ZHA custom quirk to work with Tuya TS0601 TZE204_laokfqwu occupancy sensor
I recently bought a ZigBee MmWave Human Presence Motion Sensor With Luminance/Distance Detection from AliExpress. ZHA did not recognize this model so I had no sensors. Being very new to HA but with some coding experience and after a lot of trial and error I was able to come up with a quirks file that works. Heavily based on the this post -
https://github.com/zigpy/zha-device-handlers/pull/1928
Not sure if this is the right place to post it, but I thought it might be useful for others struggling with the same issue.
import math
from typing import Dict, Optional, Tuple, Union
from zigpy.profiles import zgp, zha
from zigpy.quirks import CustomDevice
import zigpy.types as t
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import (
    AnalogInput,
    AnalogOutput,
    Basic,
    GreenPowerProxy,
    Groups,
    Identify,
    Ota,
    Scenes,
    Time,
from zigpy.zcl.clusters.measurement import (
    IlluminanceMeasurement,
    OccupancySensing
from zigpy.zcl.clusters.security import IasZone
from zhaquirks import Bus, LocalDataCluster, MotionOnEvent
from zhaquirks.const import (
    DEVICE_TYPE,
    ENDPOINTS,
    INPUT_CLUSTERS,
    MODEL,
    MOTION_EVENT,
    OUTPUT_CLUSTERS,
    PROFILE_ID,
from zhaquirks.tuya import (
    NoManufacturerCluster,
    TuyaLocalCluster,
    TuyaNewManufCluster,
from zhaquirks.tuya.mcu import (
    # TuyaDPType,
    DPToAttributeMapping,
    TuyaAttributesCluster,
    TuyaMCUCluster,
class TuyaMmwRadarSelfTest(t.enum8):
    """Mmw radar self test values."""
    TESTING = 0
    TEST_SUCCESS = 1
    TEST_FAILURE = 2
    OTHER = 3
    COMM_FAULT = 4
    RADAR_FAULT = 5
class TuyaOccupancySensing(OccupancySensing, TuyaLocalCluster):
    """Tuya local OccupancySensing cluster."""
class TuyaIlluminanceMeasurement(IlluminanceMeasurement, TuyaLocalCluster):
    """Tuya local IlluminanceMeasurement cluster."""
class TuyaMmwRadarSensitivity(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for sensitivity."""
    def __init__(self, *args, **kwargs):
        """Init."""
        super().__init__(*args, **kwargs)
        self._update_attribute(
            self.attributes_by_name["description"].id, "Sensitivity"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 1)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 9)
        self._update_attribute(self.attributes_by_name["resolution"].id, 1)
class TuyaMmwRadarMinRange(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for min range."""
        """Init."""
            self.attributes_by_name["description"].id, "Min range"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 0)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 950)
        self._update_attribute(self.attributes_by_name["resolution"].id, 10)
            self.attributes_by_name["engineering_units"].id, 118
        )  # 31: meters
class TuyaMmwRadarMaxRange(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for max range."""
        """Init."""
            self.attributes_by_name["description"].id, "Max range"
        )  # 31: meters
class TuyaMmwRadarDetectionDelay(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for detection delay."""
        """Init."""
            self.attributes_by_name["description"].id, "Detection delay"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 000)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 20000)
        self._update_attribute(self.attributes_by_name["resolution"].id, 100)
            self.attributes_by_name["engineering_units"].id, 159
        )  # 73: seconds
class TuyaMmwRadarFadingTime(TuyaAttributesCluster, AnalogOutput):
    """AnalogOutput cluster for fading time."""
        """Init."""
            self.attributes_by_name["description"].id, "Fading time"
        self._update_attribute(self.attributes_by_name["min_present_value"].id, 0000)
        self._update_attribute(self.attributes_by_name["max_present_value"].id, 200000)
        self._update_attribute(self.attributes_by_name["resolution"].id, 1000)
        )  # 73: seconds
class TuyaMmwRadarTargetDistance(TuyaAttributesCluster, AnalogInput):
    """AnalogInput cluster for target distance."""
        """Init."""
            self.attributes_by_name["description"].id, "Target distance"
            self.attributes_by_name["engineering_units"].id, 31
        )  # 31: meters
class TuyaMmwRadarCluster(NoManufacturerCluster, TuyaMCUCluster):
    """Mmw radar cluster."""
    attributes = TuyaMCUCluster.attributes.copy()
    attributes.update(
            # ramdom attribute IDs
            0xEF01: ("occupancy", t.uint32_t, True),
            0xEF02: ("sensitivity", t.uint32_t, True),
            0xEF03: ("min_range", t.uint32_t, True),
            0xEF04: ("max_range", t.uint32_t, True),
            0xEF06: ("self_test", TuyaMmwRadarSelfTest, True),
            0xEF09: ("target_distance", t.uint32_t, True),
            0xEF65: ("detection_delay", t.uint32_t, True),
            0xEF66: ("fading_time", t.uint32_t, True),
            0xEF67: ("cli", t.CharacterString, True),
            0xEF68: ("illuminance", t.uint32_t, True),
    dp_to_attribute: Dict[int, DPToAttributeMapping] = {
        1: DPToAttributeMapping(
            TuyaOccupancySensing.ep_attribute,
            "occupancy",
            # dp_type=TuyaDPType.BOOL,
        2: DPToAttributeMapping(
            TuyaMmwRadarSensitivity.ep_attribute,
            "present_value",
            # dp_type=TuyaDPType.VALUE,
        3: DPToAttributeMapping(
            TuyaMmwRadarMinRange.ep_attribute,
            "present_value",
            endpoint_id=2,
            #converter=lambda x: x / 100,
            #dp_converter=lambda x: x * 100,
        4: DPToAttributeMapping(
            TuyaMmwRadarMaxRange.ep_attribute,
            "present_value",
            endpoint_id=3,
        6: DPToAttributeMapping(
            TuyaMCUCluster.ep_attribute,
            "self_test",
            # dp_type=TuyaDPType.ENUM,
        9: DPToAttributeMapping(
            TuyaMmwRadarTargetDistance.ep_attribute,
            "present_value",
        101: DPToAttributeMapping(
            TuyaMmwRadarDetectionDelay.ep_attribute,
            "present_value",
            dp_converter=lambda x: x // 100,
            endpoint_id=4,
        102: DPToAttributeMapping(
            TuyaMmwRadarFadingTime.ep_attribute,
            "present_value",
            endpoint_id=5,
        103: DPToAttributeMapping(
            TuyaIlluminanceMeasurement.ep_attribute,
            "measured_value",
            converter=lambda x: int(math.log10(x) * 10000 + 1) if x > 0 else int(1),
    data_point_handlers = {
        1: "_dp_2_attr_update",
        2: "_dp_2_attr_update",
        3: "_dp_2_attr_update",
        4: "_dp_2_attr_update",
        6: "_dp_2_attr_update",
        9: "_dp_2_attr_update",
        101: "_dp_2_attr_update",
        102: "_dp_2_attr_update",
        103: "_dp_2_attr_update",
class TuyaMmwRadarOccupancy(CustomDevice):
    """Millimeter wave occupancy sensor."""
    signature = {
        #  endpoint=1, profile=260, device_type=81, device_version=1,
        #  input_clusters=[0, 4, 5, 61184], output_clusters=[25, 10]
        "models_info": [
            ("_TZE200_ar0slwnd", "TS0601"),
            ("_TZE200_sfiy5tfs", "TS0601"),
            ("_TZE200_mrf6vtua", "TS0601"),
            ("_TZE200_ztc6ggyl", "TS0601"),
            ("_TZE204_ztc6ggyl", "TS0601"),
            ("_TZE204_laokfqwu", "TS0601"),
        ENDPOINTS: {
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TuyaNewManufCluster.cluster_id,
                OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
            242: {
                # <SimpleDescriptor endpoint=242 profile=41440 device_type=97
                # input_clusters=[]
                # output_clusters=[33]
                PROFILE_ID: zgp.PROFILE_ID,
                DEVICE_TYPE: zgp.DeviceType.PROXY_BASIC,
                INPUT_CLUSTERS: [],
                OUTPUT_CLUSTERS: [GreenPowerProxy.cluster_id],
    replacement = {
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.OCCUPANCY_SENSOR,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TuyaMmwRadarCluster,
                    TuyaIlluminanceMeasurement,
                    TuyaOccupancySensing,
                    TuyaMmwRadarTargetDistance,
                    TuyaMmwRadarSensitivity,
            2: {
                DEVICE_TYPE: zha.DeviceType.COMBINED_INTERFACE,
                INPUT_CLUSTERS: [
                    TuyaMmwRadarMinRange,
                OUTPUT_CLUSTERS: [],
            3: {
                INPUT_CLUSTERS: [
                    TuyaMmwRadarMaxRange,
            4: {
                INPUT_CLUSTERS: [
                    TuyaMmwRadarDetectionDelay,
            5: {
                INPUT_CLUSTERS: [
                    TuyaMmwRadarFadingTime,
Main differences with original quirks file:
  • added model number to models_info
  • added endpoint 242 and import zgp
  • changed dp_to_attribute 104 to 103 for luminance sensor
  • changed x to be 1 when not > 0 in convertor for luminance
So far the sensor is working well. I am able to detect presence and luminance and change settings using HA.
i have the same model as you and got it from aliexpress. can you help me understand where to put the code and how to put it? thank you
See:
@bakernigel Nice but please submit the new quirk code as either a pull request or issue (device request) to the ZHA Device Handlers repository on GitHub → GitHub - zigpy/zha-device-handlers: ZHA device handlers bridge the functionality gap created when manufacturers deviate from the ZCL specification, handling deviations and exceptions by parsing custom messages to and from Zigbee devices.
See GitHub guides about creating pull requests:
Best is if you post/ask such question as a new issue(s) to the zha-device-handlers repository on GitHub:
ZHA Device Handlers repository is otherwise primarly used for quirks bugs and feature requests, see:
PS: Also be aware ZHA developers are working on a new ZHA-Quirks V2 architectural:
I don’t understand how to do it. can you insert step by step how to do it?
@githubsharezone I already posted a link above to a step-by-step community guide, read and follow that here → Zigbee Guide: How-to setup local custom device handler quirks in ZHA integration
nothing I do not understand … how to do it … forgive me I may be too hard-headed
i try but on check i have this warninf
Configuration warnings
Invalid config for ‘zha’ at configuration.yaml, line 51: not a directory for dictionary value ‘zha->custom_quirks_path’, got ‘/config/zha_quirks/’
i success with remove “/” but inegration not function
Everything working nice here, applying the quirk, but i have a problem, when i try to adjust the values controls ( like Max range and Min Range) the numbers goes where i want but after a few seconds come back to 0 value. i did the full restart of HA before applied the quirk by the way.
Regards
I am having the same issue. Detection delay, Fading time both immediately revert back to 0. Min and Max range, as well as Sensitivity seem to stay put though.
I’m seeing the same, but I get an additional error in the GUI
Failed to perform the action number/set_value. Failed to convert attr_value=130.0 from type <class ‘zigpy.types.basic.Single’> to int | str
Since October/24 update I am having the same issue
same here. Looking at the code, it seems like something broke in TuyaAttributesCluster from ZHA itself.
Alas today’s HA upgrade did not fix it.
2024.12 update fixed it!
Now the issue is different here. When I change any of the sensor settings, it reverts immediately (or after a while) to the default (I guess) settings.
Does anyone have a clue on how to fix this?
Update on my issue. It seems to be affecting “fading time” only… These quirks are so unstable :frowning:
Yes, fading time still seems buggy. I could reduce it but not set it back. Not sure what it does anyway. Range settings can now set and will used correctly which was the most important for me.
Works for MOES ZSS-QY-HP
        ("_TZE204_fwondbzy", "TS0601"),
but can’t get “target_distance” value and “self test values”
[danpeig] uploaded a .py in the latest post that works for me.
I guess this will later be implemented in: zha-device-handlers/zhaquirks/tuya/ts0601_motion.py at e3d3849ffdd74b809713f9f154172ddad329aad9 · zigpy/zha-device-handlers · GitHub
Hopes this also helps you!
