I run Home Assistant Operating System on an linux VM on an UNRAID server and have so for years .
Influx and Grafana addons have been flawless. I see the Influx add on says non maintained as of 2021 now that I look for help and issues go unresolved so 1st question, is this add on dead?
Now to my issue, grafana says bad gateway when displaying my dashboards derived from influxdb.
When I goto influx from home assistant side bar I see this popup suggesting the Influx DB is not running.
However in the addons GUI in HA I see it is running but is restarting often.
influxdb:
host: a0d7b954-influxdb
port: 8086
database: homeassistant
username: homeassistant
password: test
max_retries: 3
default_measurement: state
include:
domains:
- sensor
exclude:
entity_globs:
- sensor.brother*
- sensor.pm_main_freq*
- sensor.*_rx
- sensor.*_tx
- sensor.*wifi*
- sensor.*mfc*
- sensor.*hacs*
- sensor.*cr10spro*
- sensor.*aarlo*
- sensor.*zone*
Here is the the log:
Any ideas how to troubleshoot this?
[17:21:01] INFO: Starting NGINX...
time="2022-12-16T17:21:11-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:36478" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:21:11-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:36478" response_time="520.351µs" status=200
time="2022-12-16T17:21:17-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:36482" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/health
time="2022-12-16T17:21:17-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:36486" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/layouts
time="2022-12-16T17:21:17-05:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:36482" response_time=22.250341ms status=204
time="2022-12-16T17:21:17-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:36486" response_time=31.881824ms status=200
time="2022-12-16T17:21:18-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:36494" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/env
time="2022-12-16T17:21:18-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:36494" response_time=3.978364ms status=200
time="2022-12-16T17:21:18-05:00" level=debug msg=Request component=server method=POST remote_addr="127.0.0.1:36500" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/proxy
time="2022-12-16T17:21:18-05:00" level=debug msg=query command="SELECT mean(\"usage_user\") FROM \"telegraf\".\"\".\"cpu\" WHERE \"cpu\" = 'cpu-total' AND time > now() - 10m GROUP BY host;\n SELECT mean(\"load1\") FROM \"telegraf\".\"\".\"system\" WHERE time > now() - 10m GROUP BY host;\n SELECT non_negative_derivative(mean(uptime)) AS deltaUptime FROM \"telegraf\".\"\".\"system\" WHERE time > now() - 1m0s * 10 GROUP BY host, time(1m0s) fill(0);\n SELECT mean(\"Percent_Processor_Time\") FROM \"telegraf\".\"\".\"win_cpu\" WHERE time > now() - 10m GROUP BY host;\n SELECT mean(\"Processor_Queue_Length\") FROM \"telegraf\".\"\".\"win_system\" WHERE time > now() - 10s GROUP BY host;\n SELECT non_negative_derivative(mean(\"System_Up_Time\")) AS winDeltaUptime FROM \"telegraf\".\"\".\"win_system\" WHERE time > now() - 1m0s * 10 GROUP BY host, time(1m0s) fill(0);\n SHOW TAG VALUES WITH KEY = \"host\" WHERE TIME > now() - 10m;" component=proxy db=telegraf host="localhost:8086" rp=
time="2022-12-16T17:21:19-05:00" level=error msg="Error message Post \"http://localhost:8086/query?db=telegraf&epoch=ms&q=SELECT+mean%28%22usage_user%22%29+FROM+%22telegraf%22.%22%22.%22cpu%22+WHERE+%22cpu%22+%3D+%27cpu-total%27+AND+time+%3E+now%28%29+-+10m+GROUP+BY+host%3B%0A++++++SELECT+mean%28%22load1%22%29+FROM+%22telegraf%22.%22%22.%22system%22+WHERE+time+%3E+now%28%29+-+10m+GROUP+BY+host%3B%0A++++++SELECT+non_negative_derivative%28mean%28uptime%29%29+AS+deltaUptime+FROM+%22telegraf%22.%22%22.%22system%22+WHERE+time+%3E+now%28%29+-+1m0s+%2A+10+GROUP+BY+host%2C+time%281m0s%29+fill%280%29%3B%0A++++++SELECT+mean%28%22Percent_Processor_Time%22%29+FROM+%22telegraf%22.%22%22.%22win_cpu%22+WHERE+time+%3E+now%28%29+-+10m+GROUP+BY+host%3B%0A++++++SELECT+mean%28%22Processor_Queue_Length%22%29+FROM+%22telegraf%22.%22%22.%22win_system%22+WHERE+time+%3E+now%28%29+-+10s+GROUP+BY+host%3B%0A++++++SELECT+non_negative_derivative%28mean%28%22System_Up_Time%22%29%29+AS+winDeltaUptime+FROM+%22telegraf%22.%22%22.%22win_system%22+WHERE+time+%3E+now%28%29+-+1m0s+%2A+10+GROUP+BY+host%2C+time%281m0s%29+fill%280%29%3B%0A++++++SHOW+TAG+VALUES+WITH+KEY+%3D+%22host%22+WHERE+TIME+%3E+now%28%29+-+10m%3B&rp=\": EOF" component=server http_status =400
time="2022-12-16T17:21:19-05:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:36500" response_time=678.918241ms status=400
[17:21:19] INFO: InfluxDB stopped, restarting...
[17:21:19] INFO: Starting the InfluxDB...
time="2022-12-16T17:21:21-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55752" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/health
time="2022-12-16T17:21:21-05:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2022-12-16T17:21:21-05:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:55752" response_time=3.955829ms status=400
time="2022-12-16T17:21:21-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55760" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/RobotoMono-Medium.ed4bd09b.ttf
time="2022-12-16T17:21:21-05:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:55760" url=/RobotoMono-Medium.ed4bd09b.ttf
time="2022-12-16T17:21:21-05:00" level=info msg="Response: Not Modified" component=server method=GET remote_addr="127.0.0.1:55760" response_time=27.061003ms status=304
time="2022-12-16T17:21:21-05:00" level=debug msg=Request component=server method=POST remote_addr="127.0.0.1:55766" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/proxy
time="2022-12-16T17:21:21-05:00" level=debug msg=query command="SHOW DATABASES" component=proxy db= host="localhost:8086" rp=
time="2022-12-16T17:21:21-05:00" level=error msg="Error message Post \"http://localhost:8086/query?db=&epoch=ms&q=SHOW+DATABASES&rp=\": dial tcp 127.0.0.1:8086: connect: connection refused" component=server http_status =400
time="2022-12-16T17:21:21-05:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:55766" response_time=1.334842ms status=400
time="2022-12-16T17:21:21-05:00" level=debug msg=Request component=server method=POST remote_addr="127.0.0.1:55778" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/proxy
time="2022-12-16T17:21:21-05:00" level=debug msg=query command="SHOW MEASUREMENTS" component=proxy db=homeassistant host="localhost:8086" rp=
time="2022-12-16T17:21:21-05:00" level=error msg="Error message Post \"http://localhost:8086/query?db=homeassistant&epoch=ms&q=SHOW+MEASUREMENTS&rp=\": dial tcp 127.0.0.1:8086: connect: connection refused" component=server http_status =400
time="2022-12-16T17:21:21-05:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:55778" response_time="878.139µs" status=400
time="2022-12-16T17:21:21-05:00" level=debug msg=Request component=server method=POST remote_addr="127.0.0.1:55792" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/proxy
time="2022-12-16T17:21:21-05:00" level=debug msg=query command="SHOW FIELD KEYS FROM \"thirtytwodays\".\"min\"" component=proxy db=homeassistant host="localhost:8086" rp=
time="2022-12-16T17:21:21-05:00" level=error msg="Error message Post \"http://localhost:8086/query?db=homeassistant&epoch=ms&q=SHOW+FIELD+KEYS+FROM+%22thirtytwodays%22.%22min%22&rp=\": dial tcp 127.0.0.1:8086: connect: connection refused" component=server http_status =400
time="2022-12-16T17:21:21-05:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:55792" response_time=3.060614ms status=400
time="2022-12-16T17:21:21-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55806" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:21:21-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55806" response_time="551.335µs" status=200
time="2022-12-16T17:21:25-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55828" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/health
time="2022-12-16T17:21:25-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55822" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/dashboards
time="2022-12-16T17:21:25-05:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2022-12-16T17:21:25-05:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:55828" response_time=5.057415ms status=400
time="2022-12-16T17:21:25-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55822" response_time=11.799096ms status=200
time="2022-12-16T17:21:26-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55830" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/health
time="2022-12-16T17:21:26-05:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2022-12-16T17:21:26-05:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:55830" response_time="589.966µs" status=400
time="2022-12-16T17:21:26-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55846" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/kapacitors
time="2022-12-16T17:21:26-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55846" response_time="539.179µs" status=200
time="2022-12-16T17:21:27-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55854" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/kapacitors/0/rules
time="2022-12-16T17:21:27-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55854" response_time=22.983955ms status=200
time="2022-12-16T17:21:27-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55858" url="/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/kapacitors/0/proxy?path=/kapacitor/v1/ping"
time="2022-12-16T17:21:27-05:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:55858" response_time=9.840242ms status=204
time="2022-12-16T17:21:28-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55868" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources
time="2022-12-16T17:21:28-05:00" level=info msg="Failed to retrieve database version" error="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused" url="http://localhost:8086"
time="2022-12-16T17:21:28-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55868" response_time=1.66174ms status=200
time="2022-12-16T17:21:28-05:00" level=debug msg=Request component=server method=POST remote_addr="127.0.0.1:55882" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/proxy
ts=2022-12-16T17:13:51.425-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
time="2022-12-16T17:13:51-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:60370" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:13:51-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:60370" response_time=3.104798ms status=200
time="2022-12-16T17:13:51-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:60374" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:13:51-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:60374" response_time="299.552µs" status=200
ts=2022-12-16T17:13:52.564-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:13:54.892-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:13:57.671-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
time="2022-12-16T17:14:02-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:47412" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:02-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:47412" response_time=1.268011ms status=200
time="2022-12-16T17:14:02-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:47424" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:02-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:47424" response_time="108.03µs" status=200
[17:14:08] INFO: InfluxDB stopped, restarting...
[17:14:08] INFO: Starting the InfluxDB...
time="2022-12-16T17:14:13-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:51586" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:13-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51586" response_time=7.745686ms status=200
time="2022-12-16T17:14:13-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:51594" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:13-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:51594" response_time="246.439µs" status=200
time="2022-12-16T17:14:24-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:58492" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:24-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:58492" response_time="90.387µs" status=200
time="2022-12-16T17:14:24-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:58502" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:24-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:58502" response_time="155.7µs" status=200
[17:14:27] INFO: InfluxDB stopped, restarting...
[17:14:27] INFO: Starting the InfluxDB...
time="2022-12-16T17:14:35-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:42152" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:35-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:42152" response_time=3.843083ms status=200
time="2022-12-16T17:14:35-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:42168" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:35-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:42168" response_time="290.478µs" status=200
[17:14:46] INFO: InfluxDB stopped, restarting...
[17:14:46] INFO: Starting the InfluxDB...
time="2022-12-16T17:14:46-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:54160" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:46-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54160" response_time=3.228807ms status=200
time="2022-12-16T17:14:46-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:54176" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:46-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54176" response_time="572.704µs" status=200
ts=2022-12-16T17:14:50.279-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:14:50.780-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:14:51.523-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:14:52.386-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:14:53.491-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:14:55.907-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
time="2022-12-16T17:14:57-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:60062" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:57-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:60062" response_time="98.378µs" status=200
time="2022-12-16T17:14:57-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:60072" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:14:57-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:60072" response_time="245.9µs" status=200
[17:15:06] INFO: InfluxDB stopped, restarting...
[17:15:06] INFO: Starting the InfluxDB...
time="2022-12-16T17:15:08-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55432" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:08-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55432" response_time=1.417918ms status=200
time="2022-12-16T17:15:09-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:55436" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:09-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:55436" response_time="189.304µs" status=200
time="2022-12-16T17:15:19-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:33734" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:19-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33734" response_time="217.123µs" status=200
time="2022-12-16T17:15:19-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:33740" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:19-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:33740" response_time="186.807µs" status=200
[17:15:27] INFO: InfluxDB stopped, restarting...
[17:15:27] INFO: Starting the InfluxDB...
time="2022-12-16T17:15:30-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:38826" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:30-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:38826" response_time=2.193527ms status=200
time="2022-12-16T17:15:30-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:38828" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:30-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:38828" response_time="181.005µs" status=200
time="2022-12-16T17:15:41-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:54860" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:41-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54860" response_time="182.176µs" status=200
time="2022-12-16T17:15:41-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:54864" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:41-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:54864" response_time="86.483µs" status=200
[17:15:46] INFO: InfluxDB stopped, restarting...
[17:15:46] INFO: Starting the InfluxDB...
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57302" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1
time="2022-12-16T17:15:49-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57302" response_time=3.546762ms status=200
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57318" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:49-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57318" response_time="570.17µs" status=200
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57332" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/env
time="2022-12-16T17:15:49-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57332" response_time=5.453952ms status=200
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57334" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources
time="2022-12-16T17:15:49-05:00" level=info msg="Failed to retrieve database version" error="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused" url="http://localhost:8086"
time="2022-12-16T17:15:49-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57334" response_time=4.925042ms status=200
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57344" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources
time="2022-12-16T17:15:49-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57344" response_time=5.403917ms status=200
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57350" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/health
time="2022-12-16T17:15:49-05:00" level=error msg="Error message Error contacting source" component=server http_status =400
time="2022-12-16T17:15:49-05:00" level=info msg="Response: Bad Request" component=server method=GET remote_addr="127.0.0.1:57350" response_time="758.68µs" status=400
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57352" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/kapacitors
time="2022-12-16T17:15:49-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57352" response_time="448.679µs" status=200
time="2022-12-16T17:15:49-05:00" level=debug msg=Request component=server method=POST remote_addr="127.0.0.1:57364" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/proxy
time="2022-12-16T17:15:49-05:00" level=debug msg=query command="SELECT count(\"value\") AS \"count_value\" FROM \"chronograf\".\"autogen\".\"alerts\" WHERE time > now() - 30d AND time < now() GROUP BY time(1d) FILL(null)" component=proxy db= host="localhost:8086" rp=
time="2022-12-16T17:15:49-05:00" level=error msg="Error message Post \"http://localhost:8086/query?db=&epoch=ms&q=SELECT+count%28%22value%22%29+AS+%22count_value%22+FROM+%22chronograf%22.%22autogen%22.%22alerts%22+WHERE+time+%3E+now%28%29+-+30d+AND+time+%3C+now%28%29+GROUP+BY+time%281d%29+FILL%28null%29&rp=\": dial tcp 127.0.0.1:8086: connect: connection refused" component=server http_status =400
time="2022-12-16T17:15:49-05:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:57364" response_time=4.063976ms status=400
time="2022-12-16T17:15:50-05:00" level=debug msg=Request component=server method=POST remote_addr="127.0.0.1:57374" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/sources/0/proxy
time="2022-12-16T17:15:50-05:00" level=debug msg=query command="SELECT host, value, level, alertName FROM alerts WHERE time >= '2022-11-16T17:15:49-05:00' AND time <= '2022-12-16T17:15:49-05:00' ORDER BY time desc LIMIT 30" component=proxy db=chronograf host="localhost:8086" rp=
time="2022-12-16T17:15:50-05:00" level=error msg="Error message Post \"http://localhost:8086/query?db=chronograf&epoch=ms&q=SELECT+host%2C+value%2C+level%2C+alertName+FROM+alerts+WHERE+time+%3E%3D+%272022-11-16T17%3A15%3A49-05%3A00%27+AND+time+%3C%3D+%272022-12-16T17%3A15%3A49-05%3A00%27+ORDER+BY+time+desc+LIMIT+30&rp=\": dial tcp 127.0.0.1:8086: connect: connection refused" component=server http_status =400
time="2022-12-16T17:15:50-05:00" level=info msg="Response: Bad Request" component=server method=POST remote_addr="127.0.0.1:57374" response_time=1.477901ms status=400
ts=2022-12-16T17:15:50.292-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:15:50.834-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:15:51.293-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:15:52.474-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
time="2022-12-16T17:15:52-05:00" level=debug msg=Request component=server method=GET remote_addr="127.0.0.1:57390" url=/api/hassio_ingress/jr3n9Y43gGgPb3XEnsM7_35wVwPT9RBZoPOnc52dBhc/chronograf/v1/me
time="2022-12-16T17:15:52-05:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:57390" response_time="582.791µs" status=200
ts=2022-12-16T17:15:53.878-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
ts=2022-12-16T17:15:55.730-05:00 lvl=error msg="failed to connect to InfluxDB, retrying..." service=influxdb cluster=default err="Get \"http://localhost:8086/ping\": dial tcp 127.0.0.1:8086: connect: connection refused"
