Hi, I’m also having difficulties with the step of verifying the domain (duckdns). This thread is very helpful however I can’t locate the …\components\frontend…\index.html to add in the metatag as per Molodax posts.
I’ve installed home assistant using the all-in-one installer and the only file directories in my \homeassistant\ directory are '.homeassistant and ‘.cache’
When trying to verify domain, letsencrpyt places file on your webserver then attempts to view that file…
SO
1.Let’s encrypt puts file on server at /var/www/letsencrypt/checkfile (for example)
2.lets encrypt checks file present at http://your domain/letsencrypt/checkfile
3.if file found, domain is controlled by you
If having issues verifying domain you should place a file at /var/www/letsencrypt/testfile(for example), then verify the file is accessible from your domain.
You must know where letsencrypt is placing the file or there is a method to specify where the file will be placed.
@tmjpugh
Thank you for your detailed explanation, however, the issue is about component HTML5 notify and the necessity to verify domain for Google. It is not a question about letsencrypt.
I found that Firefox has less requirements for testing so until you get a message sent it may be better to remove all “Chrome” user agents from html5_push_registrations.conf and test with firefox only.
for me, when chrome fails due to configuration issues it would not send to Firefox browsers
Actions will not work in firefox I believe…fyi
Good to know, however, it’s a bit off topic since its not a browser issue or question regarding configuration. It’s rather a limitation of current implementation the component in HASS and poorly written instructions.
So it seems the docs are little out, but I found my way to the google domain verification, now getting 404: not found when trying to test the file upload. It is definitely there… so I’m thinking its an access issue.
perhaps related to this. Unfortunately I need to wait until I can power cycle my RPi
I have managed to get the HTML5 domain verification stuff done but…
I cant get the slider to switch on with my HassIO install where I have just now set up the HTML5 component. As far as I’m aware I have completed all the prerequisites, domain has been verified and HTML details listed under notify.yaml
