Fabulous! thatās exactly the help i neededā¦thank you ! Iāll be setting up all the Ceiling and Side Lights like this i thinkā¦
I just updated the blueprint and see that itās been implemented in the automation.
However, the change doesnāt seem to be working for me.
not_from: āunavailableā
not_to: āunavailableā
When I reload the Matter integration, the last event is still triggered and executed.
However, the logging shows that the device was unavailable.
Am I doing something wrong?
Can you be specific on what you event is triggered? Are you restarting the integration or restarting the matter add on or the OTBR? Iām afraid I would need more detail.
I have a custom āpartyā light script that changes groups of lights on a button press through the color wheel. My first lesson was if any such loop doesnāt self terminate it has to have a corresponding button or manually issued command to stop the script or it will run forever to the exclusion of other scripts (depending on mode: ). Taking the batteries out of my controller after the script starts and putting them back in does not re-start my script. Neither does restarting the Matter Add on. Any detail you can provide would be helpful.
The trigger last used in the automation is restarted when you restart the matter integration.
The result could be, for example, a light turning on without you even knowing it.
So, it seems to still trigger in the unavailable state, despite the adjustment you made to the blueprint.
However, Iāve since created an automation myself where this doesnāt happen.
So, the issue is now resolved for me.
Do you mind sharing?
Thank you for the blueprint. Itās been working perfectly so far.
The only thing I changed in the blueprint is that I replaced the long-press release with a simple long-press action.
I think this gives a much better user experience because you see the result of the action immediately when the long press is completed. Otherwise, you donāt know how long youāre supposed to press for it to count as a ālong pressā.
Hi - @hasenpups Iād be interested in the change you made - could you please share? Many thanks
@hansenp I love that
, would you care to add your edits to my github (if you are tracking) and or paste them here and I can update them for everyone?
@kalmma same with your changes. I would love to make sure this is as complete as possible for everyone.
@censay could this be an example on long_press change:
# IKEA BILRESA E2489 Dual Button
# Blueprint Template v1.0.4
# Internal Versioning:
# schema_version: 1.0.4
# last_updated: 2026-01-18
# Changelog:
# v1.0.4: Added Long Press to triggend during long press when button are still held down (long_press)
# v1.0.3: Added not_from/not_to filters to prevent re-triggering on HA/Matter restarts (https://community.home-assistant.io/t/ikea-bilresa-matter-button-blueprint-for-ikea-matter-over-thread-button-actions-scripts-and-entities/962344/12)
# v1.0.2: Initial release
# Power-User Notes:
# - This device exposes two event entities, one per physical button.
# - You must select the correct event entity for Button 1 and Button 2.
# - Each press updates the entity state (timestamp) and sets attributes.event_type.
blueprint:
name: IKEA BILRESA E2489 Dual Button (Matter)
author: censay,bjornh
description: >
Full-featured automation for the IKEA BILRESA E2489 Matter dual-button
remote. Supports single press, double press, and long press (on release)
for both buttons. Uses event entities exposed by Home Assistant for
Matter devices. Single-press actions are prioritized for reliability.
domain: automation
source_url: https://github.com/censay/haos-blueprints
homeassistant:
min_version: 2025.12.1
input:
target_device:
name: BILRESA Button Device
description: >
Select the IKEA BILRESA E2489 matter device.
selector:
device:
filter:
- manufacturer: IKEA of Sweden
button1_event:
name: Button 1 ā Event Entity
description: >
Select the event entity for Button 1 (for example:
event.bilresa_dual_button_button_1_2).
selector:
entity:
domain: event
button2_event:
name: Button 2 ā Event Entity
description: >
Select the event entity for Button 2 (for example:
event.bilresa_dual_button_button_2_2).
selector:
entity:
domain: event
# BUTTON 1 ACTIONS
button1_single:
name: Button 1 ā Single Press
description: Action for Button 1 single press (multi_press_1).
default: []
selector:
action: {}
button1_double:
name: Button 1 ā Double Press
description: Action for Button 1 double press (multi_press_2).
default: []
selector:
action: {}
button1_long:
name: Button 1 ā Long Press (on release)
description: Action for Button 1 long press completion (long_release).
default: []
selector:
action: {}
button1_long_press:
name: Button 1 ā Long Press (held down)
description: Action for Button 1 long press during button are down (long_press).
default: []
selector:
action: {}
# BUTTON 2 ACTIONS
button2_single:
name: Button 2 ā Single Press
description: Action for Button 2 single press (multi_press_1).
default: []
selector:
action: {}
button2_double:
name: Button 2 ā Double Press
description: Action for Button 2 double press (multi_press_2).
default: []
selector:
action: {}
button2_long:
name: Button 2 ā Long Press (on release)
description: Action for Button 2 long press completion (long_release).
default: []
selector:
action: {}
button2_long_press:
name: Button 2 ā Long Press (held down)
description: Action for Button 2 long press during button are down (long_press).
default: []
selector:
action: {}
# AUTOMATION LOGIC
variables:
button1_entity: !input button1_event
button2_entity: !input button2_event
- platform: state
entity_id: !input button1_event
not_from: 'unavailable'
not_to: 'unavailable'
- platform: state
entity_id: !input button2_event
# Added not_from/not_to filters to prevent re-triggering on HA/Matter restarts; event entities use timestamp states
condition: []
- variables:
press_type: "{{ trigger.to_state.attributes.event_type }}"
trigger_id: "{{ trigger.id }}"
- choose:
# BUTTON 1
- conditions:
- condition: template
value_template: >
{{ trigger_id == 'button1' and press_type == 'multi_press_1' }}
sequence: !input button1_single
- conditions:
value_template: >
{{ trigger_id == 'button1' and press_type == 'multi_press_2' }}
sequence: !input button1_double
- conditions:
value_template: >
{{ trigger_id == 'button1' and press_type == 'long_release' }}
sequence: !input button1_long
- conditions:
value_template: >
{{ trigger_id == 'button1' and press_type == 'long_press' }}
sequence: !input button1_long_press
# BUTTON 2
- conditions:
value_template: >
{{ trigger_id == 'button2' and press_type == 'multi_press_1' }}
sequence: !input button2_single
- conditions:
value_template: >
{{ trigger_id == 'button2' and press_type == 'multi_press_2' }}
sequence: !input button2_double
- conditions:
value_template: >
{{ trigger_id == 'button2' and press_type == 'long_release' }}
sequence: !input button2_long
- conditions:
value_template: >
{{ trigger_id == 'button2' and press_type == 'long_press' }}
sequence: !input button2_long_press
mode: restart
I added the BILRESA dual button via Zigbee2MQTT. Would this blueprint work in that case as well?
Thank you for the sample. I did it in exactly this way.
@censay can you integrade the option for the long_press into you solution?
Can you share your long press action you mentioned earlier and clarify the user experience you are seeking? Either here or as a github suggestion/issue.
Thanks!
I use exactly this implementation: IKEA BILRESA Matter Button š [Blueprint] for Ikea *Matter over Thread* Button (Actions, Scripts, and Entities)! - #29 by bjornh1337
I cant get this script to dim up or down when long press. Only steps by pressing multiple times on the button.
How does long press is working here? Is it possible to start some action when starting to hold the button and stop the action when the button is released?
Long press will activate something when the button is released. Putting in smoothly changing lighting into the core script over engineered it.
The different types of button presses are listed in the blueprint. Single-press, double-press, long-press-release. Those are 3 modes for the button.
Adding in dimming requires looping logic (although each HAOS update brings new things to triggers that simplify things). I personally have never had success with transition times provided through the UI. And each type of bulb likes to handle brightness a little differently.
Thanks, this is just what I was looking for.
I just updated the blueprint thanks to a community contribution to incorporate long press (on press) in addition to the current (on release)!
To celebrate Iām sharing āpartyā
mode script I use with my Bilresa on a group of lights grouped as āAttic lightsā. You can save this in homeassistant/scripts.yaml and assign a button to turn it on. It runs a maximum of 4 times to avoid an infinite loop. I assign the second button to āstopā the script which freezes it at whatever color it was displaying.
/homeassistant/scripts.yaml
cycle_neon_colors_on_selected_lights:
alias: Cycle Neon Colors on Selected Lights
mode: restart
sequence:
- variables:
presets:
- name: Neon Red
hs:
- 0
- 100
- name: Hot Pink
hs:
- 330
- 100
- name: Neon Magenta
hs:
- 300
- 100
- name: Electric Purple
hs:
- 280
- 100
- name: Neon Blue
hs:
- 220
- 100
- name: Neon Teal
hs:
- 180
- 100
- name: Lime Green
hs:
- 100
- 100
- name: Neon Yellow
hs:
- 60
- 100
- name: Neon Orange
hs:
- 20
- 100
target_lights: '{{ target_lights | default(''light.attic_lights'') }}'
dwell_seconds: '{{ dwell_seconds | default(5) }}'
transition_seconds: 3
max_loops: 15
- repeat:
count: '{{ max_loops }}'
sequence:
- repeat:
for_each: '{{ presets }}'
sequence:
- action: light.turn_on
entity_id: '{{ target_lights }}'
hs_color: '{{ repeat.item.hs }}'
brightness: 255
transition: '{{ transition_seconds }}'
- delay: '{{ dwell_seconds }}'
Hopefully they work for you, these lights are full RGB Linkind Matter bulbs, and I have bulbs are very particular about their RGB :).
Iām honestly clueless on how to use your blueprint. Itās the first blueprint I ever used so far.
I selected the light and the two event buttons in your setup dialog. When I save, I get an error that the sensor buttons are missing. The remote has no sensor buttons, so what should I place there?
My intention is to control a Kajplats light. I expected to just define the light and the two buttons and everything would just work out of the box. Maybe I missed somethingā¦
