INNR zigbee remote RC210 blueprint, to use with ZHA
INNR_RC210_Blueprint
This blueprint creates an automation that translates the ZHA events which are sent by the INNR RC210 smart button to actions.
Credits for this blueprint go to the original creator of the blueprint for the RC250 remote. Thank you!
For the RC250 remote see this post:
I might work on adding support for different modes later.
Prerequisites
  • The remote has to be paired with a Zigbee controller using the ZHA integration.
  • Due to the use of modern syntax (‘actions’, ‘triggers’), 2024.10 is the minimum HA core version supproted
Configuration
Configuration should be as simple as:
  1. Selecting the action type
  2. Selecting the RC210 remote
  3. Selecting or creating a helper
  4. Select the lights that you want to affect
  5. Configure the fixed action settings. You can configure 4 actions at the moment (On, Off, Long press, Double press)
