IKEA STYRBAR Remote (E2002) for Matter
Trigger actions from the four buttons on an IKEA STYRBAR remote control. Tap, long press and long release are supported on the up/down buttons, and tap is supported on the left/right buttons. Requires an IKEA DIRIGERA hub connected to Home Assistant via the Matter integration.
Tested with:
  • Home Assistant 2024.10.4
  • DIRIGERA firmware 2.660.5
  • STYRBAR (E2002) firmware 2.4.16
Note: While writing automations for various IKEA remotes via Matter I have come across many inconsistencies in the Matter implementation from model to model. This has - unfortunately - resulted in a bunch of model-specific blueprints designed to work around these differences where possible.
This remote is more than a little strange in the way it sends events to Home Assistant, which results in some unusual behaviour that I have not found a way to work around:
  1. initial_press events are sent immediately when any button is pressed, regardless of whether the button is tapped or held down. This means the only way to distinguish between a tap and a long press is to look for the short_release event. Because of this, tap events for the up and down buttons are processed when the button is released, not when it is pressed. Why just up and down? Because…
  2. …the left and right buttons only send initial_press events, so there are no long press or long release actions for these buttons. This also means that tap events for the left and right buttons are processed when the button is pressed, not when it is released as with the up and down buttons. This is great, except…
  3. …if either the left or right button is held down, the remote only sends a short_release event for the ‘up’ button. So yes, this means that holding either of these buttons will trigger the tap action for the up button instead. And no, I have no idea why it works like this. I don’t send the events, I just deal with what shows up!
One issue that could be worked around is that this remote regularly sends duplicate events for the same button press. The Lockout Time provided in this blueprint is intended to remedy this by blocking any further button actions for the specified amount of time.
Based on Lorenzo Cecchelli’s ZHA blueprint for SOMRIG shortcut buttons.
Adapted for STYRBAR and the Matter integration by Edward Wright.
blueprint:
  name: Matter - IKEA STYRBAR Remote control (Model E2002) V1.0
  description: >
    [Matter integration](https://www.home-assistant.io/integrations/matter).
    Tested with:
    * Home Assistant 2024.10.4
    * DIRIGERA firmware 2.660.5
    * STYRBAR (E2002) firmware 2.4.16
    not found a way to work around.
    1) 'initial_press' events are sent immediately when any button is pressed,
    for the 'short_release' event.  Because of this, tap events for the
    when it is pressed.  Why just up and down?  Because...
    2) ...the left and right buttons only send 'initial_press' events, so
    down buttons.  This is great, except...
    3) ...if either the left or right button is held down, the remote only sends
    a 'short_release' event for the 'up' button.  So yes, this means that holding
    And no, I have no idea why it works like this.  I don't send the events, I
    Based on [Lorenzo Cecchelli](https://community.home-assistant.io/u/cecche/summary)'s
    [ZHA blueprint](https://community.home-assistant.io/t/ikea-somrig-remote-e2213-zha/668671)
    [Edward Wright](https://community.home-assistant.io/u/fasteddy516/summary).
  author: Edward Wright
  domain: automation
  input:
    up_button:
      name: '"Up" Button Event'
      description: The entity corresponding to the up button event.
        (Up = "big sun" icon with detent)
      selector:
        entity:
          multiple: false
          filter:
            - integration: matter
              domain: event
              device_class: button
    down_button:
      name: '"Down" Button Event'
      description: The entity corresponding to the down button event.
        (Down = "little sun" icon with no detent)
      selector:
        entity:
          multiple: false
          filter:
              domain: event
    left_button:
      name: '"Left" Button Event'
      description: The entity corresponding to the left button event.
      selector:
        entity:
          multiple: false
          filter:
              domain: event
    right_button:
      name: '"Right" Button Event'
      description: The entity corresponding to the right button event.
      selector:
        entity:
          multiple: false
          filter:
              domain: event
    lockout_time:
      description: The time to wait before accepting another button press after a
        button press has been detected. Use this to prevent multiple actions from
        being triggered by a single button press.
      default: 250
      selector:
        number:
          min: 0
          max: 1000
          unit_of_measurement: milliseconds
          mode: slider
    up_tap:
      name: "Action: Up > Tap"
      description: Triggered when the 'up' button is released.
        (Also triggered by holding the left or right button.)
      default: []
      selector:
        action: {}
    up_long_press:
      name: "Action: Up > Long Press"
      default: []
      selector:
        action: {}
    up_long_release:
      name: "Action: Up > Release after Long Press"
      default: []
      selector:
        action: {}
    down_tap:
      name: "Action: Down > Tap"
      description: Triggered when the 'down' button is released.
      default: []
      selector:
        action: {}
    down_long_press:
      name: "Action: Down > Long Press"
      default: []
      selector:
        action: {}
    down_long_release:
      name: "Action: Down > Release after Long Press"
      default: []
      selector:
        action: {}
    left_tap:
      name: "Action: Left > Tap"
      default: []
      selector:
        action: {}
    right_tap:
      name: "Action: Right > Tap"
      default: []
      selector:
        action: {}
mode: single
max_exceeded: silent
triggers:
- trigger: state
  entity_id:
    - !input up_button
    - !input down_button
    - !input left_button
    - !input right_button
actions:
  - variables:
      up: !input up_button
      down: !input down_button
      left: !input left_button
      right: !input right_button
  - choose:
    - conditions:
        - condition: template
          value_template: >-
            {{ trigger.to_state['attributes']['event_type'] == 'initial_press'
          value_template: >-
            {{ trigger.entity_id == left
      sequence:
        - choose:
          - conditions:
                value_template: >-
            sequence: !input left_tap
        - delay:
            hours: 0
            minutes: 0
            seconds: 0
            milliseconds: !input lockout_time
    - conditions:
          value_template: >-
          value_template: >-
            {{ trigger.entity_id == right
      sequence:
        - choose:
          - conditions:
                value_template: >-
            sequence: !input right_tap
        - delay:
            hours: 0
            minutes: 0
            seconds: 0
    - conditions:
          value_template: >-
            {{ trigger.to_state['attributes']['event_type'] == 'short_release'
      sequence:
        - choose:
          - conditions:
                value_template: >-
                  {{ trigger.entity_id == up
            sequence: !input up_tap
          - conditions:
                value_template: >-
                  {{ trigger.entity_id == down
            sequence: !input down_tap
        - delay:
            hours: 0
            minutes: 0
            seconds: 0
    - conditions:
          value_template: >-
            {{ trigger.to_state['attributes']['event_type'] == 'long_press'
      sequence:
        - choose:
          - conditions:
                value_template: >-
            sequence: !input up_long_press
          - conditions:
                value_template: >-
            sequence: !input down_long_press
        - delay:
            hours: 0
            minutes: 0
            seconds: 0
    - conditions:
          value_template: >-
            {{ trigger.to_state['attributes']['event_type'] == 'long_release'
      sequence:
        - choose:
          - conditions:
                value_template: >-
            sequence: !input up_long_release
          - conditions:
                value_template: >-
            sequence: !input down_long_release
        - delay:
            hours: 0
            minutes: 0
            seconds: 0
Thank you very much for this integration, it comes in very handy :slight_smile:
How would you implement long-presses for changing the brightness? Long press up to increase it as long as you press it. Long pressing down would be decreasing it. Just like in the original Ikea app.
My current approach just does one step on long press:
action: light.turn_on
  entity_id: light.wohnzimmer
  brightness_step_pct: 10
Many thanks for this blueprint. Any possibility to make one for the old Ikea ON/OFF Switch E1743 and the Ikea Shortcut Button E1812 ?
I have Dirgera conncetd to HA with Matter, and I do not seem to get these devices working with the standard automation, as this gives only events.
I believe this would require a different style of script/automation, one that would accept one event (the long press) and repeatedly adjust the brightness up/down until another event (the long release) is received. I’m not sure how that would be implemented.
I have a number of E1743 TRADFRI On/Off switches and am going to make an automation for them.
I don’t have any E1812 shortcut buttons, though, and for some reason the events received through Matter are not consistent from model to model, so I would need to know details about the events that get sent in order to make an automation.
The automation I’m using for E1743 can be found here. Note that this remote only sends initial_press events, which means only tap events are supported by my automation.
As far as the E1812 button goes, I don’t have one to test with, but I do have an automation here that you can use to help identify which button events the E1812 sends out and supports. That would allow me to put something together for the E1812, or determine if it will just work with an existing blueprint.
