Hi Guys, i just moved from 3 Smarthings hub to 2 Raspberry pi4 with Nortek/GoControl HUSBZB-1 USB Hub.
Everything is working awesome except my Inovelli LZW31! I can’t access the configuration of the dimmer i.e Ramp speed, dimming speed, State After Power Restored etc!
Is there will be ,like in openzwave, a way to access and change those setting in Zwave. JS?
Turn off Z-Wave JS and install Z-Wave JS to MQTT. You’ll have to configure it with the device path, etc.
Then you’ll have access to the configuration.
I have the LZW30-SN and it works good. Unfortunately, not all the settings are there compared to the hubitat driver. I’m looking for a way to disable the on/off and just control the bulb w/ an association.
