I m new hassio stucked in my first code and stucked for 3 hours...need guidance
hi…im new hassio just writen some basic code for my door sernsors and light bulb and its giving me this error can ayone please guide me whats the issue…? whats in line 13 can’t see anything wrong
Invalid config for [automation]: [condition] is an invalid option for [automation]. Check: automation->trigger->0->condition. (See /config/configuration.yaml, line 13). Please check the docs at https://home-assistant.io/components/automation/
Invalid config for [automation]: extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘for’]. Got None
extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘from’]. Got None
extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘to’]. Got None
not a valid value for dictionary value @ data[‘condition’][0][‘conditions’][0][‘condition’]. Got None. (See /config/configuration.yaml, line 13). Please check the docs at
- alias: If the Door opens and motion detected on motion sensor"1" or "2"  turn On the lights
    platform: state
    entity_id: binary_sensor.door_window_sensor_158d000396a32c
    to: 'on'
  condition:
    condition: or
    conditions:
    - condition: state
      entity_id: binary_sensor.motion_sensor_158d0003d19463
      to: 'on'
    - condition: state
      entity_id: binary_sensor.motion_sensor_158d00039571f9
      to: 'on'
    service: light.turn_on
    entity_id: light.ceiling_light_1
- alias: If the Door is Closed and no motion detected turn Off the lights
    platform: state
    to: 'off'
  condition:
    condition: or
    conditions:
    - condition: state
      to: 'off'
      for: '00:02:00'
    - condition: state
      to: 'off'
      for: '00:02:00'
    service: light.turn_off
- alias: If the bathroom Door opens turn On the bathroom lights
    platform: state
    entity_id: binary_sensor.door_window_sensor_158d000396bbb9
    to: 'on'
    entity_id: light.xiaomi_philips_smart_led_ball_2
- alias: If the bathroom Door closes and motion detected on sensor 2 for 05 minute turn off the bathroom lights
    platform: state
    to: 'off'
    conditions:
    - condition: state
      to: 'on'
      for: '00:05:00'
from/to are not valid state conditions. State condition should be like:
- alias: "Security Arm/Disarm"
  initial_state: 'on'
    platform: state
    entity_id: input_boolean.security_status
  condition:
    condition: state
    entity_id: input_boolean.security_automation
    state: 'on'
See more examples at https://www.home-assistant.io/docs/scripts/conditions/ about how to use “for” with conditions.
condition:
  condition: state
  entity_id: device_tracker.paulus
  state: 'not_home'
  # optional: trigger only if state was this for last X time.
  for:
    hours: 1
    minutes: 10
    seconds: 5
It continues to say the issue is on line 13 - I have seen your previous post on this issue where you were getting help.
Looking at the automation documents, it looks like you still have indentation problems (I know you fixed some already).
This:
  condition:
    condition: or
    conditions:
    - condition: state
      to: 'on'
    - condition: state
      to: 'on'
Should be this (if I am reading the documents correctly):
  condition:
    condition: or
    conditions:
      - condition: state
        to: 'on'
      - condition: state
        to: 'on'
The actual condition list was not indented enough.
Let us know if that fixes this issue.
Cheers!
DeadEnd
Change your automation to make the conditions " state: ‘on’ " rather than " to: ‘on’ ". The condition is about the sensors BEING IN THAT STATE, not MOVING to that state.
Here you go, this passes the configuration check:
    platform: state
    to: 'on'
  condition:
    condition: or
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      state: 'on'
You also don’t need the " from: ‘off’ " in the trigger, because a binary sensor can only have two states, if it’s already ‘on’ it won’t trigger, so the only way it can trigger is to be coming from ‘off’.
    platform: state
    to: 'on'
    condition:
      condition: or
      conditions:
      - condition: state
        to: 'on'
      - condition: state
        to: 'on'
    platform: state
    to: 'off'
  condition:
    condition: or
    conditions:
    - condition: state
      to: 'off'
      for: '00:02:00'
    - condition: state
      to: 'off'
      for: '00:02:00'
    platform: state
    to: 'on'
    platform: state
    to: 'off'
  condition:
    condition: or
    conditions:
    - condition: state
      to: 'on'
      for: '00:05:00'
In the first automation, its condition section is indented incorrectly. Move this entire section (9 lines) to the left by two spaces.
In the last condition, you indicate:
    condition: or
but there is only one condition available.
did the corrections but its still giving the same error…
Invalid config for [automation]: extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘to’]. Got None
not a valid value for dictionary value @ data[‘condition’][0][‘conditions’][0][‘condition’]. Got None. (See /config/configuration.yaml, line 13). Please check the docs at https://home-assistant.io/components/automation/
Invalid config for [automation]: [conditions] is an invalid option for [automation]. Check: automation->trigger->0->conditions. (See /config/configuration.yaml, line 13)
anyone please…
Exactly what @123 said… post the code with the changes you made… that error is basically still telling us the condition is indented farther than it should be most likely.
after correction
Invalid config for [automation]: extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘to’]. Got None not a valid value for dictionary value @ data[‘condition’][0][‘conditions’][0][‘condition’]. Got None. (See /config/configuration.yaml, line 13). Please check the docs atInvalid config for [automation]: extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘for’]. Got None extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘from’]. Got None extra keys not allowed @ data[‘condition’][0][‘conditions’][0][‘to’]. Got None not a valid value for dictionary value @ data[‘condition’][0][‘conditions’][0][‘condition’]. Got None. (See /config/configuration.yaml, line 13). Please check the docs at https://home-assistant.io/components/automation/ Invalid config for [automation]: [conditions] is an invalid option for [automation]. Check: automation->trigger->0->conditions. (See /config/configuration.yaml, line 13).
    platform: state
    to: 'on'
  condition:
    condition: or
    conditions:
    - condition: state
      to: 'on'
    - condition: state
      to: 'on'
    platform: state
    to: 'off'
  condition:
    condition: or
    conditions:
    - condition: state
      to: 'off'
      for: '00:02:00'
    - condition: state
      to: 'off'
      for: '00:02:00'
    platform: state
    to: 'on'
    platform: state
    to: 'off'
    conditions:
    - condition: state
      to: 'on'
      for: '00:05:00'
check it please replied
Please try to keep to a single topic - starting another with this same issue leads to tracking issues for resolution… I have replied back with what I believe is the error in line 13 of your automation in the other post you started.
Line 13 indentation is wrong - indent 2 more spaces for the actual conditions.
  condition:
    condition: or
    conditions:
      - condition: state
        to: 'on'
      - condition: state
        to: 'on'
DeadEnd
Your last automation… if bathroom door closes… the condition is indented too far…
The issue isn’t indentation.
The issue is that while triggers are about state CHANGES, conditions are about CURRENT STATE.
    platform: state
    to: 'on'
  condition:
    condition: or
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      state: 'on'
You already have one thread started on this exact same issue, don’t start another one. It’s unnecessary and only clogs up the forums.
Delete one of the threads.
Sure it was. It said so in the very first error message. It was unable to recognize the condition as a valid option. That one definitely needed to be cleared by correcting the indentation.
But, as we all know, that wasn’t the only error message. There were many others including, as you pointed out, the use of invalid options within the condition. That error was also spelled out in the first post (extra keys not allowed).
I opted out after 3 strikes:
  1. not seeing any updated code, just error messages and pleading for help
  2. creation of a parallel topic
  3. receiving an odd Private Message
The author of this topic ought to read the following:
That was useful.
Know when to hold 'em, know when to fold 'em.
yes bro you are very right, i must have violated some terms and conditions of the forum and i regret that, one thing i get that have to improve my basics of coding in order to get any technical help from here.
Creation of parallel topics: it was because i didn’t knew how this forum works, seen people are asking for help every second the i thought my topic must have fallen under and no one will be able to scroll down to that to get replies to solve my issue.
In private message i just tried to get to you to bring into your knowledge that i corrected the code you suggested but it didn’t work, and i was not aware that i have to post updated code every time so just shared the logs until someone asked for code. Anything odd in the private message i didn’t think so.
Although i have violated terms & conditions of forum and for that i regret again.
Please accept my apology for today, next time i’ll be very careful while asking here and please don’t judge me for today’s discussion. I’m just a newbie knows nothing about coding.
Thank you all for helping me today.
ALashari
