Now you understand why I advised not to install it along side your LibreELEC - because eventually, youd go wrong or get some error which means youd have to start again
No point in risking your Kodi install
If youre going for a new Pi3, then I would either try the hassio solution, or the working image that has everything you need to get started
couple of questions
1: should I use the new Pi 3 for my kodi setup and the Pi2 for assistant or vice versa.
2: wemo plugs or tp link does it make a difference was gonna pick a coupe up with pi 3
3: what size sd card do i need for the assistant is 1gb enough or should i get 16gb
Thats it for now
thanks again for all your help
ps I will be mindfull to not make too many posts as I will possibly be stopped again for 4 hours grrrrr.
Kem
June 10, 2017, 2:57am
24
l iām new to this and this guy has a step by step tutorial home-assistant for beginners super easy the best tutorial on you tube
VIDEO
It doesnt say on the hassbian installation instructions but am i supposed to unzip the image file first
It looks like etcher did it for me but I ask as I cant connect at
http://hassbian.local:8123/
dont answer that yes is the answer on it now
Still canāt access it at
Have found its ip address so it is on the network, but simply wont connect via ip address states connection refused
any help would be great
Kem
June 11, 2017, 9:08pm
27
yes sometimes it happens it took me like 3 times to burned the image with etcher the other thing is that when you insert the card to the pi it takes like 5-7 minutes to start homeassistant
I have but it still wonāt let me connect
I think Iām missing something
keithh666
(Keith Hull)
June 11, 2017, 10:21pm
30
Try using the ip address e.g. 192.168.1.7:8123 instead of using dns
same thing its doing my head in.
i can see it on the router but
This site canāt be reached
192.168.1.16 refused to connect.
Search Google for 192 168 8123
ERR_CONNECTION_REFUSED
hassbian.local refused to connect.
Search Google for hassbian local 8123
keithh666
(Keith Hull)
June 11, 2017, 11:07pm
32
You have checked that HA is running on the PI? ps -aux should show HA runningā¦
homeass+ 19536 47.2 7.0 273028 66848 ? Rsl 00:01 1:38 /srv/homeassistant/homeassistant_venv/bin/python3 /srv/homeassistant/homeassistant_venv/bin/hass -c /home
Your result may differ as Iām running AIO install not hasbian but there should be something to show its running.
Hi and thanks but im lost as to what that means or how to do it.
keithh666
(Keith Hull)
June 11, 2017, 11:24pm
34
you need to type ps -aux on the command line, usually done via ssh or if you have monitor and keyboard attached via the gui terminal program
trying to conect to it have it hooked to tv as we speak
When I try ssh pi@<192.168.1.16>
I get
-bash: syntax error near unexpected token `newlineā
bloody walkthoughs removed the <> and im on
pi@hassbian:~ $ ps -aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.2 0.4 23820 3880 ? Ss 23:14 0:03 /sbin/init
root 2 0.0 0.0 0 0 ? S 23:14 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S 23:14 0:00 [ksoftirqd/0]
root 4 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/0:0]
root 5 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/0:0H]
root 7 0.0 0.0 0 0 ? S 23:14 0:00 [rcu_sched]
root 8 0.0 0.0 0 0 ? S 23:14 0:00 [rcu_bh]
root 9 0.0 0.0 0 0 ? S 23:14 0:00 [migration/0]
root 10 0.0 0.0 0 0 ? S< 23:14 0:00 [lru-add-drain]
root 11 0.0 0.0 0 0 ? S 23:14 0:00 [cpuhp/0]
root 12 0.0 0.0 0 0 ? S 23:14 0:00 [cpuhp/1]
root 13 0.0 0.0 0 0 ? S 23:14 0:00 [migration/1]
root 14 0.0 0.0 0 0 ? S 23:14 0:00 [ksoftirqd/1]
root 16 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/1:0H]
root 17 0.0 0.0 0 0 ? S 23:14 0:00 [cpuhp/2]
root 18 0.0 0.0 0 0 ? S 23:14 0:00 [migration/2]
root 19 0.0 0.0 0 0 ? S 23:14 0:00 [ksoftirqd/2]
root 20 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/2:0]
root 21 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/2:0H]
root 22 0.0 0.0 0 0 ? S 23:14 0:00 [cpuhp/3]
root 23 0.0 0.0 0 0 ? S 23:14 0:00 [migration/3]
root 24 0.0 0.0 0 0 ? S 23:14 0:00 [ksoftirqd/3]
root 26 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/3:0H]
root 27 0.0 0.0 0 0 ? S 23:14 0:00 [kdevtmpfs]
root 28 0.0 0.0 0 0 ? S< 23:14 0:00 [netns]
root 29 0.0 0.0 0 0 ? S 23:14 0:00 [khungtaskd]
root 30 0.0 0.0 0 0 ? S 23:14 0:00 [oom_reaper]
root 31 0.0 0.0 0 0 ? S< 23:14 0:00 [writeback]
root 32 0.0 0.0 0 0 ? S 23:14 0:00 [kcompactd0]
root 33 0.0 0.0 0 0 ? S< 23:14 0:00 [crypto]
root 34 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 35 0.0 0.0 0 0 ? S< 23:14 0:00 [kblockd]
root 36 0.0 0.0 0 0 ? S< 23:14 0:00 [watchdogd]
root 38 0.0 0.0 0 0 ? S< 23:14 0:00 [rpciod]
root 39 0.0 0.0 0 0 ? S< 23:14 0:00 [xprtiod]
root 40 0.0 0.0 0 0 ? S 23:14 0:00 [kswapd0]
root 41 0.0 0.0 0 0 ? S< 23:14 0:00 [vmstat]
root 42 0.0 0.0 0 0 ? S< 23:14 0:00 [nfsiod]
root 52 0.0 0.0 0 0 ? S< 23:14 0:00 [kthrotld]
root 53 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 55 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 56 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 57 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 58 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 59 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 60 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 61 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 62 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 63 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 64 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 65 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 66 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 67 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 68 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 69 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 70 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 71 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 72 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 73 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 74 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 75 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 76 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 77 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 78 0.0 0.0 0 0 ? S< 23:14 0:00 [iscsi_eh]
root 79 0.0 0.0 0 0 ? S< 23:14 0:00 [dwc_otg]
root 80 0.0 0.0 0 0 ? S< 23:14 0:00 [DWC Notificati
root 81 0.0 0.0 0 0 ? S< 23:14 0:00 [VCHIQ-0]
root 82 0.0 0.0 0 0 ? S< 23:14 0:00 [VCHIQr-0]
root 83 0.0 0.0 0 0 ? S< 23:14 0:00 [VCHIQs-0]
root 84 0.0 0.0 0 0 ? S 23:14 0:00 [VCHIQka-0]
root 85 0.0 0.0 0 0 ? S< 23:14 0:00 [SMIO]
root 87 0.0 0.0 0 0 ? S 23:14 0:00 [irq/92-mmc1]
root 90 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/1:1]
root 91 0.0 0.0 0 0 ? S< 23:14 0:00 [bioset]
root 92 0.0 0.0 0 0 ? S 23:14 0:00 [mmcqd/0]
root 93 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/2:1]
root 94 0.0 0.0 0 0 ? S 23:14 0:00 [jbd2/mmcblk0p2
root 95 0.0 0.0 0 0 ? S< 23:14 0:00 [ext4-rsv-conve
root 96 0.0 0.0 0 0 ? S< 23:14 0:00 [ipv6_addrconf]
root 114 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/u8:1]
root 131 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/u8:2]
root 142 0.0 0.2 9932 2640 ? Ss 23:14 0:00 /lib/systemd/sy
root 144 0.0 0.3 11572 2892 ? Ss 23:14 0:00 /lib/systemd/sy
root 237 0.0 0.0 0 0 ? S< 23:14 0:00 [cfg80211]
root 240 0.0 0.0 0 0 ? S< 23:14 0:00 [brcmf_wq/mmc1:
root 241 0.0 0.0 0 0 ? S 23:14 0:00 [brcmf_wdog/mmc
root 261 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/1:2]
root 269 0.0 0.0 0 0 ? S 23:14 0:00 [kworker/0:3]
root 419 0.0 0.2 5072 2488 ? Ss 23:14 0:00 /usr/sbin/cron
root 425 0.0 0.2 3396 2060 ? Ss 23:14 0:00 /lib/systemd/sy
avahi 435 0.0 0.2 3876 2468 ? Ss 23:14 0:00 avahi-daemon: r
message+ 438 0.0 0.3 5492 2944 ? Ss 23:14 0:00 /usr/bin/dbus-d
root 440 0.0 0.1 27600 1212 ? SLsl 23:14 0:00 /usr/sbin/rngd
nobody 455 0.0 0.1 2292 1396 ? Ss 23:14 0:00 /usr/sbin/thd -
avahi 469 0.0 0.0 3876 240 ? S 23:14 0:00 avahi-daemon: c
root 502 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/2:1H]
root 516 0.0 0.2 32144 2644 ? Ssl 23:14 0:00 /usr/sbin/rsysl
root 521 0.0 0.1 7156 1436 ? Ss 23:14 0:00 /sbin/wpa_suppl
root 626 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/u9:0]
root 627 0.0 0.0 0 0 ? S< 23:14 0:00 [hci0]
root 628 0.0 0.0 0 0 ? S< 23:14 0:00 [hci0]
root 629 0.0 0.0 2068 148 ? S 23:14 0:00 /usr/bin/hciatt
root 632 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/u9:2]
root 635 0.0 0.3 5008 3412 ? Ss 23:14 0:00 /usr/lib/blueto
root 727 0.0 0.0 2564 300 ? Ss 23:14 0:00 /sbin/dhcpcd -q
root 728 0.0 0.4 7864 4304 ? Ss 23:14 0:00 /usr/sbin/sshd
ntp 751 0.0 0.4 5776 3792 ? Ss 23:14 0:00 /usr/sbin/ntpd
root 752 0.0 0.1 4052 1756 tty1 Ss+ 23:14 0:00 /sbin/agetty ā
root 757 0.0 0.0 0 0 ? S< 23:14 0:00 [kworker/0:1H]
root 761 0.0 0.0 0 0 ? S< 23:15 0:00 [kworker/1:1H]
root 762 0.0 0.0 0 0 ? S< 23:15 0:00 [kworker/3:1H]
root 783 0.0 0.0 0 0 ? S 23:29 0:00 [kworker/3:2]
root 784 0.0 0.0 0 0 ? S 23:34 0:00 [kworker/3:0]
root 785 0.2 0.5 11552 4940 ? Ss 23:39 0:00 sshd: pi [priv]
pi 791 0.0 0.3 11552 3520 ? S 23:39 0:00 sshd: pi@pts/0
pi 793 0.6 0.4 6188 4084 pts/0 Ss 23:39 0:00 -bash
root 809 0.0 0.0 0 0 ? S 23:39 0:00 [kworker/3:1]
pi 810 0.0 0.2 4740 2100 pts/0 R+ 23:40 0:00 ps -aux
pi@hassbian:~ $
keithh666
(Keith Hull)
June 11, 2017, 11:48pm
37
Doesnāt look like HA is running try to find out what the start command for hassbian is, I use
sudo systemctl restart home-assistant.service
for the AIO install
Iām signing off for now as early start tomorrow
no worries thanks. Me too but its doing my head in so will give it another hourā¦
Thanks for all your help so far, I am wiping and re flashing the card again to see if that helps
Then will try your command if no joy
Re installed and ran but and have homeassistant showing up as seen below
but still no access
root 425 0.0 0.2 5072 2344 ? Ss Jun11 0:00 /usr/sbin/cron -f
root 433 0.0 0.2 3396 2124 ? Ss Jun11 0:00 /lib/systemd/systemd-logind
avahi 443 0.0 0.2 3876 2504 ? Ss Jun11 0:00 avahi-daemon: running [hassbian.
message+ 444 0.0 0.3 5492 3020 ? Ss Jun11 0:00 /usr/bin/dbus-daemon --system ā
root 454 0.0 0.1 27600 1156 ? SLsl Jun11 0:00 /usr/sbin/rngd -r /dev/hwrng
nobody 474 0.0 0.1 2292 1464 ? Ss Jun11 0:00 /usr/sbin/thd --daemon --trigger
avahi 479 0.0 0.0 3876 240 ? S Jun11 0:00 avahi-daemon: chroot helper
root 481 0.0 0.0 0 0 ? S< Jun11 0:00 [kworker/1:1H]
root 511 0.0 0.0 0 0 ? S< Jun11 0:00 [kworker/0:1H]
root 523 0.0 0.2 32144 2680 ? Ssl Jun11 0:00 /usr/sbin/rsyslogd -n
root 529 0.0 0.1 7156 1436 ? Ss Jun11 0:00 /sbin/wpa_supplicant -s -B -P /r
root 734 0.0 0.0 0 0 ? S< Jun11 0:00 [kworker/u9:0]
root 735 0.0 0.0 0 0 ? S< Jun11 0:00 [hci0]
root 736 0.0 0.0 0 0 ? S< Jun11 0:00 [hci0]
root 737 0.0 0.0 2068 148 ? S Jun11 0:00 /usr/bin/hciattach /dev/serial1
root 739 0.0 0.0 0 0 ? S< Jun11 0:00 [kworker/u9:2]
root 743 0.0 0.3 5008 3304 ? Ss Jun11 0:00 /usr/lib/bluetooth/bluetoothd
root 792 0.0 0.1 2564 1540 ? Ss Jun11 0:00 /sbin/dhcpcd -q -w
root 793 0.0 0.4 7864 4272 ? Ss Jun11 0:00 /usr/sbin/sshd -D
root 842 0.0 0.1 4052 1756 tty1 Ss+ Jun11 0:00 /sbin/agetty --noclear tty1 linu
ntp 931 0.0 0.4 5776 3832 ? Ss Jun11 0:00 /usr/sbin/ntpd -p /var/run/ntpd.
root 977 0.0 0.0 0 0 ? S< Jun11 0:00 [kworker/2:1H]
root 978 0.0 0.0 0 0 ? S< Jun11 0:00 [kworker/3:1H]
homeass+ 1124 2.8 4.4 429092 42460 ? Ssl 00:02 0:36 /srv/homeassistant/bin/python3 /
root 1245 0.0 0.5 11552 4944 ? Ss 00:04 0:00 sshd: pi [priv]
pi 1252 0.0 0.3 11552 3444 ? R 00:05 0:00 sshd: pi@pts/0
pi 1254 0.0 0.4 6188 4128 pts/0 Ss 00:05 0:00 -bash
root 1533 0.0 0.0 0 0 ? S 00:07 0:00 [kworker/u8:2]
root 1813 0.0 0.0 0 0 ? S 00:13 0:00 [kworker/0:2]
root 1816 0.0 0.0 0 0 ? S 00:13 0:00 [kworker/1:1]
root 1865 0.0 0.0 0 0 ? S 00:18 0:00 [kworker/1:0]
root 1872 0.0 0.0 0 0 ? S 00:19 0:00 [kworker/u8:1]
root 1888 0.0 0.0 0 0 ? S 00:19 0:00 [kworker/0:0]
root 1889 0.0 0.0 0 0 ? S 00:20 0:00 [kworker/1:3]
pi 1927 0.0 0.2 4740 2156 pts/0 R+ 00:23 0:00 ps -aux
Sleep time for now but any advice for tomorrow evengings enthraling episode please feel freeā¦
So here is what i have done incase anyone can spot my error
downloaded file.
Tried burning zip to file it worked but no home assistant. Tried unzipping and burning image to write it to sd card and again it worked and seems to install Homeassistant but when trying to start or stop home assistant it states it isnt there to start.
tried to manually install homeassistant manualy but came up with errors.
Just to be clear I am writing hassbian to a clean sd card with nothing previously installed onto the PI3
Confused.com
