Icon template not showing correct icon
I’m monitoring the battery level of a zwave sensor which is given in integer % and trying to animate the icon on a glance card in response.
I can retrieve the value no problem, but the following template is showing the battery-90 icon when the current level is 100, so should be showing the standard battery icon as it is full.
I have also tried == 100 in the first evaluation instead of >= 99 to no avail.
What am I doing wrong?
        icon_template: >-
          {% if state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int >= 99 %}
            mdi:battery
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 100 %}
            mdi:battery-90
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 90 %}
            mdi:battery-80
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 80 %}
            mdi:battery-70
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 70 %}
            mdi:battery-60
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 60 %}
            mdi:battery-50
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 50 %}
            mdi:battery-40
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 40 %}
            mdi:battery-30
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 30 %}
            mdi:battery-20
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 20 %}
            mdi:battery-10
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 10 %}
            mdi:battery-outline
          {% else %}
            mdi:battery-outline
          {% endif %}
Your tests are upside down.
Assume the battery is 50%. The first test that evaluates to true will be <100.
Order them the other way round, from <10 first to <100 last…
        icon_template: >-
          {% if state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int < 10 %}
            mdi:battery-outline
            mdi:battery-10
            mdi:battery-20
            mdi:battery-30
            mdi:battery-40
            mdi:battery-50
            mdi:battery-60
            mdi:battery-70
            mdi:battery-80
            mdi:battery-90
          {% else %}
            mdi:battery
          {% endif %}
Thanks but that doesn’t work either, I get the battery outline icon so the first test is still evaluating to true (battery level still at 100% in reality)
        icon_template: >-
          {% if state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int <10 %}
            mdi:battery-outline
            mdi:battery-10
            mdi:battery-20
            mdi:battery-30
            mdi:battery-40
            mdi:battery-50
            mdi:battery-60
            mdi:battery-70
            mdi:battery-80
            mdi:battery-90
          {% elif state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int == 100 %}
            mdi:battery
          {% else %}
            mdi:battery-unknown
          {% endif %}
how about playing with this in Template editor?
Where are you putting this template?
Can you show the rest of the sensor config?
What does this evaluate to in the dev tools template editor:
{{ state_attr('states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level', '%')|int }}
Edit: oh I see your problem. That template isn’t right at all
Try this in the template editor:
{{ state_attr('sensor.zwave.kaipule_technology_co_ltd_im20_door_window' 'battery_level') | int }}
If that is ‘unknown’ post your actual sensor entity_id and the attribute name (look them up in the dev tools states menu).
Format should be: {% if state_attr('sensor.entity_id', 'attribute') | int < n %}
it evaluates as true for all values <= 99.
==100 evaluates as false even though that should be true
Edit, the template editor evaluates the following as 100:
{{ states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int }}
This is in my sensor definition so that syntax won’t work, this is what I have at the moment.
Should I have the icon_template as part of the glance card definition instead?
  - platform: systemmonitor
    resources:
      - type: memory_use_percent
      - type: processor_use
      - type: throughput_network_in
        arg: enp1s0f0
      - type: throughput_network_out
        arg: enp1s0f0
    sensors:
      battery_playroomdoor:
        friendly_name: 'Playroom Door Battery'
        value_template: '{{ states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int }}'
        unit_of_measurement: '%'
        icon_template: >-
            mdi:battery-outline
            mdi:battery-10
            mdi:battery-20
            mdi:battery-30
            mdi:battery-40
            mdi:battery-50
            mdi:battery-60
            mdi:battery-70
            mdi:battery-80
            mdi:battery-90
            mdi:battery
          {% else %}
            mdi:battery-unknown
          {% endif %}
      battery_backdoor:
        friendly_name: 'Backdoor Battery'
        value_template: '{{ states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor_2.attributes.battery_level | int }}'
        icon_template: >-
            mdi:battery-outline
            mdi:battery-10
            mdi:battery-20
            mdi:battery-30
            mdi:battery-40
            mdi:battery-50
            mdi:battery-60
            mdi:battery-70
            mdi:battery-80
            mdi:battery-90
            mdi:battery
          {% else %}
            mdi:battery-unknown
          {% endif %}
      door_backdoor:
        friendly_name: 'Backdoor'
        value_template: '{% if states.binary_sensor.kaipule_technology_co_ltd_im20_door_window_sensor_sensor_2 %}
          {% if states.binary_sensor.kaipule_technology_co_ltd_im20_door_window_sensor_sensor_2.state == "on" %}
            Open
          {% else %}
            Closed
          {% endif %}
          {% else %}
          n/a
          {% endif %}'
        icon_template: >-
            mdi:door-open
          {% else %}
            mdi:door-closed
          {% endif %}
      door_playroomdoor:
        friendly_name: 'Playroom door'
        value_template: '{% if states.binary_sensor.kaipule_technology_co_ltd_im20_door_window_sensor_sensor %}
          {% if states.binary_sensor.kaipule_technology_co_ltd_im20_door_window_sensor_sensor.state == "on" %}
            Open
          {% else %}
            Closed
          {% endif %}
          {% else %}
          n/a
          {% endif %}'
        icon_template: >-
            mdi:door-open
          {% else %}
            mdi:door-closed
          {% endif %}
to answer my own question, no this doesn’t work as part of the glance card either
Then your template tests should be like this:
 {% if states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level ) | int <10 %}
Not like this:
Fixed, it correct syntax is:
        icon_template: >-
          {% if  states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <10 %}
            mdi:battery-outline
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <20 %}
            mdi:battery-10
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <30 %}
            mdi:battery-20
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <40 %}
            mdi:battery-30
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <50 %}
            mdi:battery-40
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <60 %}
            mdi:battery-50
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <70 %}
            mdi:battery-60
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <80 %}
            mdi:battery-70
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <90 %}
            mdi:battery-80
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  <100 %}
            mdi:battery-90
          {% elif states.zwave.kaipule_technology_co_ltd_im20_door_window_sensor.attributes.battery_level | int  ==100 %}
            mdi:battery
          {% else %}
            mdi:battery-unknown
          {% endif %}
Thanks for your help everyone!
Just out of interest does this evaluate correctly in the template editor:
{{ state_attr('zwave.kaipule_technology_co_ltd_im20_door_window_sensor', 'battery_level' }}
If it does, you would be better off using that format as it wont generate errors if unknown (i.e. when zwave network is initialising).
Use a variable to avoid repeating the same long-winded expression over and over.
        icon_template: >-
          {% set bl = state_attr('zwave.kaipule_technology_co_ltd_im20_door_window_sensor', 'battery_level')|int %}
          {% if bl < 10 %} mdi:battery-outline
          {% elif bl < 20 %} mdi:battery-10
          {% elif bl < 30 %} mdi:battery-20
          {% elif bl < 40 %} mdi:battery-30
          {% elif bl < 50 %} mdi:battery-40
          {% elif bl < 60 %} mdi:battery-50
          {% elif bl < 70 %} mdi:battery-60
          {% elif bl < 80 %} mdi:battery-70
          {% elif bl < 90 %} mdi:battery-80
          {% elif bl < 100 %} mdi:battery-90
          {% elif bl == 100 %} mdi:battery
          {% else %} mdi:battery-unknown
          {% endif %}
FWIW, it’s possible to reduce this template even more.
yes it does if the missing “)” is added, thanks for that
Good idea @123 thanks for that
In your template, you are using the int filter to convert battery_level to an integer value. If battery_level is unknown, the int filter will report a default value of 0. Given the way the template is currently designed, it will report mdi:battery-outline as opposed to mdi:battery-unknown.
The following template changes the int filter’s default value to -1. Now if the battery_level is unknown it will represented as -1.
        icon_template: >-
          {% set bl = state_attr('zwave.kaipule_technology_co_ltd_im20_door_window_sensor', 'battery_level') | int(default=-1) %}
          {% if bl > 0 %}
            {% else %} mdi:battery-{{ (bl // 10) * 10 }}
            {% endif %}
          {% endif %}
I’m confused as to why you guys aren’t using device_class: battery for the senor. It does this icon template for you without you needing to code it…
Doh!
… but we’re having so much fun with templates.
@sarkyscouser
Yah, no point in templates though!
Much shorter config :wink:
Haha! Oh dear. Well that’s something I won’t forget.
To be fair there’s no indication on that page about the battery icon changing, so unless you’ve used it, it’s an easy thing to miss.
@petro
You reminded me of something from long ago. As young engineers we made the following observation:
Being so ‘heads down’ solving a problem that you don’t have time to look up and see the solution.
It can be a hard habit to break …
