Ikea Trådfri remote automation
I have successfully made automation for my Trådfri remote. This automation really clutters my automations, when I use multiple remotes as I have to make new automation for every trigger.
Can someone help how to include all these triggers in one automation? My code is below:
- id: '1558223144069'
  alias: MQTT IKEA remote livingroom on/off
    - platform: mqtt
      topic: 'zigbee2mqtt/0x000d6ffffe54fd83'
  condition:
    - condition: template
      value_template: "{{ 'toggle' in trigger.payload }}"
    entity_id: light.0x00124b001ba6f59b_light
    service: light.toggle
- id: '1558263965446'
  alias: MQTT IKEA remote livingroom brightness up
    - platform: mqtt
  condition:
      value_template: "{{ 'brightness_up_click' in trigger.payload }}"
    - service: light.turn_on
      data_template:
        transition: '1'
        brightness: >
         {% set n = states.light['0x00124b001ba6f59b_light'].attributes.brightness + 20 %}
         {% if n > 255 %}
           255
         {% else %}
           {{ n }}
         {% endif %}
- id: '1558463165447'
  alias: MQTT IKEA remote livingroom brightness down
    - platform: mqtt
  condition:
      value_template: "{{ 'brightness_down_click' in trigger.payload }}"
      data_template:
        transition: '1'
        brightness: >
         {% set n = states.light['0x00124b001ba6f59b_light'].attributes.brightness - 20 %}
         {% if n < 10 %}
           10
         {% else %}
           {{ n }}
         {% endif %}
- id: '1558263165448'
  alias: MQTT IKEA remote livingroom temperature warm
    - platform: mqtt
  condition:
      value_template: "{{ 'arrow_right_click' in trigger.payload }}"
      data_template:
        transition: '1'
        color_temp: >
         {% set n = states.light['0x00124b001ba6f59b_light'].attributes.color_temp + 50 %}
         {% if n > 500 %}
           500
         {% else %}
           {{ n }}
         {% endif %}
- id: '1558263135449'
  alias: MQTT IKEA remote livingroom temperature cold
    - platform: mqtt
  condition:
      value_template: "{{ 'arrow_left_click' in trigger.payload }}"
      data_template:
        transition: '1'
        color_temp: >
         {% set n = states.light['0x00124b001ba6f59b_light'].attributes.color_temp - 50 %}
         {% if n < 150 %}
           150
         {% else %}
           {{ n }}
         {% endif %}
- id: '1558263145450'
  alias: MQTT IKEA remote livingroom brightness up hold
    - platform: mqtt
  condition:
      value_template: "{{ 'brightness_up_hold' in trigger.payload }}"
      data_template:
        transition: '10'
        brightness: >
         {% if n < 255 %}
           255
         {% else %}
           {{ n }}
         {% endif %}
- id: '1558263155451'
  alias: MQTT IKEA remote livingroom brightness down hold
    - platform: mqtt
  condition:
      value_template: "{{ 'brightness_down_hold' in trigger.payload }}"
      data_template:
        transition: '10'
        brightness: >
         {% if n > 1 %}
           1
         {% else %}
           {{ n }}
         {% endif %}
I created an app for AppDaemon to bring full functionality to IKEA E1524/E1810 and IKEA E1743. If you have more than one controller you can add a new instance app and that’s it. I don’t support group of lights, just 1 sensor connected with 1 light. However, you can connect them by creating different apps with multiple lights and the same controller in all of them. You can see the post about it here.
During my research for the same problem I stumbled upon this thread.
Just in case that somebody finds this thread during a similar research, too: I finally found a solution and posted it here.
(If posts like this to old threads are not desired/allowed, please delete it.)
You can also use one of the many blueprints that result in one automation per remote
