Thanks! It works!
Thanks so much for the Bluelink Integration.
I have a 2020 Hyundai Santa Fe. I’m getting only integer latitude and longitude locations from the integration. I tried Node-RED Bluelinky and discovered that Bluelink is returning only integer latitude and longitude in the vehicle status information. But, when location is queried it provides the full latitude and longitude values. One wonders what’s the point of these integer values in the status or if this is a Bluelink defect. Anyway, would it make sense to specifically request the vehicle location in the integration?
We are tracking this over here: GEO Location data is truncated Hyundai USA · Issue #196 · fuatakgun/kia_uvo · GitHub
This is resolved now. Give it a go for the latest version if you have a chance!
Issue was a API issue. Two commands exist for location. The typical one only gives integer but a direct query gives exact. Odd USA hyundai thing.
Hi, Amazing integration. I have two Hyundia’s One Kona and the other an Ioniq. When I activate and log on to the integration, I only get the Hyundia Kona and not the Hyndia Ioniq? Does the integration support 2 cars or is there any way to force the integration to choose/show the other car.
Hi. Great Job!!!
Is it posible to get it from you?
Thanks.
Sure, here you go. Slightly changed mind and using some custom cards
type: vertical-stack
cards:
- type: picture
image: /local/ionqi.png
tap_action:
action: none
hold_action:
action: none
card_mod:
style: |
ha-card {
--ha-card-background: transparent;
box-shadow: none;
- type: custom:stack-in-card
mode: vertical
keep:
background: false
border_radius: false
box_shadow: false
margin: false
outer_padding: false
cards:
- type: glance
entities:
- entity: binary_sensor.ioniq_plugged_in
- entity: binary_sensor.ioniq_charging
- entity: sensor.ioniq_range_by_ev
show_state: true
show_name: true
state_color: true
- type: custom:bar-card
icon: mdi:battery-charging
entities:
- entity: sensor.ioniq_ev_battery
columns: '0'
entity_row: false
direction: right
positions:
icon: outside
indicator: 'off'
minmax: 'off'
value: inside
severity:
- color: '#4CAF50'
to: '100'
- color: '#FFC107'
to: '60'
- color: '#FF5722'
to: '25'
- type: glance
entities:
- entity: binary_sensor.ioniq_tire_pressure_all
- entity: sensor.ioniq_car_battery
- entity: sensor.ionqi_battery_capacity_remaining
show_state: true
show_name: true
state_color: true
- type: markdown
content: ___
- type: glance
entities:
- entity: sensor.ev_mileage_since_last_charge
- entity: sensor.ev_comsumption
- entity: sensor.ioniq_odometer
show_state: true
show_name: true
state_color: true
- type: custom:button-card
entity: sensor.ioniq_last_update
show_last_changed: true
styles:
grid:
- grid-template-areas: '"i n l"'
- grid-template-rows: 100%
- grid-template-columns: 25% 45% 30%
label:
- justify-self: start
name:
- justify-self: end
- margin-right: 10%
name: 'Last Updated:'
aspect_ratio: 7/1
tap_action:
action: call-service
service: kia_uvo.force_update
@eximo84 Thanks for the yaml. I build with your input a great view, too.
Can you discribe how you calculate the “miles between charges”. And can you share the code for this and the lovelace yaml too. I think a own binary sensor and an jinja template can do this, but I down’t know how.
So i have a couple of helpers which are used to store statistics:
- EV Mileage Since Last Charge Base = this is the current odometer value when the car is plugged in
- EV Total Mile since last charge = this is the value from the template sensor “sensor.ev_mileage_since_last_charge”
- EV Battery Size = Set to 38.8 for my car
I have the following template sensors setup which are then used to calculate current milage, current battery remaining etc…
sensors:
ev_mileage_since_last_charge:
value_template: "{{ states('sensor.ioniq_odometer') | int - states('input_number.ev_mileage_since_last_charge_base') | int }}"
ionqi_battery_capacity_remaining:
unit_of_measurement: "kWh"
value_template: "{{ ((states('input_number.ionqi_battery_capacity') | float * states('sensor.ioniq_ev_battery') | float ) / 100) | round(1) }}"
ev_comsumption:
unit_of_measurement: "mi/kWh"
value_template: "{{ (states('sensor.ev_mileage_since_last_charge') | float / ((states('input_number.ionqi_battery_capacity') | float - states('sensor.ionqi_battery_capacity_remaining') | float ))) | round(1) }}"
And here are my automations to update the helpers when the car is plugged in
alias: Update EV Mileage Stats
description: Updates mileage stats after EV charger is connected
- platform: state
entity_id: binary_sensor.ioniq_plugged_in
to: 'on'
condition: []
- service: input_number.set_value
data_template:
entity_id: input_number.ev_total_mileage_since_last_charge
value: '{{states(''sensor.ev_mileage_since_last_charge'') | float }}'
data_template:
entity_id: input_number.ev_mileage_since_last_charge_base
value: '{{states(''sensor.ioniq_odometer'') | float }}'
mode: single
Hope this helps
Someone here having issues with the location? Mine is not updating anymore.
check the location from your app. Sometimes, location is not being updated through force_update
call (in a strange way)
Hi eximo84,
thanks for the input. With your hints I build the UI. And it looks great.
I will implement the automation for total_mileage_since_last_charge soon.
So here my current views and yamls
# lovelace yaml
cards:
- type: picture-entity
entity: device_tracker.os_ev_czech_20_location
image: http://xxxxxxxx/local/tmp/Hyundai-Kona.png
show_name: true
show_state: true
entities:
- entity: sensor.os_ev_czech_20_ev_battery
name: Akkukapazität in Prozent
animation:
state: 'on'
icon: mdi:car-battery
color: '#161616'
severity:
to: '100'
color: '#006600'
to: '25'
color: '#c1c100'
to: '15'
color: '#660000'
- entity: sensor.os_ev_czech_20_ev_battery_kw
min: '0'
max: '64'
animation:
state: 'on'
color: '#212121'
complementary: false
severity:
to: '50'
color: '#006600'
to: '20'
color: '#c1c100'
to: '10'
color: '#660000'
- entity: sensor.os_ev_czech_20_range_by_ev
max: '396'
min: '0'
color: '#161616'
severity:
to: '500'
color: '#006600'
to: '100'
color: '#c1c100'
to: '50'
color: '#660000'
positions:
icon: inside
minmax: inside
style: |-
bar-card-iconbar {
padding-left: 35px;
bar-card-value {
padding-left: 1.5em;
bar-card-min {
position: absolute;
padding-left: 6px;
bar-card-max {
position: absolute;
padding-left: 91%;
bar-card-divider {
display: none;
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 8px;
- type: grid
square: false
cards:
- type: glance
show_icon: true
show_name: true
show_state: true
state_color: false
theme: slate
entities:
- entity: binary_sensor.os_ev_czech_20_engine
- type: glance
show_icon: true
show_name: true
show_state: true
state_color: false
theme: slate
entities:
- entity: binary_sensor.os_ev_czech_20_plugged_in
- type: glance
show_icon: true
show_name: true
show_state: true
state_color: false
theme: slate
entities:
- entity: binary_sensor.os_ev_czech_20_charging
- type: button
tap_action:
action: toggle
entity: lock.os_ev_czech_20_door_lock
icon_height: 45px
show_state: true
theme: slate
- type: glance
show_icon: true
show_name: true
show_state: true
state_color: false
theme: slate
entities:
- entity: binary_sensor.os_ev_czech_20_trunk
- type: glance
show_icon: true
show_name: true
show_state: true
state_color: false
theme: slate
entities:
- entity: binary_sensor.os_ev_czech_20_hood
- type: glance
show_icon: true
show_name: true
show_state: true
state_color: false
theme: slate
entities:
- entity: binary_sensor.os_ev_czech_20_tire_pressure_all
- type: glance
show_icon: true
show_name: true
show_state: true
state_color: false
theme: slate
entities:
- entity: binary_sensor.os_ev_czech_20_air_conditioner
- type: custom:mini-graph-card
name: Akkukapazität der letzten 7 Tage
align_icon: left
hours_to_show: 168
points_per_hour: 1
upper_bound: 100
lower_bound: 0
entities:
show:
labels: true
animate: true
color_thresholds:
- value: 20
color: '#00ff00'
- value: 10
color: '#ff0000'
entity: sensor.os_ev_czech_20_last_update
secondary_info: last-changed
name: 'Zuletzt aktuallisiert:'
styles:
grid:
- grid-template-columns: 15% 58% 27%
label:
name:
- justify-self: end
- margin-right: 40%
And I have a view for the daily driven kilometers. The custom:mini-graph-card can do this, but I have a second logic for this with the utility_meter integration. Here I make the change your hints for mileage_since_last_charge and an automation. Thanks therefore!
# lovelace yaml
cards:
name: gefahrene Kilometer der letzten 7 Tage
align_icon: left
hours_to_show: 336
points_per_hour: 1
entities:
- entity: sensor.os_ev_czech_20_odometer
color: '#212121'
show:
labels: true
animate: true
name: gefahrene Kilometer pro Tag
align_icon: left
hours_to_show: 336
entities:
- entity: sensor.os_ev_czech_20_ev_daily_odometer
show_graph: false
aggregate_func: delta
group_by: date
show:
graph: bar
color_thresholds:
- value: 0
color: '#383C45'
- value: 1
color: '#161616'
align_icon: left
hours_to_show: 168
entities:
show_graph: false
group_by: date
show:
graph: bar
color_thresholds:
- value: 0
color: '#383C45'
- value: 1
color: '#161616'
# configuration.yaml
utility_meter:
os_ev_czech_20_ev_daily_odometer:
source: sensor.os_ev_czech_20_odometer
name: "OS EV CZECH 20 EV Daily Odometer"
cycle: daily
os_ev_czech_20_ev_monthly_odometer:
name: "OS EV CZECH 20 EV Monthly Odometer"
cycle: monthly
So i use card-mod to remove the name from picture-entity card like so:
My graph isnt ideal, i tried mini-graph but it averages my values and i dont want that. I am using apex-chart but i only want to plot a point on the graph each time the mileage between charges changes, currently it will fill in a months worth but can duplicate if it doesnt change regularly.
Hello All,
I have installed this integration via HACS, however I am not able to find configuration UI anywhere? Can someone help and guide me how to access/configure this integration - where I have to put username and password for BlueLink account?
Thank you!
Have you checked integrations page to add the integration? After downloading custom integration over hacs, you need to setup over here;
Yes, I was checking this but was not showing. However I did restart of HA, removal of intagration and afterwards installed it again and all worked. Thanks!
Hi, Thanks for the integration. Would you happen to know why I get only these entities for my 21’ Kona Electric. These are not that helpful and I’ve seen that Ioniq and Ioniq 5 integrations at least give useful stuff out (like SOC, or even some controls).
The only control I have is door lock…
I would say create a GitHub issue and dump your data sensor attributes into it. we had noticed slight differences between API responses for different cars and models.
