I have this message AddonManager.install' blocked from execution, no host internet connection
Hi
I am brand new to home assistant, please be gentle, I have had a search but it has all this code.
I have installed on a Raspberry Pi4 on an ssd all went well. I can see my home and its connected to my items ok.
So I have gone exploring and I believe I have to download some bits and bobs including HACS.
When I go to download something I get this message
AddonManager.install’ blocked from execution, no host internet connection
I am totally new to this so please be gentle, it all looks so easy on youtube.
Thank you
Probably DNS.
Go to Settings → System → Network. Click on your adaptor then the IPv4 settings and change the DNS server to 8.8.8.8 or 1.1.1.1
Hi
Thankyou, it says External access denied beside network
Are you using Pi-Hole or some other network-wide blocker or have rules set up on your router/firewall? If you SSH to your Home Assistant system can you ping google.com or home-assistant.io?
Sorry
SSH?
A means for you to gain access directly to the HA console (which you can also do if you have a monitor attached to your rPi).
I cant access the network so my ip4 settings are wrong I think
Take a screenshot of what HA is showing you have configured your network as and post it here? Also, on a computer take a shot of your computers network settings? If you do that we can help you determine that.
I will have another go tomorrow
I have lost connection altogether now, so I will do a fresh install on Pi manager
Thanks for your help
Well, your network is not incorrect. According to those settings you are on the correct network and, since I assume you are on here from that computer, your DNS server appears to be OK as well. I presume that since your gateway and DNS servers are both 191.168.1.1 that it’s a router that is providing DNS. What happens if you change the Home Assistant DNS to 8.8.8.8?
nothing just the same
That is interesting, as is the earlier statement “lost connection altogether”. I wonder if the router might be an issue or the load on the rPi. But you totally reinstalled HA on the pi didn’t you?
Is Home Assistant wired or wireless? If wireless you could, as a test, connect it to your phones hotspot to see if there is any difference and if there is then you know its the router, if not then it’s the rPi or the installation of HA on it.
I did a clean install again on a ssd, it is a wired connection, must be the settings in the configure network settings, I have tried 1.1.1.1 I will reset the router tomorrow.
Hey -
This worked for me with the same issue.
I’m using PiHole on my network as the main DNS, but not quite understanding how DNS is effecting the add-on installer? Thanks!
If you block the DNS then the installer cannot resolve the name and Pi-Hole will just return nothing, that’s the error.
I had this occasionally over the past few month and again just now.
What worked for me:
  1. Go to: Settings → System → Network.
  2. Change IP4 from automatic to static while not changing any values.
  3. save
  4. retry → works
I can only assume the in my case it’s like this: I use Adguard Home on HA itself. I guess sometimes Adguard has not started when HA (re)starts and the update component of HA remembers that instead of rechecking and thinks it’s offline. ‘Changing’ the network settings (while not changing them) apparently resets the offline flag and the updater works fine.
This worked for me although I don’t use Adguard
Nope this did not work for me. I have had this issue for nearly a year now.
My work around for this is to type the following into the console.
ha jobs options --ignore-conditions internet_host
I have been running like this for over a year now.
When I type ha network info into the console I get host_internet: false
While running ha jobs options --ignore-conditions internet_host I get the following warning in settings but I am able to install all updates and everything seems to be working fine.
I have noticed there is a seemingly new reset configuration button on the network settings page. Unfortunately I am 3000km away from home currently and not game enough to test it while I do not have physical keyboard access to my console.
Well I am finally home and clicked the [Reset Configuration] button mentioned above.
FINALLY after a year I have host_internet = true
