I’m just getting into the KNX integration with HA.
What I want to do is to read the target_temperature_state_address - let’s say 1/2/3 and paste the value into an input_button helper in HA.
The value of the helper then should be set as temperature for an other thermostat.
Maybe there is no need for the input_button helper, currently I only know how to set the temperature value from that helper for the thermostat, but lacking on putting the value from KNX into the helper.
If I understand correctly, I don’t think you’d need a helper entity for that. You could just create an automation that listens on state attribute change of one climate entity and call an action to set another climate entity (climate.set_temperature) to that value via a template {{ state_attr("climate.bad", "temperature") }}
