Hum yeah, totally forgent about the states menu !
Do you think itās now possible to use the long-lived token with ifft?
Thanks for this great article! found an easier way to both get the token and the map coordinates.
Install mitmproxy on your computer, set the computer as proxy on your mobile phone.
Then you can get both the token and the map coordinates by looking what is sent to the vacuum in mitmproxy.
You will need to add the mitmproxy ssl certificate to your mobile device for this to work (so mitmproxy is able to decrypt the ssl traffic).
I found this is the easiest: Get the Xiaomi Home token
Granted you need to trust a russion app but well I deinstalled it after getting the token and with NoRoot Firewall keep everything blocked afterwards.
Thatās the one linked in my how-to
oops. I never saw that because I never read the full opening post and unfolded that point. Saw only the other post haha
Is there a way to get multiple zones vacuumed in one script? Can someone pls provide an example?
Iād like to say āAlexa, vacuum the kitchenā, but the area would need a couple of āzonesā. I donāt want it to go back to the dock after cleaning the first zone, but continue to the second zone, then redock.
Well you can put all zones in sequence in your script.
Yes, thatās possible. The command takes a list of zones. This is also described in the HowTo. For example:
vacuum_kitchen:
alias: "Vacuum the kitchen"
sequence:
- service: vacuum.send_command
entity_id: vacuum.DustyMcDustface
command: app_zoned_clean
params: [[26500, 20500, 29000, 23000, 1], [23500, 23500, 21000, 22000, 1]]
Thanks for that guys. Is the following code valid then?
vacuum_family_area:
alias: "Vacuum the family area"
sequence:
entity_id: vacuum.xiaomi_vacuum_cleaner
params: [[21800, 19500, 26300, 23000, 1]]
params: [[23000, 23300, 26300, 25400, 1]]
Or Iām guessing it should be more like this?
vacuum_family_area:
sequence:
params: [[21800, 19500, 26300, 23000, 1], [23000, 23300, 26300, 25400, 1]]
For anyone interested I have managed to complete a migration of the original āVacuum a Roomā Floor Plan config into Lovelace using a Picture Elements Card rather than Floor Plan. Overall it works well although rather than being able to click on a room I need to click on the room text. Also - background is transparent so it changes with the theme. Lovelace Config
Yay got it working, thanks for the help
Yes, sorry
Iāve just read through this a few times, and tried @stanvx yaml file (changing the appropriate items for our house) and I must be thick, as I canāt get anything to work.
Has anyone put together a Dummyās Guide to this as yet? Iām happy to test it out
I will be honest, my experience with Home Assistant (Iām running Hassbian because I donāt like Docker) is a bit limited, but I have basic stuff working, like lights doing what I want, and I can do basic things with the Roborock already via itsā own group tabā¦
Iām not running Lovelace, as I havenāt got my head around that yetā¦
I couldnāt get this to work until i added quotes to everything.
Unfortunately I have the issue that the map keeps rotating.
Try avoiding the regular cleanup. It seems that the map rotates once you initiate a regular cleanup (where the robot cleans everything he can find). You can actually use that knowledge to get the map into your desired position again. Then, after the map is in the right position, only use zoned cleanups - they wonāt rotate the map.
Itās really an annoying thing because I often clean upstairs or separate rooms but then when I put it back downstairs indeed the map is rotated or all coordinates donāt apply anymore!
If anyone has a brilliant solution for thisā¦
Iām not getting app_go_to command to work. It works in dev tools when I call the service, but it does not when I put it in a script. Does it not work within a script?
Yes, it works in a script. Can you please post your script here? There must be an error in your script.
