that ws why I tried to show with the image
I can’t seem to show it with the forum software but ink my HA it is exactly ss you had
The image you posted was of your forum post, with no indenting.
All you should have to do is copy and paste it, using the code markup (</>
) in the toolbar.
Still, if you actually have it correct, check the log file for warnings or errors.
duh. logs. and thank for code markup tip
I am getting
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: RTSP/1.0 method ANNOUNCE failed with code 453: Not Enough Bandwidth
That doesn’t surprise as my internet is so so
back to MaryTTS since stand alone a actually my goal
configuration.yaml
# Text to speech
tts:
- platform: marytts
language: "en_US"
host: "10.0.1.10"
port: 59125
service call
service: tts.marytts_say
cache: false
entity_id: all
message: test
Ii get this error
[140499411523888] Error handling message: Unknown error (unknown_error) from 10.0.1.185 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.6.1 Safari/605.1.15)
10:27:54 AM – (ERROR) Home Assistant WebSocket API
websocket_api script: Error executing script. Unexpected error for call_service at pos 1: [Errno 111] Connection refused
10:27:54 AM – (ERROR) components/marytts/tts.py
I m wondering if this has to do with the fact I am running HA on a Linux VM hosted on Mac mini. I have tried localhost for the IP. 10.0.10 which is the VM and 10.0.1.185 (which if the host) and get the same error
Make sure that your internal URL is correctly set. If you’re handling SSL in HA then that can’t be http://
or use your LAN IP.
You can inspect the media player entity in states and test the URL for the TTS MP3 in your browser.
You have advanced my knowledge of HA several degrees. I had not updated the internal URL on this reinstallation. There is a media player instance in state but I am uncertain what you mean testing the url. I am still getting
[139964082203200] Error handling message: Unknown error (unknown_error) from 10.0.1.185 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.6.1 Safari/605.1.15)
2:56:13 PM – (ERROR) Home Assistant WebSocket API
2:56:13 PM – (ERROR) components/marytts/tts.py
I also can not get the MaryTT page up at 59125 just get a connection failure
Look at that entity and you’ll see a URL in the attribute. For instance I just played a TTS and see:
media_content_id: http://192.168.0.42:8123/api/tts_proxy/0f7b9c1779a56cde0deec591da114e59a68db301_en-us_152245a9c2_google_cloud.mp3
I can paste that URL into a browser and it plays the TTS.
I suspect you need to install that software, and that it’s not part of HA.
ahhhhhhhhhh. I was sort of thinking that. Make sense. Install on host or virtual machine?
It’d need to be an add-on
ahhh. I think that is level 5 and I am at level 0. Time for more research
and new errors. wonder if the speaker is part of the issue
139873573122976] Error handling message: Unknown error (unknown_error) from 10.0.1.185 (Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.6.1 Safari/605.1.15)
4:47:17 PM – (ERROR) Home Assistant WebSocket API - message first occurred at 4:47:02 PM and shows up 2 times
4:47:17 PM – (ERROR) components/apple_tv/media_player.py - message first occurred at 4:47:02 PM and shows up 2 times
Did you check the URL for the media_content_id
Did you test it in a browser?
There was no url I have no functioning TTS I don’t have anything to browse I just want it to say sornething like open or close
expanding the error I get
ok. selecting MaryTTS under media and choosing browser. I can get MaryTTS to speak Still no id
you’re saying that when you look in the States menu at the media_player
entity that there’s no attribute there?
my attributes are
volume_level: 0.33
friendly_name: Beachtick
supported_features: 137093
I think the nature of this device doen’t support what we re trying to do, It is an apple airport express router. which was discontinued 7 years ago, Thanks for all the effort
looking at this… I am thinking about utrying to add an Owntones server. to HA and then using Airplay to get the TTTS output to my speakers Does that makem any sense to anyone?
no luck with this or MaryTTS
Still playing and leaning, The issue was with the media players. The one I was trying to use was a BT in the Mac OS. In this Link. https://community.home-assistant.io/t/tryin-to-get-tts-to-work-on-host-computer/552930/4 I learned about browers mod which worked great for mat limited purpose
