Trigger actions from the “dot” buttons on an IKEA SOMRIG shortcut button. Tap, double-tap, long press and long release are all supported. Requires an IKEA DIRIGERA hub connected to Home Assistant via the Matter integration.
Based on Lorenzo Cecchelli’s ZHA blueprint. Adapted for the Matter integration by Edward Wright.
blueprint:
name: Matter - IKEA SOMRIG Shortcut Button (Model E2213) V1.0
description: Trigger actions from the "dot" buttons on an IKEA SOMRIG
via the [Matter integration](https://www.home-assistant.io/integrations/matter).
Based on [Lorenzo Cecchelli](https://community.home-assistant.io/u/cecche/summary)'s
[ZHA blueprint](https://community.home-assistant.io/t/ikea-somrig-remote-e2213-zha/668671).
Adapted for the Matter integration by [Edward Wright](https://community.home-assistant.io/u/fasteddy516/summary).
author: Edward Wright
domain: automation
input:
single_dot_button:
name: '"Single Dot" Button Event'
description: The entity corresponding to the single dot button event.
selector:
entity:
multiple: false
filter:
- integration: matter
domain: event
device_class: button
double_dot_button:
name: '"Double Dot" Button Event'
description: The entity corresponding to the double dot button event.
selector:
entity:
multiple: false
filter:
domain: event
lockout_time:
description: The time to wait before accepting another button press after a
button press has been detected. Use this to prevent multiple actions from
being triggered by a single button press.
default: 250
selector:
number:
min: 0
max: 1000
unit_of_measurement: milliseconds
mode: slider
single_dot_single_press:
name: "Action: Single Dot > Tap"
default: []
selector:
action: {}
single_dot_double_press:
name: "Action: Single Dot > Double Tap"
default: []
selector:
action: {}
single_dot_long_press:
name: "Action: Single Dot > Long Press"
default: []
selector:
action: {}
single_dot_long_release:
name: "Action: Single Dot > Release after Long Press"
default: []
selector:
action: {}
double_dot_single_press:
name: "Action: Double Dot > Tap"
default: []
selector:
action: {}
double_dot_double_press:
name: "Action: Double Dot > Double Tap"
default: []
selector:
action: {}
double_dot_long_press:
name: "Action: Double Dot > Long Press"
default: []
selector:
action: {}
double_dot_long_release:
name: "Action: Double Dot > Release after Long Press"
default: []
selector:
action: {}
mode: single
max_exceeded: silent
- platform: state
entity_id:
- !input single_dot_button
- !input double_dot_button
- variables:
single_dot: !input single_dot_button
double_dot: !input double_dot_button
- choose:
- conditions:
- condition: template
value_template: >-
{{ trigger.entity_id == single_dot
value_template: >-
{{ trigger.to_state['attributes']['event_type'] == 'multi_press_1'
sequence: !input single_dot_single_press
- conditions:
value_template: >-
value_template: >-
{{ trigger.to_state['attributes']['event_type'] == 'multi_press_2'
sequence: !input single_dot_double_press
- conditions:
value_template: >-
value_template: >-
{{ trigger.to_state['attributes']['event_type'] == 'long_press'
sequence: !input single_dot_long_press
- conditions:
value_template: >-
value_template: >-
{{ trigger.to_state['attributes']['event_type'] == 'long_release'
sequence: !input single_dot_long_release
- conditions:
value_template: >-
{{ trigger.entity_id == double_dot
value_template: >-
sequence: !input double_dot_single_press
- conditions:
value_template: >-
value_template: >-
sequence: !input double_dot_double_press
- conditions:
value_template: >-
value_template: >-
sequence: !input double_dot_long_press
- conditions:
value_template: >-
value_template: >-
sequence: !input double_dot_long_release
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: !input lockout_time
