I started using home assistant today and already made a lot of progress.
My local smarthome hub is by a company called Innogy (https://www.innogy.com/web/cms/de/3753870/home/ui/).
The system provides a http-request module that allows me to make requests when “things” change on the hub side. Unfortunately the module only allows to make GET and POST request with query parameters but no payload (neither JSON nor anything else). So I cannot use the default json api.
The innogy system also does not provide a “easy” method to poll the values. (the API is not publicly available)
Currently I am using a workaround by using IFTTT as a man in the middle…
INNOGY HUB – send request?params -> IFTTT – send api request json(params) -> home assistant
It works - yay! but is also slow … I would prefer a more direct approach.
First of all I made a mistake:
The post requests of the http-requests module put the parameters in the post parameters.
Still I have a new workaround. I modified /homeassistant/components/api.py:
Probably doing it like this is a bad idea for a number of reasons - but it works, for now:
def post(self, request, entity_id):
"""Update state of entity."""
hass = request.app['hass']
try:
data = yield from request.json()
except ValueError:
try: #added
_LOGGER.error("ValueError in json, falling back to post data") #added debug output
data = yield from request.post() #added get parameters from post parameters
except ValueError:
return self.json_message('Invalid JSON specified', HTTP_BAD_REQUEST) #not handled
new_state = data.get('state')
Now I am looking for a way to host home-asssistant on https and normal (perferably only internally) http at the same time, as the http-request module of innogy cant deal with https… grrr
did your efforts conclude? Is anybody using the Innogy in his setup? It seems to be quite popular in Germany, thought I have the feeling, it’s rather closed source.
Best
