While esp-01 was working, it suddenly stopped connecting to wifi, it does not broadcast ssid. I can upload with espflasher, I can see the mac address. I am providing power to vcc and CH_PD pins. I also checked the log records while working, there is no record.
Are you installing ESPHome? Can you provide some logs.
Could you possibly write in complete sentences? What are you flashing? ESPHome or something else? Post your YAML file or code.
Welcome @ilkers to the community! ![]()
For the start it would be really helpful for us (so we can help you
) that you would take some minutes reading this post ![]()
I don’t think this is YAML code because when I closed and reopened it suddenly stopped working. still codes:
- platform: dht
pin: D0
temperature:
humidity:
update_interval: 10s
As seen in the screenshot, esp can be programmed. When working, the red light on the esp is constantly on, the blue light is flashing at startup.
Wifi does not connect, according to log records, the codes in ESP do not run. (ch pin is powered)
Can you post the code you are trying to upload. Also, try and capture in the logs the moment after uploading is complete.
The screenshot I replied to you is the log record after uploading.
platform: dht
pin: D0
temperature:
humidity:
At the bottom of the screenshot of your last post, I can make out the words “Writing 0x00000000 (4%)”.
What I am looking for is what comes after "Writing 0x######## (100%).
Odd that there is no output. What board are you using? What is CH_PD pin?
Can you also post your entire YAML file from ESPHome dashboard:
The card I use is esp-01, the programming card is USB To Ttl Uart CH340G.
After programming ESP, I power the ch pin
Please post code using code tags as described in Post #4.
I’m sure there is no problem with yaml codes. Because I also tried ready-made bin files and there is no log record. but still cods;
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ***
ota:
password: ***
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Dht Fallback Hotspot"
password: "dfX2wxR2ITQ1"
captive_portal:
web_server:
port: 80
version: 1
- platform: dht
pin: 02
temperature:
humidity:
You said in your original post that is was working then stopped. What changed with the board or Home Assistant that caused it to stop working.
What are you using to power the board?
What is this program you are flashing with?
It’s ESPHome Flasher. The same one I use. You won’t see log data here from the ESP-01.
Schematic, please. Though you said it had been working?
Yes it was working. Didn’t work after disconnecting the power and re-applying power.
For now, I’m temporarily powering it with the 3.3v output of the TTL module.
ESPHome-Flasher.
