After i have set a color for the “color” Hue lights they change 3 till 4 times a week to amber/white instead of blue and green etc.
Can i set the RGB in the script with yaml?
So it will allways use that as default?
I have tried to search and find some explanation what i understand in all the treads and stuff but i dint find something i can easy use.
Ty for the quick response,
But the above one get the anwser in the lower one, and that refers to a CSV file in components / lights
I have a RPi4 with SSD addon and i run the full version Home Assistant and i dont that those folders. ( HA OS 11.5)
As on your anwser they talk about the csv file there.
This is what i have in my Home Assistant folder:
So you lost me there, and this are the lights.
some are just filament bulbs without color, and the others are with colors:
homeassistant folder and the config folder is the same thing, it just goes in there next to those files / folders in the same place that configuration.yaml lives.
