Nick4
(Nick)
June 29, 2021, 11:03pm
1
Controller: Conbee II
Integration: deCONZ
Remote: IKEA Symfonisk Rotary Remote
I have used
ZHA, deCONZ, Zigbee2MQTT - Ikea E1744 SYMFONISK rotary remote Universal blueprint - all actions - control lights, media players and more with Hooks
and
Media Player Hook - Control any media player (play/pause, volume, prev/next track) with one of the supported controllers
I am using the Logitech Squeezebox for my mediaplayers.
Automations:
- id: '1625332892547'
alias: Controller - IKEA E1744 SYMFONISK Rotary Remote
description: ''
use_blueprint:
path: EPMatt/ikea_e1744.yaml
input:
integration: deCONZ
controller_device: cc744586ed184a772321a7299bed5723
action_rotate_left:
- service: media_player.volume_up
entity_id: media_player.kitchen
action_rotate_right:
- service: media_player.volume_down
rotate_left_loop: true
rotate_right_loop: true
- id: '1625333025763'
alias: Hook - Media Player
description: ''
use_blueprint:
path: EPMatt/media_player.yaml
input:
controller_model: IKEA E1744 SYMFONISK rotary remote
media_player: media_player.kitchen
Automation does get triggered but nothing happens.
From the log:
Logger: homeassistant.components.automation.controller_ikea_e1744_symfonisk_rotary_remote
Source: helpers/script.py:1341
Integration: Automation (documentation, issues)
First occurred: 12:48:38 AM (4 occurrences)
Last logged: 12:48:39 AM
Controller - IKEA E1744 SYMFONISK Rotary Remote: Error executing script. Invalid data for call_service at pos 3: not a valid value for dictionary value @ data['entity_id']
Have you made sure that the device you’re telling it to control is right? Because it looks like it might not be.
koying
(Chris B)
June 30, 2021, 3:27pm
3
Put otherwise, OP, please show the source of your automations.
Nick4
(Nick)
June 30, 2021, 3:48pm
4
Thanks guys for stepping in!
In the visual editor I have chosen DD1 (which is the altered name from the remote in Phoscon)
- id: '1624872791126'
description: ''
use_blueprint:
input:
integration: deCONZ
action_rotate_left:
Nick4
(Nick)
July 3, 2021, 5:46pm
6
Still struggling to get this working…
Is this so obvious or exotic?
koying
(Chris B)
July 3, 2021, 6:11pm
7
What is behind media_player.kitchen?
Nick4
(Nick)
July 3, 2021, 6:19pm
8
Hi @koying ; it’s a picoreplayer (RPi) connected to Logitech Media Server
Nick4
(Nick)
July 3, 2021, 9:48pm
9
Also nothing happens when I exchange the media player for a light.
koying
(Chris B)
July 4, 2021, 7:44am
10
I can’t see.
I’ll just put here a similar blueprint automation of mine.
The syntax for calling services is different than yours, bit IDK if it matters.
- id: '1610279516253'
alias: Hue Remote Switch Bureau
description: ''
use_blueprint:
path: homeassistant/hue_remote_zha.yaml
input:
hue_remote: sensor.hue_remote_bureau
remote_off_short_press:
- service: light.turn_off
data: {}
entity_id: light.lumieres_bureau
remote_on_short_press:
- service: light.turn_on
data: {}
remote_up_short_press:
- scene: scene.bright_bureau
Nick4
(Nick)
July 4, 2021, 6:18pm
11
Thanks for anyway helping @koying
I’m really stuck here, have read the docs over and over again but have no clue what is wrong, where to look and how to solve this.
Nick4
(Nick)
July 5, 2021, 10:50am
12
Anybody?
From the automation trace process:
Stopped because an error was encountered at July 3, 2021, 11:44:45 PM (runtime: 0.01 seconds)
Any idea what this might be?
koying
(Chris B)
July 5, 2021, 10:54am
13
Did you try to adapt your code to a syntax similar to mine?
Nick4
(Nick)
July 5, 2021, 10:59am
14
Hi Chris, no I didn’t because I have no clue how to fit this with my situation.
koying
(Chris B)
July 5, 2021, 11:03am
15
Try to remove target: and align entity_id: with service:
Nick4
(Nick)
July 5, 2021, 11:16am
16
This is what I have now:
description: ''
use_blueprint:
input:
integration: deCONZ
action_rotate_left:
data: {}
data: {}
Trace Timeline:
Triggered by the event 'deconz_event' at July 5, 2021, 1:12:39 PM
Test multiple conditions using "and"
Delay for {"milliseconds":0}
Define variables trigger_action, trigger_delta, last_controller_event
Call service input_text.set_value
Stopped because an error was encountered at July 5, 2021, 1:12:39 PM (runtime: 0.01 seconds)
Nick4
(Nick)
July 5, 2021, 9:27pm
17
@epmatt : do you have an idea what might be wrong?
Shouldn’t that entity_id be part of the data, rather than a separate value?
Nick4
(Nick)
July 6, 2021, 6:42pm
19
Don’t know @Fuzzysteve , I’m completely lost here with this problem.
epmatt
(Matteo Agnoletto)
July 7, 2021, 4:56pm
20
Hi @Nick4 @FuzzySteve ,
While configuring the blueprint you need to provide a valid input_text entity for the helper_last_controller_event input, as described in the Inputs section in the E1744 blueprint documentation .
You can find additional details regarding this mandatory input in the general Controller-Hooks Ecosystem documentation .
Please let me know if adding the missing blueprint input solves your issue.
Thank you!
