Howto: Xiaomi vacuum zoned cleaning
Right I see!
Apologies for all the questions as I am fairly new with the Xiaomi vacuum. I have just ordered the roborock v2 and it’s on its way to me.
Have you got any tips for setting it up or things which I should avoid whilst setting it up?
I will definitely try your zoning method and getting HA to clean a specific room of choice.
Thanks.
Don’t move the station/robot around since that will mess up your map. It seems to work best if you have it sitting in a corner, so if the map gets corrupted, it always starts the new map exactly like the old one :slight_smile:
So I move it once I have set up your method and clean individuals zones like you described?
If you move the robot (not the station), e.g. by carrying it around, it will still think that it’s at its old position when you turn it on. This can be “fixed” though by letting the robot build a new map from the station (by starting a new cleaning task from the station). But if you move the station, the starting point of the map (which is in front of the station) will still be [25500,25500], but is then a different location on your map - then you would have to go through the entire process again, yes. The zones might just be shifted according on how much you moved the station, but it’ll be a hassle anyway ;). So better decide where to set up the station before getting all the coordinates :wink:
@Cib it was really good if you made a video , how we can draw a map and all the process. what do you think about that?
I measured in my home and mm seems right.
I.e. 1 “Xiaomi Unit” == 1 mm.
Use the “app_goto_target” command and see where the point is in the Xiaomi app. I.e. no need to wait for the vacuum to actually get there.
The same works for zones, test sending a zone via HA and see what it looks like in the app. Then modify accordingly.
Hi @ciB, great post.
I have a doubt: You mention you have your v2 vacuum registered on europe server. I’ve tried a time ago, but it was not possible for me. Registering on china mainland worked. Do you know if it’s a new feature, or did you do some trick to register it?
Thanks!
My app is set to Europe, and if I press the “+” in the top right it shows me a list 9 items that are sold in europe, including the “Roborock Vacuum” which is the v2. No other vacuum is listed, for that you would have to switch to Mainland China.
It does not really matter though which region you have set it to, so if Europe does not work for you just use China instead.
Ok, I will give it a try. The main issue I see when working with MiHome app are the delays. It’s very slow to get information from the vacuum (status, map, etc.). An I often get timeouts messages. So that’s the reason I want to try on Europe’s server
Great write up! Thank you ciB!
I found a cool thing that you can do when you can send it to a predetermined spot. I was trying to make the vacuum cross a threshold it was struggling with. I then noticed that if you go backwards using the command velocity (-x) it helps a lot. So, if you go to the spot where the threshold is, make a 180 degree turn by:
  - service: vacuum.xiaomi_remote_control_move_step
      entity_id: vacuum.dammsugare
      velocity: "0"
      rotation: "115"
…then back up using:
      velocity: "-0.29"
      duration: "6000"
It can now get places it couldn’t before.
Now, I only need to string all the steps together. Can you make a script wait for a previous step to have completed? That is, not just a time delay, but when the vacuum is actually finished with the last step?
Yes, that should be possible. The robot has a status depending on what it is doing right now. E.g, if you send it to a specif spot the status is “going to target”, then, once it reached the target, the new status is “idle”. Once the status updates to idle, you could then send a new command.
So basically if you want the vacuum to clean a room that you need to enter via your trick, you could start the script by sending him to the spot that you need him to go (infront of the ridge) and activate an automation that waits for the status to change to “idle”. Once the robot reaches the spot (status goes to idle), you call a new script through that automation that then starts your sequence for going over the ridge backwards and that also turns off that automation again and turn on another one. The 2nd automation starts the cleaning process in that area when your vacuum is idle again. That automation also turns itself off again. Makes any sense?
Yes. I actually started to implement something very much like that solution, but it fast became very muddy.
Since the action after “idle” (or ‘going back to dock’ after the cleaning) is different every time I have to use an input_number to keep track at what step the vacuum is at. Then the whole jinja if else machinery. It is doable, but it’s very hack-ish and cumbersome.
So I put that on hold and tried to use a python script instead. Given how new I am to python that will take some time. But if I could use something like:
hass.services.call('vacuum', 'send_command', 'entity_id': 'vacuum.dammsugare', 'command':'app_goto_target', 'params':'[23350,23600]')
if N == 100:
    if hass.states.get(vacuum.dammsugare) == 'idle':
        break
    time.sleep(7)
	N = N+1
…instead, then a lot of complications could be avoided. Ideally I would like to just get a callback to the python script but, I don’t know how you do that.
I’m new at this, the code above is probably wrong in more ways than one, but do you think that it could lead somewhere?
I don’t think that it would be that complicated to do with automations (depending on your acutal needs). You can DM me and I can try to tinker a solution for you. Doing it with a python script would work similarily, but keep in mind that you would have to start a loop for checking the condition, since you would never know when to actually call the python script:
while hass.states.get(vacuum.dammsugare) != 'idle':
  do nothing
What you could also try is Node-RED, maybe thats easier, but I just started looking into that myself.
I didn’t manage to get very far with the python script. I couldn’t even get the test case of:
hass.services.call('vacuum', 'locate', { 'entity_id': 'vacuum.dammsugare' })
For curiosities sake, why does that not work?
I then revisited the original plan and I found the wait command, which I missed the first time. So now it looks something like:
  vaccum_barnrum_go_and_clean_and_go_home:
    alias: "Go to childrens room, clean and then go home"
      # Go to starting point in the kids room
      - service: vacuum.send_command
          command: app_goto_target
          params: [23350,23600]
      #Wait untill done
      - wait_template: "{{ states.vacuum.dammsugare.attributes.status == 'Idle'}}"
          entity_id: input_number.vaccum_progress
          value: 1
      - delay: '00:00:30'
      #clean room
          command: app_zoned_clean
          params: [[20613,19502,24163,25002,1]]
      #Wait untill done
      - wait_template: "{{ states.vacuum.dammsugare.attributes.status == 'Returning home'}}"
          value: 2
      - delay: '00:00:05'
      #Stop going home
      - service: vacuum.stop
…and it goes on. It becomes pretty long when you have to specify each step.
This seems to work well, but It needs a bit more polish. The input_number is just for debugging.
So it seems I got it under control for now, but I do thank you for your kind offer of assistance.
TBH, I don’t know why your service call does not work…to my understanding that’s how it should work :face_with_raised_eyebrow:
there is kinda error in your manual.
you suggest:
Download a modified Mi Home app from this 13 russian website. (Direct Link v.**5.1.29** 15)
Xiaomi Mi Robot Vacuum telling that:
As per python-miio issue 185 the Mi-Home app no longer stores the token within the database (it’s retrieved from Xiaomi servers from version **5.0.31**+).Currently the only known fix is to uninstall, then install a downgraded version of the apk. Apkmirror is a trusted source for older versions of the app. Mi-Home version 5.0.0 is confirmed as working for the following Android methods.
so… why should i download this russian modified apk?
Because the modified Mi Home app let’s you read the token from within the app :wink:
Only the original Mi home app, to which the HA documentation is referring to, does not store the token anymore.
So I got my roborock today done the first clean went very well.
I was trying to use the mop feature and the vacuum threw an error saying it’s stuck and it wouldn’t move. I didn’t place anything on the floor. I am not home now and the roborock is sleeping in the position it got stuck.
Do you think it’s because of the mop as it has added extra layer to the roborock and got stuck?
Any tips on how to avoid the roborock from getting stuck?
I don’t know why your robot got stuck in your specific case, but it should not be the mop’s fault unless you are going over carpets. In my experience so far my robot got stuck on cables, a water bottle fell over and blocked its way back out of a narrow passage. And it once got stuck on a sock :wink: so yeah, make sure there are not objects lying on the ground that could entangle the robot.
Mine gets stuck when mopping because the wheels start slipping on the wet floor!
