The problem is that you need to verify your ownership of https://xxxxxxxxx.duckdns.org/ and there are several options, e.g. “you can upload an html-file to your server”, so it will be something like https://xxxxxxxxx.duckdns.org/googledjdk5265365366xxx.
Or you can add html tag in “meta name” etc.
Could someone explain how to do it?
You should make that html file available on the system on which you run home assistant. So it would be, usually, in the folder homeassistant/components/frontend/www_static if you set up duckdns correctly the file would then be reachable via xxx.duckdns.go/htmfile.html
I’ve temporarily solved the issue on domain verification by adding the meta tag in \Python35-32\Lib\site-packages\homeassistant\components\frontend\templates\index.html however, I don’t think that it is a good solution.
Were you able to get this working end to end? I’ve gotten as far as you have (domain verification through metatag and duckdns) but I could get the notifications slider to activate. I wonder if I used the right gcm/api keys, since the directions were a little unclear and did not match what was available in gcm.
If I understood the structure of the code some more I’m sure I could do the work and do a pr for it. Not use to all the open source stuff. I use git daily however lol
Thanks to this thread I was able to get the domain verified in Google by manually editing my index.html
Now, I’m running into a problem where when I try to enable push notifications in my browser (tried both Chrome and FF), I get a “failed to register” error. I’m not seeing anything in home_assistant.log. Does anyone have a suggestion on where to start debugging this? I’m pretty confident that I’ve got the correct keys from firebase, etc.
I’ve got:
- name: html5
platform: html5
gcm_api_key: 'long string of characters'
gcm_sender_id: 'shorter string of characters'
I’ve tried triggering a notification via the services dev tool and also via a script:
htmlpushtest:
alias: HTML5 push
sequence:
- service: notify.html5
message: "This is a test"
Though, I don’t think it’s my script that’s the issue, but likely something with my config.
I’m using the AIO install, secured with LetsEncrypt. No proxies or NGINX to deal with.
Have you checked that all dependencies have been installed?
I remember that I had a problem with that some of them were not automatically installed several versions ago. And I am not sure if the issue has been completely resolved in the current version.
