I'm a BroadLink dummy. Help me!
The Broadlink app configuration is independent to the HA integration, so devices learned in the app are of no use in HA AFAIK.
I setup two Broadlink RM mini 3s recently to control two ceiling fans, and did the following:
  • Configured them to connect to my network using Broadlink Manager
  • Assigned reserved IPs from my router.
  • Firewalled the IPs from the internet (except for NTP traffic).
  • Added both remotes in HA:
remote:
  - platform: broadlink
    host: 192.168.1.238
    mac: 24:df:a7:d6:12:f2
    type: rm_mini3_newblackbean
    host: 192.168.1.239
    mac: 24:df:a7:d6:11:4d
  • used the remote.learn_command service in Developer Tools > Service for each remote to learn the commands from the fan remote (these commands are saved as a file named broadlink_remote__codes under config/.storage folder.
  • wrote scripts to send named commands eg:
# reverse the current direction of the fan.
living_room_fan_reverse:
  alias: "Living room fan reverse"
    - service: remote.send_command
        entity_id: remote.living_room
        device: fan
        command: "Reverse"
I’d encourage you to look at the Broadlink Manager thread I linked above - it’s lengthy but covers a wide discussion on how to best integrate. I went with a hybrid approach avoiding use of the app with the Broadlink Manager application but learning the codes through HA and I’m happy with the results.
