Dear,
My yaml file is approved in the editor of my air quality meter but not in the esphome builder, I have installed HA in virtual box with esphome builder but when I want to install I always get the following error "INFO ESPHome 2024.12.2
INFO Reading configuration /config/esphome/living.yaml…
ERROR Error while reading config: Invalid YAML syntax:
Error reading file /config/esphome/common/base.yaml: [Errno 2] No such file or directory: ‘/config/esphome/common/base.yaml’
Can someone tell me what the solution would be?
