Just got the vacuum today. Before integrating with HASS I am trying to make it work.
Currently I use Chinese server in Mi Home app (at the very beginning was the only way to put it in developer mode and integrate Xiaomi sensors in HASS), now after adding the Vacuum it says to change to local server (I am in Europe), but if I do I loose all Xiaomi other devices.
How do i use the services call to send a goto command?
Tried like vacuum.send_command
Than input
âentity_idâ: âvacuum.roombaâ,
âcommandâ: âapp_goto_targetâ,âparamsâ:"[26700,26800]"
Nothing happens. Although the same stuff with command:app_zoned_clean and params [[26600,21800,28727,26800,1]]
initiates the zone cleaning⌠Using the v2 roborock
Thanks for this post, I started it and it works perfectly.
A question⌠my robot is not going straight, when I start a zoned cleanup it re-draws the map and moves it a bit⌠any idea ?
Can it be because some doors are not fully opened so its referential changes ?
And do you know the command to turn it off once the cleanup is done ?
!!!PLEASE DONT UPGRADE VACUUM FIRMAWARE IF OLD SETUP WORKS! XIAOMI IS EVENTUALLY CHANGING SOME STUFF AND ROBOT CANT BE ROOTED AFTER ! So please hold on for upgrading.of not this forum will be flooded with those messages like: Cantrell root my robot etc
U might want to join the dustcloud discord server âŚthey discuss a lot âŚthere will be another release from valetudo with zoned cleaning via selection on map feature hit stay tuned âŚnot released yet
for the Map indeed zoned cleaning works without rooting but I disconnected the robot from the internet. I donât like it if no matter who collects data about me
Ah ok, so zone cleaning from HA doesnât work if not connected to internet? How do you disable internet anyway on the vacuum? There are no gateway or dns settings? Or do you block it on your firewall/router?
No NO NO ! U got me wrong⌠to get the MAP of the Robot u need root. How I cut the internete for the robot? : Blocked the internet access on my router for this MAC and IP
First it looks nice .You see the difficulties fir the robot in your flat/house Appartment⌠Aaaaaaand I need this map as thereâs something being developed to make zone cleaning directly by defining an area on a map ⌠hosted on the vacuum itself âŚfor this install u need root
Does anyone know if the original suppled by @ciB or subsequent instructions will work with the amazon echo? I am happy to set it up with HA and integrate to echo, but would like to enjoy custom requests.
