EDIT:
This project has evolved and now it supports many more devices and can be integrated with zigbee2MQTT, deCONZ, MQTT, and ZHA. You can check the documentation in here.
ORIGINAL POST:
Hi guys,
I would like to share an AppDaemon I have been working on. In my setup, I use Zigbee2MQTT and some IKEA devices. I bought 2 IKEA E1524/E1810 and 1 IKEA E1743. When trying to integrate the controllers I faced two problems:
- I couldn’t find any integration for these controllers to work smoothly to dim and brighten the light (brightness and color temperature). So I created a very long spaghetti automation yaml to solve. You can find the solution in here
- Once I had a working solution. I had to copy and paste the same automation for the other controller and light, which I did not like.
With all this, I came up with the idea to create an app for AppDaemon so I could share it with everyone. The app can be found in xaviml/controllerx.
This automation brings the following functionalities to IKEA E1524/E1810:
- Toggle light
- Manual increase/decrease of brightness and color temperature
- Smooth increase/decrease (holding button) of brightness and color temperature
This automation brings the following functionalities to IKEA E1743:
- Turn on/Turn off light
The integration is now on HACS and ready to use.
Let me know what you guys think or if you have any suggestions.
