Qq: can the trace of the automation show the retry logic, or do I need to see that on logs elsewhere?
The trace of the automation doesn’t show the retry logic. However, log entries are created. There is a log line for each retry with the reason of the failure.
Hi, I’ve used it to turn on and off a switch at night. It seems to work as the switch does turn on and off but I get “repairs” notifications:
## Service call failure
homeassistant.turn_on(entity_id=binary_sensor.salonnord_input) failed after 7 retries. Check the log for additional information.
Please open an issue here. The form will guide you on how to collect and upload the required information for debugging the issue. The main thing that is missing is the error from the log with the reason for the retries.
The Tapo stuff in the log is just noise due to my camera being physically unplugged when I’m home most of the time.
edit: thanks for your help on the ticket !
For those encountering the same problem, in the target selection, you should select the switch entity only and not the device. I’m using a Shelly 1 and the device includes not only a switch but also some other entity.
I’m either not clear on the validation option or I’m getting an error. I’m testing a switch (switch.test). The integration works great but if I add the validation option I get an error when attempting to check to see if switch.test is on to stop the retry attempts.
I’m using “[[ states(‘switch.test’) = “on” ]]” and I get an error: invalid template (TemplateSyntaxError: unexpected char ‘‘’ at 10) for dictionary value @ data[‘validation’].
My apologies, I do have == and am getting that error but if the expected state is checked before each attempt, that will work. I understood that this was only checked before the first attempt and then the defined retries happened without using validation.
