I’m having a hard time getting these HX711 + load cells to work.
Currently using:
HX711 Sensor
Wemos D1 Mini
4 Load cells connected in wheatstone bridge
I’ve tried hooking them up in different ways and experimenting with the sensor, YAML, firmware but could never get accurate readings. What am I missing to get these working. Note that I connected the wires for the load cells by twirling them together and then hot-glueing them, previously soldered them but made no difference.
I’m just getting the same very high negative value (even when placing different weights on the cells) and when I look at the history it briefly changed to another value (with nothing on the scale)
Wemos D1 mini connected to HX711 via 2 GPIO pins and 5V.
Doesn’t seem to make any difference running on the 3v3 pin. Shows the same reading with nothing on the scale, a clay pot and a propagation station in plastic.
@thibmaek Wemos DI has a divider of 3.3 on the adc input.
You need to multiply with 3.3 to get correct results.
This divider is placed to protect the ADC input which can take max of 1 Volt.
@thibmaek
You have indicated that you have connected the load cells in Wheatstone bridge config.
Is the reading of each load cell added and finally divided by 4?
Multiplying by 3.3 didn’t do the trick. Here’s how I connected everything. The diagram doesn’t show wiring to D1 Mini but I’ve got that to:
DAT: D2
CLK: D3
GND: GND
VCC: 3.3V
Apart from the ESPHome code above I have not made any additional changes like dividing by 4
[14:50:11][D][hx711:031]: 'Weight': Got value -8388608
[14:50:11][D][sensor:092]: 'Weight': Sending state -27682406.00000 with 0 decimals of accuracy
[14:50:35][D][sensor:092]: 'ESP8266 HX711 — Uptime': Sending state 55.86800 s with 0 decimals of accuracy
[14:50:41][D][hx711:031]: 'Weight': Got value -8388608
[14:50:41][D][sensor:092]: 'Weight': Sending state -27682406.00000 with 0 decimals of accuracy
[14:50:52][D][sensor:092]: 'ESP8266 HX711 — Signal': Sending state -78.00000 dB with 0 decimals of accuracy
[14:51:11][D][hx711:031]: 'Weight': Got value -8388608
[14:51:11][D][sensor:092]: 'Weight': Sending state -27682406.00000 with 0 decimals of accuracy
[14:51:35][D][sensor:092]: 'ESP8266 HX711 — Uptime': Sending state 115.86700 s with 0 decimals of accuracy
[14:51:41][D][hx711:031]: 'Weight': Got value -8388608
[14:51:41][D][sensor:092]: 'Weight': Sending state -27682406.00000 with 0 decimals of accuracy
Another thing I noticed is that all four load cells are placed in the base packaging material which is compressible. How about placing them on the floor instead.
Just starting this project and from what I see you have your black & white wires connected incorrectly. Don’t know if that is what’s causing your problem or not but worth a test.
My wiring is basically the same but in the opposite direction, don’t think that matters (only direction might be reversed in readings) The bases are 3d printed, load cells and HX711 from Aliexpress
@thibmaek, you have not applied the calibration if you notice very large negative number is zeroed and another negative value set to about 79 Kg.
Maybe without calibration the output is negative.
I am quoting from the link posted by you
I now have this but it seems to wildly fluctuate even when there is no weight applied to the scale.
Started at 0.0 kg then went up to 0.19. I think these load cells are only meant to measure rough and high loads, not to the gram.
filters:
- calibrate_linear:
- -2112820 -> 0
- -1279866 -> 2.684 # measured this with a kitchen scale first
[11:23:43][D][hx711:031]: 'Weight': Got value -2052437
[11:23:43][D][sensor:092]: 'Weight': Sending state 0.19457 kg with 0 decimals of accuracy
[11:24:13][D][hx711:031]: 'Weight': Got value -2054781
[11:24:13][D][sensor:092]: 'Weight': Sending state 0.18702 kg with 0 decimals of accuracy
[11:24:21][D][sensor:092]: 'ESP8266 HX711 — Uptime': Sending state 3243.59399 s with 0 decimals of accuracy
[11:24:22][D][sensor:092]: 'ESP8266 HX711 — Signal': Sending state -81.00000 dB with 0 decimals of accuracy
[11:24:43][D][hx711:031]: 'Weight': Got value -2055960
[11:24:44][D][sensor:092]: 'Weight': Sending state 0.18322 kg with 0 decimals of accuracy
[11:25:13][D][hx711:031]: 'Weight': Got value -2057177
[11:25:13][D][sensor:092]: 'Weight': Sending state 0.17930 kg with 0 decimals of accuracy
[11:25:21][D][sensor:092]: 'ESP8266 HX711 — Uptime': Sending state 3303.59009 s with 0 decimals of accuracy
[11:25:22][D][sensor:092]: 'ESP8266 HX711 — Signal': Sending state -80.00000 dB with 0 decimals of accuracy
[11:25:43][D][hx711:031]: 'Weight': Got value -2055728
[11:25:43][D][sensor:092]: 'Weight': Sending state 0.18397 kg with 0 decimals of accuracy
[11:26:13][D][hx711:031]: 'Weight': Got value -2057550
[11:26:13][D][sensor:092]: 'Weight': Sending state 0.17809 kg with 0 decimals of accuracy
[11:26:21][D][sensor:092]: 'ESP8266 HX711 — Uptime': Sending state 3363.58789 s with 0 decimals of accuracy
[11:26:22][D][sensor:092]: 'ESP8266 HX711 — Signal': Sending state -81.00000 dB with 0 decimals of accuracy
[11:26:43][D][hx711:031]: 'Weight': Got value -2060993
[11:26:44][D][sensor:092]: 'Weight': Sending state 0.16700 kg with 0 decimals of accuracy
[11:27:13][D][hx711:031]: 'Weight': Got value -2062969
[11:27:13][D][sensor:092]: 'Weight': Sending state 0.16063 kg with 0 decimals of accuracy
[11:27:21][D][sensor:092]: 'ESP8266 HX711 — Uptime': Sending state 3423.58691 s with 0 decimals of accuracy
[11:27:22][D][sensor:092]: 'ESP8266 HX711 — Signal': Sending state -80.00000 dB with 0 decimals of accuracy
[11:27:43][D][hx711:031]: 'Weight': Got value -2061792
[11:27:43][D][sensor:092]: 'Weight': Sending state 0.16443 kg with 0 decimals of accuracy
Even with a weight applied it seems to just build up the weight the longer the ESP stays active.
Started at 2.6kg, after 30 min reading 4.99640 kg without a different weight applied to it.
