iCloud3 Device Tracker v1.0.6 (June 25) - Track devices without iCloud Location Service
iCloud3 v1.0.6 tracks devices when the iCloud Location Service is down is now available
  • iCloud3 will now issue a request_location_update to the IOS app using the HA notification service. If the IOS app is loaded and running, or running in the background and the phone is awake, the IOS App may respond with the current location. Otherwise it is hit-or-miss but better than nothing.It will issue this location request when the next update time is reached in the same manner as requesting the location from the iCloud Location Service.
  • Updated the status on being able to resume accessing the iCloud Location Service.
More information is in the Change Log here
It can be downloaded from the iCloud3 github repository here.
General information and documentation about iCloud3 is here.
Gary aka GeeksterGary
General Description
iCloud3 is a device_tracker custom_component for iPhones, iPads and iWatches. It is tightly integrated with the HA IOS App, uses the Waze Route Tracker for distance and time information, creates Dynamic Stationary Zones when you are stationary, supports device include/exclude filters, minimizes battery usage, and much more.
iCloud3 is a new Home Assistant device tracker custom component that greatly expands the capabilities of the iCloud (and iCloud2) HA component. It exposes many new attributes, provides many new features, is based on enhanced route tracking methods, is much more accurate, and includes additional service calls.
Some of these features include:
  1. A variable polling interval based on the Waze route mapping service (drive time and distance rather than just a calculated straight line distance).
  2. Immediate status update on zone change notification from the bridge IOS App. (enter and exit).
  3. Sensor templates that are used in automations, in scripts and on Lovelace cards are created and updated automatically.
  4. GPS wandering that changes the device’s state from home to not_home randomly is eliminated.
  5. Short 15-second polling when less than 1 mi/km from home (reliably trigger automations based on an accurate distance).
  6. Ability to include or exclude devices or device types (filters for devices you want to track).
  7. Dynamic Stationary Zones (conserve battery life when stationary).
  8. Old location data and GPS accuracy are automatically discarded.
  9. Additional service call commands (setting intervals, pausing and resuming polling, zone assignment, etc.)
  10. No longer need any other program (other than the HA IOS app) to handle device tracking and presence detection (no more Nmap, OwnTracks or router based tracking components).
  11. Configuration variables (18 new variables), Attributes (22 new items returned), Service Calls (10 new subcommands), lines of code (from 425 to 4000+).
  12. And more…
It is now available for download at https://github.com/gcobb321/icloud3. You will find comprehensive documentation and screenshots, all the configuration files, automations and Lovelace card setup that I use for device tracking, and presence detection.
Gary Cobb, aka GeeksterGary
Edited June 8, 2019
Looks good!
You say the IOS app will notify Home Assistant. I assume that means you need to have the IOS app connect over the mobile network (i.e. have the hole punched through the firewall).
Could you please confirm?
Thanks!
Yes, the IOS app needs to be running on the device (iPhone) in order to provide location information to HA. I connect securely through duckkdns and letsencrypt (part of duckkdns) on my Hass.io based rig. There are lots of docs and YouTube videos available that will help you set it up and they will be a lot more useful than I can be.
See HA info on duckkdns here.
See info on the IOS app Here.
Hi Gary,
impressive work - really cool!
A few questions - sorry if the answers are just too obvious, but I couldn’t find them…
ios:
I suppose this should stay in configuration.yaml (as notifications will otherwise stop to work, e.g.)?
Device ID
My iPhone has two identities in known_devices.yaml, one from iCloud and one from the “Device ID” field in the app (Home Assistant for iOS 1.5.0).
Is this kind of “un-intended” behaviour due to me not naming the device in the HASS iOS-app the same as the device is named in iCloud?
Hass iOS-app vs. iCloud - 1
At present, my son’s iPhone is on a separate iCloud account - and tracking his device is based on the device tracker resulting from having the Hass iOS-app installed on his phone. Of course, his phone does not show up with the new attributes from your custom component. How should I configure the component in order to track devices on different iCloud accounts?
Hass iOS-app vs. iCloud - 2
Kind of opposite, my iPad is tracked via iCloud but the Hass iOS-app isn’t installed. However, attributes originating from your component are added to the tracker in Hass. So, what will be the actual difference between devices with or without the Hass iOS-app installed?
Don’t get me wrong - there’s absolutely not any kind af malice in my questions - I’m impressed and it might be not getting the finer details - and I do know some of is kind of not related to your work, but only “exposed” due to the work you’ve done :slight_smile:
Regards,
Chr.
Hi Gary,
I’m posting this here instead of GitHub as I was unable to complete the account creation regime with my current configuration.
I’ve been using icloud2 for several weeks now and still can’t get the location accuracy necessary to open the garage door as i approach the house. I believe I’ve followed your instructions with this device_tracker.yaml entry:
  - platform: icloud3
    username: !secret icloud_user
    password: !secret icloud_passwd
    account_name: gklocation
    include_device: Gary
    exclude_device: GaryOld
  - platform: icloud3
    username: !secret icloud2_user
    password: !secret icloud2_passwd
    account_name: sklocation
    include_device_type: iphone
I’m attempting to setup two phones (7 & 8 running latest iOS), each on their own iCloud account. User account sklocation populates with all the attributes. User account gklocation does not. GaryOld is excluded from tracking as expected, but Gary doesn’t adopt icloud3 attributes. I’ve tried different combinations of include_device, device_type, and as below, called out the devices by name. No luck. Any suggestions?
I’m on 64-bit Hassio V85.1, RPI3b+ and V1.5.0 iOS app on the phone. No errors reported other than the unsupported warning similar to icloud2.
I set this up and nothing happened. I got the notification to authenticate with my iCloud account, but there were no new devices. So I’ve disabled it.
cbh:
ios: Yes
Device ID , Hass iOS-app vs. iCloud - 2 - Yes. The IOS app issues zone enter/exits and pushes location updates to HA; the iCloud Find-my-Friends issues location updates and other device information when asked by iC3. They must map to the same device. If they do not, or if the IOS app is not installed on the device, the zone enter/exits will not be picked up when they actually happen.
They will be updated, however, on the next poll by iC3. The problem with not having the IOS app installed is if you are in a zone and on a 2-hour polling interval, it could be 2-hours before the device goes to a not_home state. With the IOS app, it picks up the zone exit, pushes it to HA, gets picked up by iC3 and changes the state within a minute or two of exiting the zone.
My config is iPhone Settings>General>About=Gary-iPhone, IOS App name=gary_iphone (HA85+) (or garyiphone HA84 and earlier). Special characters (’-’) get mapped to ‘_’ by HA and must be accounted for. I could have set it to Gary_iPhone but didn’t.
Hass iOS-app vs. iCloud - Set up another device_tracker: iCloud3 platform with your other account and have an include_device statement in each account for the device in that account.
@gcobb321:
Thank you very much for the explanation - have reconfigured and now have one device_tracker. per phone (and that from two different iCloud accounts) which seems to work.
Might be the explanation for the delay I had with presence detection (in some way, kind of weird the name proposed in the Hass iOS app isn’t the exact same as the device is called in settings - to avoid this type of mix-up - but that’s another subject).
Looking forward to (the expected) positive change in presence detection :wink:
Thanks again!
@cbh Show your work :thinking:
Nothing original to show - my config is basically copy-pasting from:
  1. The original examples provided at GitHub and
  2. The AppDaemon app “Better Presence” by @helto4real
Most probably, my contribution has been messing up the code while figuring out what to change and what to leave to get it work - so I would definitely suggest looking at the original examples :wink:
OK. I’ll continue to fiddle until both phones’ attributes appear.
Perhaps, something that I can’t show (because I deleted it), could be what you’re looking for:
Changed the device name in iOS settings to something new and added the same in the Hass iOS app - and then removed references to the old names in the config (in .storage\core.device_registry, in .storage\core.entity_registry and in known_devices.yaml).
(And, of course, used the mandatory time for finding groups, automations etc. with the old names that I forgot about first…)
I’ll try your approach if/when I’ve reached my limit… Changing .storage\core.device_registry looks straightforward, but .storage\core.entity_registry lists sensor ID’s. Did you just delete the sensors from the file?
yes - you’re not supposed to do it, you’ll find loads of warnings on the forum about it, I’ve spent hours trying to find where I screwed up while doing it before - you’re warned… Do for crying out loud backup the file before editing it and definitely also stop hass.io… Really…
If you decide to do it anyway (as everybody else):
Make sure to delete the complete entity - and if you’re deleting the last one in the file, that the new “last one” does not have a , after the }
Got it! (i hope)
I use HA ios app device tracking at the moment whereas I used the icloud component in the past. The icloud component really killed my iphone battery (and the one from my wife as well) and it also killed both my apple watch batteries like crazy.
Even with a once per 60 minutes polling it drained the battery really fast. My question is, what is the hit on the battery with this component? Because with only the HA ios app I have great battery life, and automations work great, however it isn’t always as accurate.
I have also had good luck with both BT tracking with my iPhone (not BLE) and using the HA iOS app. No apparent impact to the battery.
How iCloud3 minimizes battery impact
I, the guy that developed the program, have used an iPhone X until December (iPhone XS since then) and have noticed no noticeable effect on the battery. Most of the time I am in a zone (Home and others) that is on a 2-hour inzone (configurable) polling cycle. As soon as I leave the zone, the IOS app generates an exit zone notification and actual polling begins. I just picked 2-hours but it configurable and could be 6, 12 or whatever works best in your situation.
A lot of work has been spent minimizing battery usage and the polling interval calculation is a major part of that… The base iCloud component calculates the polling interval on the distance from home, not the time it will take to get there. iCloud3 uses the driving time/distance from the Waze mapping service (except for the last mile). This makes determining the polling interval much more accurate. For example, it’s a 20-minute drive home – the next poll is in 12-minutes. If, at that poll, I am now 10-minutes from home, the next poll would be in 6-minutes. The interval is determined by taking 60% of the Waze drive time (configurable) until the last mile. Then it goes to a 15-second poll to trigger ‘arrive home’ automations.
Another way it minimizes battery usage is by creating Dynamic Station Zones. If you haven’t moved very much during 2 polling cycles (shopping, friends house, doctors office, the beach, etc), a DSZ is created with the current location and you are now on a 2-hour polling cycle. When you leave the DSZ, the IOS app notifies HA of the zone exit and you are back on the time/distance cycle.
Service Call commands let you pause and resume polling. For example, you are on a trip far from home. It makes no sense to poll the device even though the polling interval would be very large. If you are out of the country I am sure the driving time returned from the Waze service would be unrealistic. When you arrive back in the country, resume polling and it will be gin in 15-seconds.
Gary
It sounds pretty good, I might give it a try. Though my current setup works perfectly fine (only ios HA and tado device tracker). But this seems like what I was searching for when I first started using the icloud (aka idrain) component in hass.
Version .86 - 1/22/2019 now on Github
I just pushed out an update that:
  1. Fixed an issue where a device was not being included if another one with a similar name was in an exclude_device configuration statement.For example, garyold was being excluded, gary was being included but gary was not showing up in the iCloud3.
  2. The tracked_devices attribute now shows the account name the device is associated with to easier troubleshoot device setup for multiple Apple iCloud accounts.
  3. Updated the documentation to include information and examples on multiple accounts, device naming between the device and the HA IOS app, and and explanation of the impact of not using the HA IOS app.
