Hi all,
I would like to control the fan speed by pressing the fan icon buttons (last row). I was able to create the card layout by I don’t know how to interface to the custom component. is there someone that can help me, please?
the javascript below:
import {
LitElement,
html,
css
} from “https://unpkg.com/[email protected]/lit-element.js?module”;
class ComfoAirCard extends LitElement {
static get properties() {
return {
hass: {},
config: {}
render() {
return html`
<ha-card>
<div class="container">
<div class="bg">
<div class="flex-container">
<div class="flex-col-out">
<div>${this.hass.states['sensor.outside_air'].state}°C</div>
<div class="fan-state"><ha-icon icon="mdi:speedometer"></ha-icon></ha-icon> ${Math.trunc(this.hass.states['sensor.fan_speed_supply'].state)} rpm</div>
<div>${this.hass.states['sensor.exhaust_air'].state}°C</div>
<div class="fan-state"><ha-icon icon="mdi:speedometer"></ha-icon> ${Math.trunc(this.hass.states['sensor.fan_speed_exhaust'].state)} rpm</div>
</div>
<div class="flex-col-main">
<div>${this.hass.states[this.config.entity].attributes.temperature}°C</div>
<div><ha-icon class="spin" icon="mdi:${({'auto': 'fan', 'off': 'fan-off', low: 'fan-speed-1', medium: 'fan-speed-2', high: 'fan-speed-3'}[this.hass.states[this.config.entity].attributes.fan_mode])}"></ha-icon></div>
</div>
<div class="flex-col-in">
<div>${this.hass.states['sensor.return_air'].state}°C</div>
<div class="fan-state"><ha-icon icon="mdi:fan"></ha-icon> ${Math.trunc(this.hass.states['sensor.return_air_level'].state)}%</div>
<div>${this.hass.states['sensor.supply_air'].state}°C</div>
<div class="fan-state"><ha-icon icon="mdi:fan"></ha-icon> ${Math.trunc(this.hass.states['sensor.supply_air_level'].state)}%</div>
</div>
</div>
</div>
</div>
<div class="info-row">
${this.getFanTmpl()}
${this.getAirFilterTmpl()}
${this.getBypassTmpl()}
${this.getPreHeatTmpl()}
${this.getSummerModeTmpl()}
</div>
<div class="info-row-fans">
<ha-icon-button id="ca200_fanoff" icon="mdi:fan-off" role="button"></ha-icon-button>
<ha-icon-button id="ca200_fan1" icon="mdi:fan-speed-1"></ha-icon-button>
<ha-icon-button id="ca200_fan2" icon="mdi:fan-speed-2" role="button"></ha-icon-button>
<ha-icon-button id="ca200_fan3" icon="mdi:fan-speed-3" role="button"></ha-icon-button>
</div>
</ha-card>
getFanTmpl(){
if(this.hass.states['binary_sensor.supply_fan'].state == 'on'){
return html`<ha-icon icon="mdi:fan"></ha-icon>`;
}else{
return html`<ha-icon class="inactive" icon="mdi:fan"></ha-icon>`;
getAirFilterTmpl(){
if(this.hass.states['binary_sensor.filter_full'].state != 'on'){
return html`<ha-icon class="inactive" icon="mdi:air-filter"></ha-icon>`;
}else{
return html`<ha-icon class="warning" icon="mdi:air-filter"></ha-icon>`;
getBypassTmpl(){
if(this.hass.states['binary_sensor.bypass_valve'].state == 'on'){
return html`<ha-icon icon="mdi:electric-switch"></ha-icon>`;
}else{
return html`<ha-icon class="inactive" icon="mdi:electric-switch"></ha-icon>`;
getPreHeatTmpl(){
if(this.hass.states['binary_sensor.preheating'].state == 'on'){
return html`<ha-icon icon="mdi:radiator"></ha-icon>`;
}else{
return html`<ha-icon class="inactive" icon="mdi:radiator"></ha-icon>`;
getSummerModeTmpl(){
if(this.hass.states['binary_sensor.summer_mode'].state == 'off'){
return html`<ha-icon icon="mdi:snowflake"></ha-icon>`;
}else{
return html`<ha-icon class="inactive" icon="mdi:weather-sunny"></ha-icon>`;
setConfig(config) {
this.config = config;
// The height of your card. Home Assistant uses this to automatically
// distribute all cards over the available columns.
getCardSize() {
return 7;
static get styles() {
return css`
.container {
padding: 10px;
.bg {
background-image: url(/local/lovelace-comfoair/comfoair_heat.png);
height: 200px;
background-size: contain;
background-repeat: no-repeat;
background-position-y: center
.not-found {
background-color: yellow;
font-family: sans-serif;
font-size: 14px;
padding: 8px;
.flex-container {
display: flex;
justify-content: space-between;
height: 100%;
.flex-col-main {
display: flex;
flex-direction: column;
padding: 30px 0px;
font-size: x-large;
text-align: center;
font-weight:bold;
.flex-col-out {
display: flex;
.flex-col-in {
display: flex;
.fan-state {
padding-top: 15px;
.spin {
animation-name: spin;
animation-duration: 2000ms;
animation-iteration-count: infinite;
animation-timing-function: linear;
.info-row {
background: rgba(0,0,0,0.2);
margin-top: 10px;
padding: 5px;
border-top: rgba(0,0,0,0.4);
-webkit-box-shadow: 0px -4px 3px rgba(50, 50, 50, 0.75);
-moz-box-shadow: 0px -4px 3px rgba(50, 50, 50, 0.75);
box-shadow: 0px -2.5px 3px rgba(0, 0, 0, 0.4);
display: flex;
justify-content: space-around;
.info-row-fans {
margin-top: 10px;
padding: 5px;
display: flex;
.inactive {
opacity: 0.7;
.warning {
color: color: #d80707db;
@keyframes spin {
from {
transform:rotate(0deg);
to {
transform:rotate(360deg);
customElements.define(“comfoair-card”, ComfoAirCard);
