Humidity information on the Thermostat Card
Humidity information is quite common with many different climate devices. This metric can be added to the Thermostat card, for example like this:
This was also discussed here: Humidity display on the Thermostat Card · Issue #4740 · home-assistant/frontend · GitHub
If you think this is a good idea, please hit the VOTE button up top!
I voted for this, but if you want alternatives i listed all i could find here 2023.12: Welcome home! - #501 by nickrout
At least, it should be able to configure it, if you want to display this information or not - if the integration / device does provide this information.
If it doesn’t, it can be considered, if you should be able to add the information from another humidity sensor as an alternative
Duplicate, vote here
