Ikea FYRTUR and zigbee2mqtt, buttons grey
Hi, after a homeassistant update, the up/down buttons are gone. In the web interface from the zigbee2mqtt, slider and close/open buttons are available and functional. I tried to remove the entity and re-add it, but the behavior is the same.
Any ideas? thanks
Hi, I had the same Problem and could solve it with this post:
https://community.home-assistant.io/t/cover-entities-stopped-working-with-2021-6-update/314957
I had to update my zigbee2mqtt plugin + repository path, therefore I did:
  1. stop and uninstall the zigbee2mqtt plugin
  2. add the new repository path on the plugin side.
https://github.com/zigbee2mqtt/hassio-zigbee2mqtt
  1. install zigbee2mqtt from the new repository
  2. copy the old zigbee2mqtt configuration files from /share/zigbee2mqtt to /config/zigbee2mqtt. See: Updating zigbee2mqtt when i've installed from an old repo - #3 by dawsonweb
    I used the samba share plugin to do this via my Laptop.
  3. Start the plugin. Everything should now work like before
I hope this helps you!
Thanks, changed the repo, restored the config
FYRTUR working again
I forgot that I added the repo manually …
