OK as discussed in this https://community.home-assistant.io/t/ll-tts-give-unknown-error/537422/25. I have been trying to get TTS to work through my airplay speaker. I have tried several things including installing mopidy
and owntone server
. I also looked at https://community.home-assistant.io/t/make-airplay-speakers-the-voice-of-ha-other-fun-macos-tricks/189279/44. which looked promising but apparently apple rendered out date. Ok the strange things is that if I access my media from the side bar and select a mp3 file from my local media that file plays on my built in speaker which I can redirect using Airfoil. Trouble is I have no idea what app or Service is performing this function> My logs show nothing. If I could figure out the service I can build scripts and or auomaio to achieve my goal own an audible security system. I know this is back butt forward but it is almost what I wanted. Any thoughts and insights or suggestion would be appreicatte
Hi, is it not your browser that is playing?
The one from where you select that mp3 file from media.
Don’t you see a target at the right hand bottom where you select where to play this file?
ahhh I see what you mean… oh well Thought *I had a solution but don’t se how I can harness this. darn. Appreciate it
