Ikea Styrbar not working after firmware upgrade
Same for me.
what helps:
Removing batteries for a second.
than the styrbar works again for ??? 24 hours.
(could smash them at my wall)
new firmware seems to send the styrbar in some zombie sleep mode.
probably solutions/ideas:
  • keep alive trigger from HA/Zigbee2MQTT
  • treading the zombie commands as regular commands.
Very strange that mine is working since I got the initial problem fixed…
It’s rather FYI than help, but it seems that IKEA is at least aware of the problem. I found this post on Reddit:
https://www.reddit.com/r/tradfri/comments/1d8yk1w/styrbar_remotes_not_working_properly_anymore/
Thanks Netpoet.
That’s great to hear. Hopefully they’ll find a resolution soon, as they say it has been prioritised 27 days ago.
At my end, it is frustrating as I use Command strips to put them on the wall, so need to keep taking them down and replacing them, just to get them to work.
I’m afraid to update the firmware on any of my IKEA items now.
After the last update and everything not working I was a bit mad at myself. Why even bother doing updates if everything worked before.
Difficult to fully see through but never change a running system is still a valid approach most of tge time.
Good luck.
I’m getting notified about a new firmware version to update
0x02040016 replacing 0x02040011.
Has anyone tried this?
I don’t have a notification, possibly because all of my Styrbar’s are sleeping at the moment.
I woke one of them up, but it’s not getting any notification. I’ve hit the ā€œcheck for updateā€ button a few times.
I think most of mine are on 0x0204001:
Firmware version: 2.4.11
IKEA don’t seem to list any update to Styrbar firmware on their release notes site:
https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html
Where can I see what version is being suggested as an update? One of mine is still on old firmware, so I’m not going to update until we have a confirmed fix.
Seems to be fixing an issue that’s was caused by the last update : https://www.reddit.com/r/tradfri/comments/1e4lq3f/styrbar_firmware_version_2416/
Thanks Seano.
I’m trying to get mine to update, but it hasn’t found the update yet for the one I’m testing on.
I’ll have to take a few more down and wake them up and try them also.
z2m: No update available for ā€˜Playroom switch’
Same issue here. Everything was great until I upgraded. None of the workarounds listed above work for me. The remote goes offline after a random number of days and the only fix is to pull the batteries for a few seconds.
When a new firmware is released, do you guys update via Z2M ota? Or is there a better method?
Hi John,
Unfortunately mine is still telling me there is no update, or else is falling asleep before I can check.
I’m attempting to update via Z2M.
Don’t know if there is a better method.
I have the same issue.
I’ve checked Ikea thread and should be available the fw 2.4.16 that should solve the issue.
The problem appears that the update only appears on IKEA Hub.
Need help to check why Zigbee2Mqtt cannot find the upgrade available? Can it be done manually?
That’s what I was hoping for also Maverick, some help to make Z2M complete the upgrade.
Does anyone know?
I Hope also that anyone can answer this
In case this helps anyone:
The updates to 2.4.16 have started to pop up for at least two of my eight Styrbars this morning. I have updated one of them successfully so far. The dropouts used to happen after at least a few days for me, so it’s too early to tell whether the update fixes the problem. Fingers crossed.
I have upgraded my Styrbars to 2.4.16.
It indeed seems to have solved the buttons issue (I prefer to let one or two weeks pass to confirm), but they now seem to have lost the ability to bind to groups. Anyone has been able to do that?
I went and bought the Dirigera hub from IKEA, updated one switch and it seemed to be good, but then I was away for a while and now I see that HA is able to update them. Bit of a waste. Thankfully all seem to be updated now, so will have to give it a few days to see if its all ok.
How are you getting the OTA update exactly? I’m on Z2M and am still getting ā€œNo Update Availableā€.
When I wake them up, I keep hitting check for update and after a few tries it is available.
Anyone have long term feedback after upgrading to 2.4.16 ?
Im still on 2.4.5 and wondering if I should upgrade…
