Ingress with Custom URL?
I have a docker container that I’m running on the same machine as Home Assistant that runs its web interface on an alternate port. It’s not an official Add-on, but I was wondering, would it be possible to access this container’s UI through Home Assistant’s web interface? I added a panel_iframe, but I looking for a way to use ingress with this app so that I can access it remotely without exposing any additional ports to the internet.
Does anyone know of a way to use ingress with custom URLs?
Unless you’re running a k8s cluster, you probably mean a nginx or similar reverse proxy?
This is a container running on the same machine as Home Assistant. Add-ons are nothing more than containers, so I’m wondering how I could leverage ingress for other containers running on the same docker hosts as Home Assistant without converting them to add-ons.
Why don’t I want to convert them to HA add-ons? Because that would mean I’m having to update and maintain this container myself, manually, rather than just inheriting the work that’s done already via Docker hub.
I don’t say. I don’t use add-ons either, only the product supported images.
My own reverse proxy is a “plain”, non containerized, nginx.
I just don’t know of a reverse proxy named “Ingress”. Afaik, “Ingress” is the name given to the concept if a reverse proxy in the kubernetes world.
Would you have a link to the product?
In this context, Ingress is the method used to access an addon’s web interface through the HA interface and authentication. Ingress can only be used with addons that are specifically designed for it, not arbitrary URLs.
This was the launch post: https://www.home-assistant.io/blog/2019/04/15/hassio-ingress/
Oh, ok. Thanks for the clarification.
Bright idea to call it that way, if you ask me :wink:
Does that system allows to “proxy” the UI of an addon, without the need for a dedicated reverse proxy setup?
Yes, that’s the point. But it only works with addons that are built for it.
Got anyone new informations? :grinning_face_with_smiling_eyes:
I wanted to expose some server on the network as well through ingress and managed to write a small add-on that uses a nginx reverse proxy server to provide an “ingress-ready” view of the resource. You can install it from here: https://github.com/tux2000/home-assistant-addons
Nginxproxymanager can do this with as many subdomains as you want while only exposing 80 and 443. 80 strictly for https(443) redirect. 443 for the https reverse proxy. To whichever backend IP and ports
Then use Adguard or other DNS service to prevent internal connections to fqdn’s from going out to the internet to be routed back in.
Then you can use the same fqdn Internally and externally
I tried to install your addon but it failed on my HassOS setup.
Failed to install add-on
The command ‘/bin/bash -o pipefail -c apk add --no-cache nginx=1.22.0-r1’ returned a non-zero code: 1
Great that this seems useful to you, @Mincka, and sorry that it did not work. Could you please open an issue at Issues · tux2000/home-assistant-addons · GitHub with more details so that i can have a look at it?
Actually, I think i fixed it. Could you try installing version 0.2.1 ?
Thank your for your reply. I can confirm I was able to build your addon.
I tried to access a few websites on my LAN but it seems there are few incompatibility issues.
I tried the following sites:
  • OpenWRT web interface (Luci): does not load at all. 403 error on cgi-bin/luci/. Maybe it’s related to source IP restrictions that are not seen coming from lan, I need to investigate.
  • Proxmox VE: does not load at all (actually only HTML). The browser attempts to load resources directly on root path (https://xxx.ui.nabu.casa/proxmoxlib.js?ver=3.5.1), so 404 errors and unable to load the interface.
  • Frigate NVR (just to test since it’s useless because of Frigate Proxy addon): Broken interface but few images loaded. I saw this in the container log:
ws4py.exc.HandshakeError: Header HTTP_UPGRADE is not defined
  File "/usr/local/lib/python3.9/dist-packages/ws4py/server/wsgiutils.py", line 101, in __call__
    self. Result = application(self. Environ, self.start_response)
  File "/usr/lib/python3.9/wsgiref/handlers.py", line 137, in run
    raise HandshakeError('Header %s is not defined' % key)
Some JS seems to load ok on some paths, but others don’t:
OK (200) https://XXX.ui.nabu.casa/api/hassio_ingress/LyrTBcff_mAd7UwYSYlIAJzQxqqfzI-mH_DbSKOttuQ/assets/index.e8c171d2.js
NOT OK (404) https://xxx.ui.nabu.casa/api/hassio_ingress/LyrTBcff_mAd7UwYSYlIAJzQxqqfzI-mH_DbSKOttuQ/api/hassio_ingress/LyrTBcff_mAd7UwYSYlIAJzQxqqfzI-mH_DbSKOttuQ/assets/vendor.153a2319.js
  • Portainer: After a initial long loading (it looked like looping resources loading), it managed to load and it works perfectly fine. :+1:
I don’t know if it’s possible to build a universal ingress proxy because of the specifics of each application. However, I am already happy so see that Portainer works great.
Do you prefer individual issues for each site on GitHub or just a single one?
necro, we need working links into frigate proxy, Fix.
Thanx for writing this addon. I couldn’t find other examples how to use ingress with addons in HA. It is really useful. It doesn’t work though when using forms for my addon
If certain targets dont work, it might be due to other places of the html needing an edit than the ones i am handling. The filters are defined in home-assistant-addons/direct.gtpl at ef50dd6a0067f39cf6b4ae96514954bbedd9b069 · tux2000/home-assistant-addons · GitHub and maybe you can extend with more cases that are needed in your use case @mspiridakis and @Mincka
If you fix your use cases, feel free to send a pull request.
That helped a lot.
Thanx again
Just found this, been looking for a way to do this for a long time.
Is there a way to add multiple instances of this addon with different names? I’m running two home assistant instances and need additional ways to access the second HA addons from the primary instance.
Also, accessing Webmin through here would be awesome.
If possible, it would be great if there were additional Destination: line items in the config, as well as sub-urls for the proxy to allow for multiple proxies. This would allow people to add custom panels.
For instance, I’m in the process of migrating my adguard from one HA instance to another, but I have both running at the same time rather than a solid cutover. I’m using your addon and just relabelled it in my config:
panel_custom:
  - name: adguard_server_con
    sidebar_title: Adguard Home 2
    sidebar_icon: mdi:shield-check
    js_url: /api/hassio/app/entrypoint.js
    url_path: '8e1c3c73_ingress_proxy/dashboard'
    embed_iframe: true
    require_admin: true
    config:
      ingress: core_configurator
