Unfortunately it doesnt seem to work, I cant get Arduino IDE to work in order to do the calibration.
question
has anybody knowledge how I could realize this with ESPHome and may help with the wiring? I have basic knowledge with ESPHome but not any with wiring load cells. I spent hours of research but couldnt find any suitable tutorial with my config including only one cell. for example I found this thread: ESP8266 + HX711 + 4 small load cells giving incorrect values
The goal is to use the scale for a “smart” toilet paper holder
The wires colors on load cells are not always correct. With a resistance meter, a pair will be 2x the resistance. That pair should be the e- and e+ in your diagram
the log always shows a value of 0 regardless how much pressure I put on the sensor. I even tried another HX711 and another load cell (also checked the resistance) but have the same results.
I use the full four load cells and never tried with less. The only thing I might suggest is trying with all 4 load cells to first make sure that the items you have are working.
thats a good idea, actually it doesnt work either :S I have no clue what I am doing wrong but I will put it aside for the moment I never had issues with other ESP-projects. If I find a solution I will post it here.
For future reference: there are “single” load-cells with 4 internal sensors aka beam load-cells and these will plug straight into the HX711 (and have more wires).
The sensor that was being used must be configured as part of 4 into a Wheatstone bridge - Wikipedia or it simply won’t work; the HX711 is (from memory) measuring tiny tiny voltage differences and needs the cancellation and comparison effect of this bridge (which is a bit of a mind-bender in itself, and look how old it is)
Also the stamped metal sensor being used here is a bit …terrible (I have some). Its poor measurement repeatability and creep under load will be annoying, I’d suggest a cheap beam sensor is 10x better and simpler at the same time.
Hello @bwooce thanks for your idea. I need to build something to measure the weight of my chicken’s food and water.
What kind of beam sensor do you have in mind? Can you please give me an example on aliexpress ?
