Import from USB - no success/error message
The request
When trying to import settings from USB thumb drive there is no way to say if the process finished successfully or with errors.
In my case, I’m trying to enable I2C but I don’t know if it succeeded (without restarting PI and checking).
Ideally, we should see a toast message when the USB device is connected (the Import from USB button should get enabled) and a message box when the settings get successfully imported or error message when there was a problem with this.
I’m sure many users have problems with importing settings. A proper message box will help with debugging what might be the cause.
The alternatives
There are no alternatives. We can look at logs, but this won’t say much.
In supervisor section I see:
20-07-13 20:03:45 INFO (MainThread) [supervisor.hassos] Syncing configuration from USB with HassOS.
20-07-13 20:03:45 INFO (MainThread) [supervisor.host.services] Restart local service hassos-config.service
20-07-13 20:03:45 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.RestartUnit on /org/freedesktop/systemd1
20-07-13 20:04:39 INFO (MainThread) [supervisor.hassos] Syncing configuration from USB with HassOS.
20-07-13 20:04:39 INFO (MainThread) [supervisor.host.services] Restart local service hassos-config.service
20-07-13 20:04:39 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.RestartUnit on /org/freedesktop/systemd1
In host section:
[ 1313.264543] usb 2-1: New USB device found, idVendor=13fe, idProduct=6300, bcdDevice= 1.10
[ 1313.264587] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1313.264616] usb 2-1: Product: USB DISK 3.0
[ 1313.264640] usb 2-1: Manufacturer: Wilk
[ 1313.264663] usb 2-1: SerialNumber: 070A8CC995B06616
[ 1313.272692] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 1313.274823] scsi host0: usb-storage 2-1:1.0
[ 1314.343921] scsi 0:0:0:0: Direct-Access Wilk USB DISK 3.0 PMAP PQ: 0 ANSI: 6
[ 1314.345816] sd 0:0:0:0: [sda] 60555264 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 1314.346309] sd 0:0:0:0: [sda] Write Protect is off
[ 1314.346345] sd 0:0:0:0: [sda] Mode Sense: 45 00 00 00
[ 1314.346675] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 1314.473743] sda: sda1 sda2
[ 1314.476558] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 1314.481043] udevd[417]: inotify_add_watch(6, /dev/sda, 10) failed: No such file or directory
[ 1314.484941] udevd[265]: inotify_add_watch(7, /dev/sda, 10) failed: No such file or directory
[ 1314.488341] udevd[264]: inotify_add_watch(7, /dev/sda2, 10) failed: No such file or directory
[ 1314.488414] udevd[265]: inotify_add_watch(7, /dev/sda1, 10) failed: No such file or directory
[ 1314.488833] udevd[499]: inotify_add_watch(6, /dev/sda, 10) failed: No such file or directory
[ 1314.490119] udevd[418]: inotify_add_watch(6, /dev/sda2, 10) failed: No such file or directory
[ 1314.491488] udevd[417]: inotify_add_watch(6, /dev/sda1, 10) failed: No such file or directory
[ 1314.493981] udevd[498]: inotify_add_watch(6, /dev/sda2, 10) failed: No such file or directory
[ 1314.494698] udevd[499]: inotify_add_watch(6, /dev/sda1, 10) failed: No such file or directory
Additional information
Related issues:
home-assistant/operating-system#753
https://github.com/home-assistant/frontend/issues/6374
Another related issue:
and WTH topic: WTH why enabling I2C is so hard?
Found a good workaround which doesn’t fix the issue for this Feature Request but is a step in the right direction for ease of use.
Posting here in case people find this thread before that add-on.
