Hi
All IKEA TRADFRI SHORTCUT that i have is working, but since about a month the battery level has changed from max 100% to av value of max 255%. The icon that used to be a battery has become an eye icon. Is there any changes in HA that is the cause of this? I always update to the latest HA version when it becomes available. All buttons reports firmware 0x24040006. I have tried to remove them, rebooted HA and added them again, but the problem remains. Somebody?
Silly question, sorry… are you sure this is the battery level? The LQI maximum is 255 and the default icon is the eye.
Enable firmware updates in ZHA as newer software has improved matters. This could be an interview issue or a regression with a “quirks file”.
Hi. I think it is the right sensor. I have not changed anything, It happened by it self. Here is how it looks:
I have tied most of these tips, but no luck yet. Thanks for the tips!
I have the same Problem, one Button work normally the other is shown 255%
Suggest report issue to ZHA Device Handlers → https://github.com/zigpy/zha-device-handlers/issues
Bug is open here: [BUG] IKEA TRADFRI SHORTCUT Button - Battery Level wrong state
Thanks, same issue here. Added comment to bug.
