Sure!
I’ve removed any links to the LH menu and top alarms as that’s another story.
Note that since I last posted, I’ve changed the top section for both heating and water to reflect the fact I realised I never needed the “off” or “Scheduled” buttons as I lever had a need to leave “scheduled” so now looks like this:
I think I mentioned before that you cannot switch schedule 2 or 6 on/off or set their time - this is because they are the default ‘day’ and ‘night’ temps and so must always be ‘on’ and the timing is set by input_select.house_mode
. It’s easy enough to con age if you don’t want to do it this way, but just ask if you want help.
I’m using a bunch of decluttering templates (which uses custom: button) so you’ll need to install the following (HACS):
- custom:decluttering-card
- custom:button-card
- custom:text-divider-row
- custom:lovelace-expander-card
- custom:vertical-stack-in-card
- custom:lovelace-layout-card
- custom:numberbox-card
- custom-brand-icons
The code might look a little bonkers but info_button
is used all over my dash and a single change to it will change the look of all my dashboards.
The Hive ‘system’ assumes the following template sensors exist which I can provide if needed):"
can be['Awake','Asleep','Manual']
zone.home
(most users have this)sensor.time
(most users have this)- contact sensors ending in
door_contact
,doors_contact
,window_contact
- check the package forbinary_sensor.hive_heating_doors/windows open
which uses these and has some ignored (eg: for me the front door and ensuite window).
Dashboard view
Heating/Water view
title: Hive heating
path: hive
icon: phu:hive
cards:
- type: vertical-stack
title: Hive Status
cards:
- type: custom:decluttering-card
template: climate-info
template: climate-info-temperature
- type: horizontal-stack
cards:
template: info_button
variables:
- entity: sensor.hive_heating_today
- name: Heating today
- show_icon: false
- icon: mdi:radiator
- action: navigate
- navigation_path: hive_history
variables:
- entity: sensor.hive_water_today
- name: Water today
- show_icon: false
variables:
- entity: switch.study_smartplug
- name: Study radiator
- show_icon: false
- on_colour: var(--state-climate-heat-color)
- off_colour: grey
- action: toggle
- type: history-graph
show_names: false
entities:
- entity: climate.hive_heat
title: Heating
cards:
template: climate-influence_boost
variables:
- item: heating
- name: "[[[ return '➜ '+ states['sensor.hive_heating_target_temp'].state +'℃' ]]]"
- icon: "[[[ return states['sensor.hive_heating_target_temp'].attributes.icon ]]]"
- label: "[[[ return 'set by: ' + states['sensor.hive_heating_target_temp'].attributes.influence ]]]"
# influence
- type: conditional
conditions:
- entity: binary_sensor.hive_heating_doors_windows_open
state_not: 'off'
card:
type: markdown
content: >
<h3>Dr/win open:</h3>
{{ state_attr('binary_sensor.hive_heating_doors_windows_open','influence') }}
# schedule
- type: custom:text-divider-row
text: "Schedule & Settings"
template: climate-schedule_heating
variables:
- schedule: 1
- scheduled_colour: Brown
variables:
- schedule: 2
- action: none # day default - must not be toggled off
variables:
- schedule: 3
variables:
- schedule: 4
variables:
- schedule: 5
variables:
- schedule: 6
- action: none # night default - must not be toggled off
# defaults
- type: custom:expander-card
title: Default settings
title-card-button-overlay: true
padding: 0em
gap: 0em
cards:
- type: entities
entities:
- type: custom:numberbox-card
entity: input_number.hive_heating_away_temp
entity: input_number.hive_heating_open_temp
- type: divider
entity: input_number.hive_heating_boost_temp
entity: input_number.hive_heating_boost_time
template: internals_automation
variables:
- automation: 'hive_heating_*'
title: Hot water
cards:
variables:
- item: heating
- name: "[[[ return '➜ '+ states['sensor.hive_water_target_mode'].state ]]]"
- icon: "[[[ return states['sensor.hive_water_target_mode'].attributes.icon ]]]"
- label: "[[[ return 'set by: ' + states['sensor.hive_water_target_mode'].attributes.influence ]]]"
- color: var(--state-active-color)
# schedule
template: climate-schedule_water
variables:
- schedule: 1
variables:
- schedule: 2
variables:
- schedule: 3
variables:
- schedule: 4
# defaults
padding: 0em
gap: 0em
cards:
entity: input_number.hive_water_boost_time
Decluttering cards
Note: I use these everywhere so may have functionality not used by the Hive view"
info_button
default:
- show_name: true
- name:
- show_state: true
- show_icon: true
# note attribute take precedence over label
- label: ''
- attribute: false
- icon:
- colour: gre
- show_border: true
# on / off
- on_value: 'on'
- on_operator: '=='
- on_colour: var(--state-active-color)
- on_icon:
- on_name:
- on_label: # for attribute ilo state
- on_box_shadow: false
- off_value: 'off'
- off_operator: '=='
- off_icon:
- off_label:
- off_name:
- off_colour: var(--state-inactive-color)
- off_box_shadow: false
# values: note box_shadow_[1,2,3] uses on_box_shadow
- value_1:
- value_2:
- value_3:
- operator_1: '=='
- operator_2: '=='
- operator_3: '=='
- icon_1:
- icon_2:
- icon_3:
- label_1:
- label_2:
- label_3:
- action: none
- hold_action: none
- condition_entity: input_boolean.dummy
- condition_state: "on"
card:
type: conditional
conditions:
- condition: state
entity: '[[condition_entity]]'
state: '[[condition_state]]'
card:
type: custom:button-card
entity: "[[entity]]"
show_name: '[[show_name]]'
show_icon: '[[show_icon]]'
show_state: '[[show_state]]'
show_label: "[[[ if ( [[label]] != '' || [[attribute]] != false ) return 'true'; else return 'false'; ]]]"
label: '[[label]]'
icon: '[[icon]]'
color: auto
color_type: icon
styles:
card:
- font-size: 15px
- border: "[[[ if ( '[[show_border]]' == 'false' ) return 'solid 0px'; ]]]"
icon:
- color: '[[colour]]'
state:
label:
state:
- value: '[[on_value]]'
operator: '[[on_operator]]'
icon: '[[on_icon]]'
label: '[[on_label]]'
styles:
card:
- box-shadow: "[[[ if ( '[[on_box_shadow]]' == 'true' ) return '0px 0px 9px 3px [[on_colour]]'; ]]]"
state:
- color: '[[on_colour]]'
icon:
label:
- value: '[[off_value]]'
operator: '[[off_operator]]'
icon: '[[off_icon]]'
label: '[[off_label]]'
styles:
card:
- box-shadow: "[[[ if ( '[[off_box_shadow]]' == 'true' ) return '0px 0px 9px 3px [[off_colour]]'; ]]]"
state:
- color: '[[off_colour]]'
icon:
label:
- value: '[[value_1]]'
operator: '[[operator_1]]'
icon: '[[icon_1]]'
label: '[[label_1]]'
styles:
card:
state:
- color: '[[colour_1]]'
icon:
label:
- value: '[[value_2]]'
operator: '[[operator_2]]'
icon: '[[icon_2]]'
label: '[[label_2]]'
styles:
card:
state:
- color: '[[colour_2]]'
icon:
label:
- value: '[[value_3]]'
operator: '[[operator_3]]'
icon: '[[icon_3]]'
label: '[[label_3]]'
styles:
card:
state:
- color: '[[colour_3]]'
icon:
label:
- value: "[[[ return entity.state == 'unknown' || entity.state == 'unavailable' || entity.state == 'offline' ]]]"
operator: 'template'
styles:
state:
- color: var(--error-color)
icon:
label:
tap_action:
action: "[[action]]"
navigation_path: "[[navigation_path]]"
url_path: "[[url_path]]"
service: '[[service]]'
entity_id: '[[entity]]'
hold_action:
action: "[[hold_action]]"
default:
- item: heating
card:
type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 3fr 1fr
grid-template-rows: auto
grid-template-areas: '"infl boost"'
cards:
- type: custom:button-card
view_layout:
grid-area: infl
entity: "sensor.hive_[[item]]_target_temp"
icon: '[[icon]]'
show_icon: true
show_state: false
show_label: true
label: '[[label]]'
layout: icon_name_state2nd
styles:
card:
- height: 60px
- font-size: 15px
name:
- justify-self: start
label:
icon:
tap_action:
action: none
view_layout:
grid-area: boost
entity: timer.hive_[[item]]_boost
if ( states['timer.hive_[[item]]_boost'].state == 'active' ) return 'Cancel Boost'
else return 'Boost'
icon: mdi:plus
color_type: icon
color: auto
show_state: false
styles:
card:
- height: 60px
- font-size: 15px
icon:
- color: var(--state-inactive-color)
state:
- value: "active"
styles:
icon:
state:
tap_action:
action: none
hold_action:
action: call-service
service: script.hive_[[item]]_toggle_boost
default:
- action: toggle
- scheduled_colour: SkyBlue
card:
title-card:
entity: 'input_boolean.hive_heating_[[schedule]]_scheduled'
card_size: 1
show_name: true
if ( '[[schedule]]' == '2' ) return 'Awake';
if ( '[[schedule]]' == '6' ) return 'Asleep';
else return states['input_datetime.hive_heating_[[schedule]]'].state.slice(0,-3);
show_icon: true
icon: mdi:calendar-remove
show_state: false
show_label: true
label: "[[[ if ( states['input_boolean.hive_heating_[[schedule]]_scheduled'].state === 'on' ) return '➜ ' + states['input_number.hive_heating_[[schedule]]_temp'].state + ' ℃'; ]]]"
layout: icon_name
styles:
card:
- height: 50px
- padding: 5px
- font-size: 15px
grid:
- grid-template-areas: '"i n l"'
- grid-template-rows: 40px
- grid-template-columns: 20% 20% 60%
name:
label:
icon:
state:
# heating
- operator: template
value: "[[[ return states['sensor.hive_heating_target_temp'].attributes.influence.slice(-1) == [[schedule]] ]]]"
icon: mdi:radiator
styles:
card:
- box-shadow: 0px 0px 9px 3px var(--state-active-color)
name:
icon:
label:
# scheduled
- value: "on"
icon: mdi:calendar-check-outline
styles:
name:
- color: '[[scheduled_colour]]'
icon:
label:
tap_action:
action: none
hold_action:
action: '[[action]]'
# end of title card --------------------------------------------------------
padding: 0em
gap: 0em
cards:
- type: custom:vertical-stack-in-card
cards:
- type: conditional # dont show 'on' if [[schedule]] is 2 or 6
conditions:
- entity: input_datetime.hive_heating_[[schedule]]
state_not: 'unavailable'
card:
type: custom:time-picker-card
link_values: true
layout:
align_controls: right
thin: true
tap_action:
action: none
entity: input_number.hive_heating_[[schedule]]_temp
card:
title-card: #-----------------------------------------------------------------
entity: 'input_boolean.hive_water_[[schedule]]_scheduled'
card_size: 1
show_name: true
name: "[[[ return states['input_datetime.hive_water_[[schedule]]_on'].state.slice(0,-3) ]]]"
show_icon: true
show_state: false
show_label: true
label: "[[[ if ( states['input_boolean.hive_water_[[schedule]]_scheduled'].state === 'on' ) return 'for ' + states['input_number.hive_water_[[schedule]]_time'].state + ' Hr(s)'; ]]]"
layout: icon_name
styles:
card:
- height: 50px
- padding: 5px
- font-size: 15px
grid:
name:
label:
icon:
state:
# On
value: "[[[ return states['sensor.hive_water_target_mode'].attributes.influence.slice(-1) == [[schedule]] ]]]"
icon: mdi:water-pump
styles:
card:
name:
icon:
label:
- color: var(--primary-text-color)
# scheduled
- value: "on"
styles:
name:
icon:
label:
tap_action:
action: none
hold_action:
action: toggle
padding: 0em
gap: 0em
cards:
cards:
- type: custom:time-picker-card
entity: input_datetime.hive_water_[[schedule]]_on
link_values: true
layout:
thin: true
tap_action:
action: none
entity: input_number.hive_water_[[schedule]]_time
card:
horizontal: true
cards:
variables:
- entity: sensor.coldest_temp
- name: Coldest
- icon: mdi:thermometer-low
- colour: LightBlue
- action: navigate
- navigation_path: weather_temp
variables:
- entity: sensor.coldest_heated_temp
- name: heated
- colour: LightBlue
- action: navigate
variables:
- entity: sensor.hottest_temp
- name: Hottest
- icon: mdi:thermometer-high
- colour: pink
- action: navigate
climate-info
default:
- action: none
card:
cards:
horizontal: true
cards:
- type: custom:layout-card
layout:
grid-template-columns: auto
grid-template-areas: '"down hive up"'
cards:
# down ---------------------------------------
- type: conditional
conditions:
- entity: sensor.hive_heating_reported_mode
state_not: "off"
card:
view_layout:
grid-area: down
entity: sensor.hive_heating_reported_target_temp
show_name: true
show_state: false
show_label: true
label: "[[[ return (entity.state -0.5) + '℃' ]]]"
icon: mdi:thermometer-minus
styles:
card:
- font-size: 15px
- color: grey
icon:
- color: LightBlue
tap_action:
service: script.turn_on
service_data:
entity_id: script.hive_heating_decrease_setpoint
# hive ---------------------------------------
view_layout:
grid-area: hive
entity: binary_sensor.hive_heating_reported_action
show_name: false
show_state: false
show_icon: true
icon: "[[[ if ( states['binary_sensor.hive_heating_reported_action'].state == 'off') return 'mdi:radiator-disabled'; else return 'mdi:radiator'; ]]]"
show_label: false
label: >
if ( states['sensor.hive_heating_reported_mode'].state == 'off' ) return '(off)';
if ( states['timer.hive_heating_boost'].state == 'active' ) return states['sensor.hive_heating_reported_target_temp'].state +'<font color="grey"> (Boost)</font>';
else return '<font color="grey"> (' + states['binary_sensor.hive_heating_reported_action'].state+')</font>';
custom_fields:
ts: "[[[ if ( states['sensor.hive_heating_reported_mode'].state == 'off' ) return 'off'; else return states['sensor.hive_heating_reported_target_temp'].state + '℃' ]]]"
tn: "Target"
cs: "[[[ return states['sensor.hive_heating_reported_current_temp'].state + '℃' ]]]"
cn: "Actual"
styles:
grid:
- grid-template-areas: |
"i i"
"s s"
"tn cn"
"ts cs"
- grid-template-columns: auto
card:
- font-size: 15px
- border: 0px solid
icon:
- color: >
if ( states['sensor.hive_heating_reported_mode'].state == 'off' ) return 'grey';
else if ( states['binary_sensor.hive_heating_reported_action'].state == 'off' ) return 'LightBlue';
else return 'var(--state-climate-heat-color)';
state:
- color: "[[[ if ( states['sensor.hive_heating_reported_mode'].state == 'off' ) return 'grey'; else return 'orange'; ]]]"
custom_fields:
tn:
- color: grey
cn:
- color: grey
ts:
- color: "[[[ if ( states['sensor.hive_heating_reported_mode'].state == 'off' ) return 'grey'; ]]]"
cs:
- color: >
if ( states['sensor.hive_heating_reported_current_temp'].state < states['sensor.hive_heating_reported_target_temp'].state ) return 'LightBlue';
else if ( states['sensor.hive_heating_reported_current_temp'].state > states['sensor.hive_heating_reported_target_temp'].state ) return 'orange';
tap_action:
action: more-info
# up ---------------------------------------
- type: conditional
conditions:
state_not: "off"
card:
view_layout:
grid-area: up
show_name: true
show_state: false
show_label: true
label: "[[[ return (+entity.state +0.5) + '℃' ]]]"
icon: mdi:thermometer-plus
styles:
card:
- font-size: 15px
- color: grey
icon:
- color: orange
tap_action:
service_data:
entity_id: script.hive_heating_increase_setpoint
default:
- title: ''
- slice: 0
card:
type: custom:auto-entities
show_empty: false
card:
type: entities
title: '[[title]]'
show_header_toggle: false
sort:
method: name
filter:
include:
- entity_id: 'automation.[[automation]]'
options:
entity: this.entity_id
show_state: true
name: "[[[ return entity.attributes.friendly_name.slice([[slice]]) ]]]"
styles:
grid:
- grid-template-areas: '". n s"'
- grid-template-columns: 1em 1fr 2em
card:
- height: 40px
- padding: 0
name:
- font-size: 14px
- color: "[[[ if (entity.state == 'off') return 'grey'; else return 'lightgrey'; ]]]"
state:
- color: "[[[ if (entity.state == 'off') return 'brown'; else return 'green'; ]]]"
- font-weight: bold
tap_action:
action: toggle
hold_action:
action: more-info
OK, this has taken a little time to write/edit so I apologise if there are any typos. Just ask if something doesn’t work. Please test it to ensure it works for you.
I’ll repost the packages shortly (the forum would not let me put it all on one post.
[Edited for clarity and typos]
