Continuing the discussion from IKEA TRADFRI Remote (5 button version) through ZHA events:
Okay, so… I have one of these devices from Ikea, and had it set up with the above automation to nicely control my Floalt panel. I then got two of the Tradfri outlets, and proceeded to set up one of them using a the two-button dimmer button. For the second, I tried to add it to ZHA using an ikea button (the just-one-button click one), but I couldn’t get it to pair, so I used to the 5-button remote. And it showed up fine that way, and I could then use an automation (specifically ZHA - IKEA Tradfri Shortcut button debounced) to make the button work to control it. (Weirdly, I can’t make an automation other than the blueprint with that button for some reason… it just doesn’t respond. But the blueprint works.)
But now… ooops. The 5-way remote is directly linked to that outlet. Not what I intended. Eventually, removed it, did the 4-click reset on the remote, and added it back again. It was discovered just fine… but now it doesn’t work. It shows up in ZHA like this:
… with “Desk Two?” being my attempt at getting it to work with the a new automation from IKEA TRADFRI Remote (5 button version) through ZHA events. The “Last Seen” time is just now, when I pressed the button. But the automation says “Never” under last-triggered, still.
What did I do wrong, and how can I fix it?
