Howto: Xiaomi vacuum zoned cleaning
como vc conseguiu as coordenadas?
I downloaded the app from the Russian website.
I’ve installed it and re-added the robot (I think mine is the xiaomi robot v1). I can’t see any option for network info under general settings. What am I doing wrong?
Is it advalible in it?
If you dont understand russian - i can help.
The app is English and the Russian website gets translated by Google so no problem from that point of view, thanks
i have 2-nd gen of robot bit now it’s under valetudo - so it dont work with xiaomi cloud
Hello, I have a viomi.vacuum.v8 vacuum, I have tried the FloleVac app with login to EU server, but it says it can’t retrieve the data.
How I use the manual setup from FloleVac app?
I had this issue once too, I reinstalled the app and that helped…
I use these instructions to zone clean my apartment.
I have some chairs which are a problem for the mi Vacuüm. So I made a map which excludes these chairs.
Sometime this is going okay. But not always.
The vacuum is lost totally and cleans only one room or so.
After a full clean of the whole appartement, the next time I do a zoned cleaning, which excluding the chairs, it is going okay again.
I really don’t know where to start troubleshooting with this.
Can you guys please help me with this?
I was looking exactly for this. The problem is that the vacuum integration of home assistant itself does not support ā€œzone cleaningā€, so we’d have to do some development there first to support the zone trait for vacuums in google assistant.
what i ended up doing was my own custom hack: i copy pasted the google_assistant component in the config/custom_component folder and did the following changes:
diff google_assistant/trait.py ../homeassistant/components/google_assistant/trait.py
538,549d537
<     zones = {"Bedroom Corridor": [16],
<              "Kitchen": [17],
<              "Dining Room": [18],
<              "Entrance": [20],
<              "Master Bedroom": [21],
<              "Living Room": [22],
<              "Study Room": [25],
<              "Carpet": [26],
<              "Living areas": [17, 18, 20, 22, 26],
<              "Bedroom areas": [16, 19, 21, 24]}
558d545
<         _LOGGER.info("Registering vacuum in google assistant with zones: %s", str(list(self.zones.keys())))
562,563c549
<             != 0,
<             "availableZones": list(self.zones.keys())
>             != 0
577,596c563,569
<                 if params["zone"]:
<                     _LOGGER.info("Vacuum start zone command received with zone: '%s'", params["zone"])
<                     _LOGGER.info("Sending app_segment_clean command to vac with zone IDs: '%s'", str(self.zones[params["zone"]]))
<                     await self.hass.services.async_call(
<                         self.state.domain,
<                         vacuum.SERVICE_SEND_COMMAND,
<                         {ATTR_ENTITY_ID: self.state.entity_id,
<                          "command": "app_segment_clean",
<                          "params": self.zones[params["zone"]]},
<                         blocking=True,
<                         context=data.context,
<                 else:
<                         vacuum.SERVICE_START,
<                         {ATTR_ENTITY_ID: self.state.entity_id},
<                         blocking=True,
>                     self.state.domain,
>                     blocking=True,
as far as hacks go, this is a pretty dirty one as it is forcing your custom zones directly into the google assistant vacuum support trait, but hey - it works. now i can tell google assistant ā€œstart cleaning in the kitchenā€ or ā€œstart cleaning the living areasā€ without all the script and IFTTT hackery suggested by the op above.
Some dev who has time should definitely try to add zone support to HA’s vacuum integration and then add zone support to the google assistant integration. PLEASE :slight_smile:
Yes, I played before with code changed too, I also had zone cleaning working… Allthough I use nabucasa… And that’s not possible to load as custom :frowning:
I don’t want to use the local Google anymore
Btw, what are those numbers, like 17, 18 … ?
I guess you don’t have an s50? Some other model that supports rooms?
I have an s50, I need to work with coordinates… Don’t think my model supports rooms
Yes, S50 with latest firmware now supports rooms.
These are room IDs. Here’s how you retrieve them:
Thnx for info… Now we need Google supporting those :wink:
Who can create a PR for this? :wink:
I am using Room/segmented Cleaning and although pause works - vacuum.start starts a brand new clean house cycle - so current room clean is ignored ?
Is anyone else having this issue - I have a card setup with pause and a start clean button.
service: vacuum.pause & service: vacuum.start
In zone cleaning - pause and then sending vacuum.start works to resume the cleaning where it left off
Have tried double pause but it doesn’t work. Any suggestions?
I think this is a limitation/bug of the vacuum firmware.
If you pause it with the physical button on the vacuum and then press again to resume it will as well start a brand new cleanup instead of resuming.
If you uses zones then pause/resume works with HA and physical button.
I have never found a way of HA reliably resuming the cleaning, but I found that sending the direct commands to the vacuum seems to work properly.
So I built the following automation, based on a sensor where I store the type of cleaning (disregard the trigger part, as this is just triggered from an iOS actionable notification):
### Resume Vacuum Cleanup when action is chosen from iOS ###
### Possible commands in python-miio/miio/vacuum.py ###
### from https://github.com/rytilahti/python-miio ###
  - alias: 'Resume Vacuum from iOS'
      platform: event
      event_type: ios.notification_action_fired
      event_data:
        actionName: VACUUM_RESUME
      - service: vacuum.send_command
        data_template:
          entity_id: vacuum.aspirador
          command: >-
            {% if is_state('sensor.current_cleanup_type', 'segment_clean') %}
              resume_segment_clean
            {% elif is_state('sensor.current_cleanup_type', 'zoned_clean') %}
              resume_zoned_clean
            {% elif is_state('sensor.current_cleanup_type', 'clean') %}
              start
            {% endif %}
Hope this helps, although it is not exactly what you asked for, it actually works perfectly well.
@pplucky Thank you - works a treat !
@masterfink thanks for the node red code - I had to modify my wait command though as my vacuum needs to recharge if I select all my rooms - this causes a problem as the return to dock is read as room finished - so last few rooms get missed.
Ended up solving it by adding a template sensor to figure out the difference between return to dock for charging vs finished room clean - so mine waits for my sensor.vacuum_cleaning_state to be false:
Might help someone:
      vacuum_cleaning_state:
        friendly_name: Cleaning Status
        entity_id:
          - vacuum.xiaomi_vacuum_cleaner
        value_template: >-
          {%- if is_state("vacuum.xiaomi_vacuum_cleaner","returning") -%}
            {%- if (states.vacuum.xiaomi_vacuum_cleaner.attributes.battery_level | int < 21) -%}
              Charge_return
            {%- else -%}
              False
            {%- endif -%}
          {%- else -%}
            {%- if is_state("vacuum.xiaomi_vacuum_cleaner","docked") and (states.vacuum.xiaomi_vacuum_cleaner.attributes.battery_level | int < 81) -%}
              Charging
            {%- else -%}
              {%- if not is_state("vacuum.xiaomi_vacuum_cleaner","docked") -%}
                True
              {%- else -%}
                False
              {%- endif -%}
            {%- endif -%}
          {%- endif -%}
Had to add an extra pause in the flow.
Other change is my rooms deselect in lovelace as it finishes each one, so you can see the progress:
Can @fillilutten or somebody else explain on how to do that without Node Red? I just have Home Assistant. I have valetudo running on my vacuum and zones are configured. But I cant find a way to start zoned cleanup. I have been trying with this:
start_zoned:
  alias: start zoned
  icon: mdi:stairs
  mode: single
  sequence:
  - data:
      command: zoned_cleanup
      entity_id: vacuum.tachikoma
      params:
        zone_ids:
        - stairs
But its not working. Any help?
