings → Integrate to HA.
This is a weird and very roundabout way of doing it, but it works.
There are SOME challenges in speed of course, as we now go to a cloud service, that talks to another cloudservice.
This will impact speed. Mostly after a ‘sleep’ period, so the more LEDVANCE lights you have, the better, as it will not go to sleep ![]()
So the procedure in short is:
Add your light to the LEDVANCE app.
Log in to SmartThings, and add a new device by selecting the ‘Brand’ Ledvance Wifi+.
Then you can control your lights through the SmartThings App.
Then you follow the SmartThings integration steps to integrate SmartThings into HA.
You will then see your LEDVANCE lights in Home assistant!
There is a video in danish language available on how to do it here:
i did not follow all the steps but i did find the old print-local-keys.py with the correct credentials and got the information i needed. Although I’m not quite sure where the password fits
. The only way to recover is to unplug the lamp and turn it on again. No action on Hassio is required.
