HowTo Motion/Precence sensor TS0601 TZE204_no6qtgtl from TEMU
So, I have, about since they became available, two Aqara Motion Sensors (really budget-friendly at around €140 for both, if I remember correctly), but I don’t really like them, the feel, the handling — and honestly, in my opinion they’re prohibitively expensive for what they offer.
So when I was recently browsing TEMU and came across a deal for an RSH ZigBee 3.0 mmWave Radar sensor, including shipping, for acceptable €16.30, that triggered my intrest.
Well, for €16 — and considering TEMU’s refund policy — you can’t really go wrong.
So I went for it. Fast forward three weeks (after the thing literally took the scenic route on the Southern version of the Trans-Sib Railway through Kazakhstan), and it finally arrived.
I unboxed it, liked the look of it, liked the handling even more, powered it up, and connected it to ZHA.
It was stupidly easy.
ZHA detected the device—but only showed an LQI value and nothing else…
Dang.
So, I turned to Google and found this:
:link: https://community.home-assistant.io/t/zha-custom-quirk-to-work-with-tuya-ts0601-tze204-laokfqwu-occupancy-sensor/743184?u=mannebk
That pointed me in the right direction, and with help from this guide:
:link: https://community.home-assistant.io/t/zigbee-guide-how-to-add-setup-local-custom-zha-device-handlers-also-known-as-quirks-in-the-zha-integration/683473?u=mannebk
I implemented it. But the code from that thread didn’t work with my TS0601.
Again, from the first link above, I found this issue:
:link: https://github.com/zigpy/zha-device-handlers/issues/4070
And what can I say? The code from opa-gamert just works.
All credit to him — my only contribution was finding it.
Here’s the Python code you need to zuGutenberg (paste, for the non-Germans :slightly_smiling_face:) into your quirk file:
import logging
from typing import Final
from zigpy.quirks.v2 import QuirkBuilder, BinarySensorDeviceClass
import zigpy.types as t
from zigpy.zcl.foundation import ZCLAttributeDef
from zhaquirks.tuya import (
    TuyaLocalCluster,
    TuyaPowerConfigurationCluster2AAA,
from zhaquirks.tuya.mcu import TuyaMCUCluster, DPToAttributeMapping
from zigpy.quirks.v2.homeassistant import EntityPlatform, EntityType
_LOGGER = logging.getLogger(__name__)
class PresenceState(t.enum8):
    none = 0x00
    presence = 0x01
    peaceful = 0x02
    small_movement = 0x03
    large_movement = 0x04
class HumanPresenceSensorManufCluster(TuyaMCUCluster):
    """Custom Tuya cluster for _TZE204_no6qtgtl human presence sensor."""
    cluster_id = 0xEF00
    class AttributeDefs(TuyaMCUCluster.AttributeDefs):
        presence_state: Final = ZCLAttributeDef(
            id=0x0001, type=t.uint8_t, access="rp", is_manufacturer_specific=True
        near_detection: Final = ZCLAttributeDef(
            id=0x0003, type=t.uint16_t, access="rp", is_manufacturer_specific=True
        far_detection: Final = ZCLAttributeDef(
            id=0x0004, type=t.uint16_t, access="rp", is_manufacturer_specific=True
        target_distance: Final = ZCLAttributeDef(
            id=0x0009, type=t.uint16_t, access="rp", is_manufacturer_specific=True
        static_sensitivity: Final = ZCLAttributeDef(
            id=0x0065, type=t.uint8_t, access="rp", is_manufacturer_specific=True
        motion_sensitivity: Final = ZCLAttributeDef(
            id=0x0066, type=t.uint8_t, access="rp", is_manufacturer_specific=True
        # lighting_mode verwijderd
    dp_to_attribute: dict[int, DPToAttributeMapping] = {
        1: DPToAttributeMapping(TuyaMCUCluster.ep_attribute, "presence_state", converter=PresenceState),
        3: DPToAttributeMapping(TuyaMCUCluster.ep_attribute, "near_detection"),
        4: DPToAttributeMapping(TuyaMCUCluster.ep_attribute, "far_detection"),
        9: DPToAttributeMapping(TuyaMCUCluster.ep_attribute, "target_distance"),
        101: DPToAttributeMapping(TuyaMCUCluster.ep_attribute, "static_sensitivity"),
        102: DPToAttributeMapping(TuyaMCUCluster.ep_attribute, "motion_sensitivity"),
        # 103 verwijderd
    data_point_handlers = {
        1: "_dp_2_attr_update",
        3: "_dp_2_attr_update",
        4: "_dp_2_attr_update",
        9: "_dp_2_attr_update",
        101: "_dp_2_attr_update",
        102: "_dp_2_attr_update",
        # 103 verwijderd
# Build the quirk
    QuirkBuilder("_TZE204_no6qtgtl", "TS0601")
    .skip_configuration()
    .replaces(TuyaPowerConfigurationCluster2AAA)
    .adds(HumanPresenceSensorManufCluster, endpoint_id=1)
    .binary_sensor(
        "presence_state",
        HumanPresenceSensorManufCluster.cluster_id,
        endpoint_id=1,
        device_class=BinarySensorDeviceClass.OCCUPANCY,
        fallback_name="Presence",
        translation_key="occupancy",
    .enum(
        HumanPresenceSensorManufCluster.AttributeDefs.presence_state.name,
        PresenceState,
        endpoint_id=1,
        entity_platform=EntityPlatform.SENSOR,
        entity_type=EntityType.STANDARD,
        fallback_name="Presence State",
        translation_key="presence_state",
    .number(
        HumanPresenceSensorManufCluster.AttributeDefs.target_distance.name,
        endpoint_id=1,
        step=1,
        min_value=0,
        max_value=1000,
        fallback_name="Target Distance (cm)",
        translation_key="target_distance_cm",
    .number(
        HumanPresenceSensorManufCluster.AttributeDefs.near_detection.name,
        endpoint_id=1,
        step=1,
        min_value=0,
        max_value=1000,
        fallback_name="Near Detection (cm)",
        translation_key="near_detection_cm",
    .number(
        HumanPresenceSensorManufCluster.AttributeDefs.far_detection.name,
        endpoint_id=1,
        step=1,
        min_value=0,
        max_value=1000,
        fallback_name="Far Detection (cm)",
        translation_key="far_detection_cm",
    .number(
        HumanPresenceSensorManufCluster.AttributeDefs.motion_sensitivity.name,
        endpoint_id=1,
        step=1,
        min_value=0,
        max_value=10,
        fallback_name="Motion Sensitivity",
        translation_key="motion_sensitivity",
    .number(
        HumanPresenceSensorManufCluster.AttributeDefs.static_sensitivity.name,
        endpoint_id=1,
        step=1,
        min_value=0,
        max_value=10,
        fallback_name="Static Sensitivity",
        translation_key="static_sensitivity",
    # .switch voor lighting_mode verwijderd
    .add_to_registry()
Unfortunatly, I cant offer you a Link to the product, TEMU says its sold out… I would have loved to buy some more…
If I happen to find them again, Ill put the link in here.
Cheerse
Manne
Tnx for the credits, i got mine from ali from this shop
https://a.aliexpress.com/_EHmZf5W
Always arround 16 euro
Hey Opa-gamert. Zou graag in kontakt komen over de Bluetooth esp-home firmware. Heb wat vragen en zou graag aan het project mee werken.
Groet Frank
thanks to both! it works perfectly. do you know if this sensor has the light and temperature sensor?
mine does not. Just motion and presence, so its providing in
presence: none, still and motion
motion: free or motion
and a distance to target, that does not really make any sense to me
